Cummins crate engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoJuan, Dec 31, 2016.
  1. Mar 22, 2017 at 9:12 PM
    #81
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Hell no
  2. Mar 22, 2017 at 9:15 PM
    #82
    PyroJoe
    PyroJoe Member
    HA! Then why are you here telling people it's a pointless swap? I don't get it. Seems rather pointless. I might as well join a Ford forum and tell people they're all idiots for buying Fords. Not trying to argue. I just enjoy trying to understand psychology of different people since everyone's different (which is a good thing).
    EdinCincinnati likes this.
  3. Mar 23, 2017 at 7:29 AM
    #83
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    This is a social discussion forum. I am here to discuss.
    digitaLbraVo likes this.
  4. Mar 23, 2017 at 7:44 AM
    #84
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    I love diesels, especially Cummins, however that 2.8 weighs the same as a 2UZ-FE (500 lbs)and makes less torque and hp. A 4BT is 250 lbs more.
    Someone really needs to start producing a swap kit for us like the Honda guys have for K's into B or D series cars.
  5. Mar 23, 2017 at 6:23 PM
    #85
    PyroJoe
    PyroJoe Member
    V shaped motors are likely to produce more HP, simply because they're probably going to run much higher RPM's. The torque produced by the 2UZ is probably at a high RPM, and probably has a sharp peak. Whereas, the R2.8 makes 267 lb*ft from 1600 THRU 3200 RPM !!! That is insanely flat! My 5.9 cummins and my LBZ Duramax are like cats and dogs. The Cummins grunts around but doesn't scream down the highway, whereas the Chevy will get up to 80mph in a hurry. Both great engines, but different design completely and different pros/cons.
    If you're going to drag race, mud bog, or live in an area where Diesel is 3x the price of gas, the 2UZ is probably a great option!
    If you're going to be doing rock crawling, dirt hill climbs, slow speed road driving, towing, or just want the efficiency of a diesel and live where diesel is plentiful, then the R2.8 will be a great option! And don't assume that by "efficiency" I mean paying off the swap. Some people like not having to stop for fuel every 150 miles.
    As far as making a kit for the 2UZ...I'll leave that to the gasser guys. I'm really already stepping out of my bounds by messing with a common-rail. My M.O. is building EMP-proof vehicles. The R2.8 will be screwed! But I think that if I shove an R2.8 in a 2wd 5spd w/ 3.3 gears and the R155, I should be able to pull ridiculous mileage, and show the U.S. that the auto makers are a bunch of idiots for not bringing a diesel to the market place like they've had in Australia for decades, when I'll be doing it with an emissions compliant motor and making better mileage than anything they (Toyota) offer today.
    BenMara likes this.
  6. Mar 27, 2017 at 2:13 PM
    #86
    sledman2005taco
    sledman2005taco Member
    cochrane ontario canada
    05 tacoma sr5
    k&n, 20 inch rims gps dvd head unit alpine amps and speakers and sony sub
    hey anybody ever try the vw diesel conversion in a 2nd gen tacoma? I seen a guy that had one in a first gen tacoma and he bought everything in a kit and swears he's getting 30 to 40mpg but i cant seem to find anything on the second gen kit. Just wondering if anyone seen or herd of it or if its a waste of time. I have a first half 2007 dodge 3500 6 speed with the 5.9 so I have other mean when it comes to towing......lol.. and i dont think i could ever afford the 4bt conversion that i would really want.... any help would be great thanks
  7. Apr 9, 2017 at 9:14 AM
    #87
    Kadowampus
    Kadowampus Well-Known Member
    Ventura County
    2011 SR5 4x4 extended cab
    front & rear 5100 Bilstein shocks, eibach/toytec coils, .5" lean spacer, 2" AAL, Derped wheels, Smittybuilt 8000, Technora line, Factor 55 Flatlink, ARB Bumper, Curt receiver, frontrunner load bars, eezi-awn 1600, Lightforce lights, pop-n-lock
    What ever happened with this swap kit? Sounded like a cool idea to have another emissions legal engine option for the tacomas.
    Bigheadtinyarms likes this.
  8. Apr 9, 2017 at 10:45 AM
    #88
    PyroJoe
    PyroJoe Member
    Cummins told me they'd be giving an update after Easter. EPA testing is taking longer than expected. They really want to get this engine approved higher than 1999, and I do, too. At least 2005, if not 2015. That way all 2nd gen Taco's will be covered.
  9. May 20, 2017 at 7:54 AM
    #89
    Taco_eater2015
    Taco_eater2015 Active Member
    2015 Tacoma
    4" suspension lift, ARB bumper, Ramsey Winch, Fuel wheels, BF Goodwrench tires, tinted window, Hood Bug guard, Tool box modification with two 7.62mm ammo cans.
    Over seas makets the Toyota has the Hulix. Nothing more than a Tacoma. The Hulix comes with a diesel motor as standard. What diesel motor it is, I do not know? But I do know the Hulix is bullet proof! I hear in the next few years the Tundra will have a diesel in the American Market. That would be something to consider with my next purchase.
  10. May 20, 2017 at 8:10 AM
    #90
    PyroJoe
    PyroJoe Member
    After doing some extensive research on the Hilux engine and transmission options in Australia a couple weeks ago, I found that the Hilux comes with the same size diesel that puts out more power, and comes factory from Toyota. Which makes me think that for 8 to $10,000 for the engine swap, plus the cost to rebuild your high mileage transmission, it would probably be more worth it to simply source a front cut from Australia and do a bolt in swap.
  11. May 20, 2017 at 10:10 AM
    #91
    Kadowampus
    Ventura County
    Isn't there a 2nd gen hilux diesel that's a direct bolt-in for the 2tr-fe with a 5-speed manual?
  12. May 20, 2017 at 10:17 AM
    #92
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    I thought it was spelled bookoo
  13. May 20, 2017 at 10:29 AM
    #93
    Large
    Large Red
    If I remember diesel toys discontinued putting custom D4D's in 2nd gens, they are doing their own thing now where you have to buy a whole truck from them
  14. Jun 30, 2017 at 6:51 PM
    #94
    Rthompson02
    Rthompson02 Well-Known Member
    NW Florida
    2015 AC with a Hand Shaker
    3 inch leveling kit.
    I'm in...........
    Just have to convince the wife!
  15. Jul 6, 2017 at 12:04 AM
    #95
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    Local place in Albuquerque putting out sweet rides.
  16. Jul 6, 2017 at 12:48 AM
    #96
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    shill
  17. Jul 6, 2017 at 8:36 AM
    #97
    shawnMc
    shawnMc Well-Known Member
    Shawn
    Santa Barbara
    2009 Tacoma regular cab 4x4
    Holy crap! That's the coolest truck I've ever seen.
  18. Aug 15, 2017 at 8:37 AM
    #98
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    did this thread amount to any new swaps?
  19. Aug 15, 2017 at 9:11 AM
    #99
    WhiteDog
    WhiteDog King of the Brittanys
    Brian
    Central Indiana
    Do you ever wonder why Toyota doesn't offer a factory diesel option?
  20. Aug 15, 2017 at 11:13 AM
    #100
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Not enough interest to make it worth the cost. They won't make money.
    taco2010trd likes this.
