Curious about lift
Discussion in 'Suspension' started by austinmacry, May 17, 2009.
  1. May 17, 2009 at 4:46 PM
    austinmacry
    austinmacry [OP] Active Member
    Colorado Springs
    TRD Off-road
    I just got my first taco. Its a stock 2004 TRD Off-road with the double cab. I want to put a lift on it and I read the lift sticky in the forum but Im still a little lost. I want to use aal for the rear and not sure what I need for the front. Where would I find decent ones for the price? What is all that I need to do a complete 2 or 3 inch lift?
  2. May 17, 2009 at 5:39 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
  3. May 17, 2009 at 6:04 PM
    austinmacry
    Colorado Springs
    TRD Off-road
    I want to order a lift kit for my truck but Im a little lost.
    I want to lift it about 2-3 inches. Im think of doing a add a leaf for the rear and coil-over for the front.
    What else would I need to complete the lift kit? (ie. brake lines ect)
    I was looking at a couple different ones and noticed that they normally are a 2.5 in the front and a 1.5 in the rear. Why is that?
    Is there coilovers that arent adjustble? The only reason Im thinking of the is because I read a FAQ and they said the other types of lifts only provide 1 inch of downward movement.
    Pls, let me know. Thanks!
  4. May 17, 2009 at 6:09 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    try the toytec ultimate lift kit. Comes with everything you need. You dont NEED longer brake lines. Its only if you want. I dont have those. Why do you want non-adjustable coilovers? If you want a 3" non adjustable look at the 3" OME lift kit from toytec.
  5. May 17, 2009 at 6:24 PM
    austinmacry
    Colorado Springs
    TRD Off-road
    Is there any need to have them adjustable? I just figured it was something extra that I dont need? Thought it was just another add-on that costs more money.
  6. May 17, 2009 at 6:27 PM
    Brunes
    Brunes abides.
    Rotorhead
    Some folks want adjustable coilovers so they can compensate if the lift sags at all or so they can do less than 3 full inches.
    If you know you want 3 inches- Give wheelers offroad or toytec a call and price out hte OME shocks and coils for the front, OME shocks with an AAL or replacement leaf pack in the back.
    Brake lines are a good idea. Upper Control Arms are also a good idea- Neither is required. You may find ourself in need of axle shims or a differential or carrier bearing drop if you get any vibrations or binding....but that is all case by case.
  7. May 17, 2009 at 7:43 PM
    austinmacry
    Colorado Springs
    TRD Off-road
    Thank you, that is a big help. To much studing on it and I started getting lost on all the items needed for lift. I must look into it some more to make sure i dont buy something i dont need and not buy something I need lol.
  8. May 17, 2009 at 9:53 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    def. get the diff drop if your 4x4. it saved my boots! and rear brake lines are a good idea. and also new rear shocks, everyone recomends bilstein 5100's or 5125's. I changed my rear to 5100's, and it was a huge difference, way better ride!
    Yes, new UCA's are a good idea for allignment issues and a little more travel. I got them for the allignment issues I was having. Your allignment/caster, camber will always be off, and new UCA's will bring it back to spec. But there not a must need item!
  9. May 17, 2009 at 9:59 PM
    austinmacry
    Colorado Springs
    TRD Off-road
    Will the Ultimate Tacoma lift for 95.5-04 Tacoma by toytec work for everything I need. Minus the UCA's and brake lines. I believe it has the diff drop and an aal, rear shocks and coilover for the front. The rear needs no springs right?
    Im sorry Im mechanical declined but Im trying to learn.
    -thanks
  10. May 17, 2009 at 10:22 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    correct - rear has no coils
  11. May 17, 2009 at 10:27 PM
    austinmacry
    Colorado Springs
    TRD Off-road
    Alright! Just need to drop a grand now lol. Wow, I cant wait to get under it and start cranking away. A couple more months when I get home I get to have some real fun!!!
  12. May 17, 2009 at 10:59 PM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    Theres alot of great places to wheel out in the springs. I'm guessing your at Ft. Carson I used to be right across the street at NORAD. I'm about to do the toytec ultimate lift prob in 2 weeks on my 09 I think its right choice for me but look around there are alot of lifts out there.
