Current wheels set ups
Discussion in '5 Lug' started by Poot Klopp, Dec 8, 2010.
  1. Jan 15, 2016 at 4:29 PM
    #181
    4 Season Taco
    4 Season Taco Well-Known Member
    2010 5 Lug Taco
    so do your tires stick out of the wheel wells or do they sit flush?
  2. Jan 15, 2016 at 4:39 PM
    #182
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
    They stick out of the wheel well.
  3. Jan 15, 2016 at 4:45 PM
    #183
    4 Season Taco
    2010 5 Lug Taco
    good to know, thanks for your help!
  4. Jan 15, 2016 at 5:13 PM
    #184
    Rolis12
    Rolis12 Well-Known Member
    Rolis12
    San Diego
    2015 5lug access auto
    Goodyear Wrangler TrailMark 31's. F.B's 2.75" spacer, TRD rear shocks, stub antenna, ripped out charcoal filter added AFE dry, Chrome grille, upgraded to SR5 sun visors, variable wipers, backup camera, HID DDM 35w 5000kv, ebay fogs w/yellow LEDs.
    I have 31s on my 2015 5 slug the wheels are Ion Alloys 15x7 with -6mm offset, 3.75" backspacing and the tires stick out but the rims look flush.
    SleazyPetey likes this.
  5. Jan 15, 2016 at 5:22 PM
    #185
    SleazyPetey
    Pete
    2013 Regular Cab
    Sorry for the bad quality pic, its rainin in VA. They stick out even with the aftermarket fender flares on - which stick out a couple inches from the side of the truck
    Rolis12 likes this.
  6. Jan 15, 2016 at 6:05 PM
    #186
    4 Season Taco
    2010 5 Lug Taco
    so if I don't have fender flares and I go with 15x8, -19mm, with 235s they are going to way out there
  7. Jan 15, 2016 at 6:08 PM
    #187
    SleazyPetey
    Pete
    2013 Regular Cab
    Yepperz. It's going to be sticking out more noticeably
  8. Jan 15, 2016 at 6:14 PM
    #188
    4 Season Taco
    2010 5 Lug Taco
    guess i'll go with 15x7 because I don't want to have my tires to far past the body, but with that said I do like the wider stance look. I guess worst come to worst I can buy some wheel spacers if I feel necessary
  9. Jan 15, 2016 at 6:16 PM
    #189
    SleazyPetey
    Pete
    2013 Regular Cab
    Definitely! What wheels were you looking at in particular??
  10. Jan 15, 2016 at 6:18 PM
    #190
    4 Season Taco
    2010 5 Lug Taco
    American Racing AR23 Wheels
    think they would look good with my rack
    Geronimo1111 likes this.
  11. Jan 24, 2016 at 8:54 AM
    #191
    gsesupport1
    gsesupport1 Active Member
    18 Cement DCLB 4x4 TRD Sport
    Running Boards, Sprint Booster, Remote start, Custom vinyl decals, Valve stem caps (little green hand grenades)
    I was running 235/55/16's on my 07 Taco, Access cab, 2.4l 4cy, MBWHEELS Seven X with I think the offset might be 42mm. I would like to put 245/70/16's without any mods, does any one know if this is possible?
  12. Jan 24, 2016 at 8:55 AM
    #192
    gsesupport1
  13. Feb 2, 2016 at 11:44 PM
    #193
    Tacomoto23
    Tacomoto23 Well-Known Member
    Carey
    Torrance,CA
    21’ TRD 4x4
  14. Feb 8, 2016 at 6:17 AM
    #194
    benharrison
    benharrison Member
    Ben
    Bristol, VA
    I just got a set of 30x9.50R15 General Grabber AT2 Tires installed.
  15. Feb 11, 2016 at 5:39 AM
    #195
    benharrison
    benharrison Member
    Ben
    Bristol, VA
  16. Feb 15, 2016 at 8:21 PM
    #196
    Jamrome918
    Jamrome918 New Member
    Joshua cortes
    2007 black Tacoma
    No modification
    15x8 0 offset on 30x10.5x15
    Oscvr_g, Nathan103, KS WRAITH and 2 others like this.
  17. Feb 16, 2016 at 8:00 PM
    #197
    Bristow.907
    Bristow.907 Well-Known Member
    Onterrible
    07 AC sr5
  18. Jul 27, 2016 at 10:01 PM
    #198
    SleazyPetey
    Pete
    2013 Regular Cab
    I think that's a little too expensive for those wheels. You can find very similar ones from American Racing for about $50 a pop
  19. Jul 28, 2016 at 5:51 AM
    #199
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    I would try to bring him down $100-200.00. That seems to be a bit of a premium price given it's USD $, and your retail prices are more reasonable, as compared to here.
    Retail, that would be worth around $1100.00 CDN for the tires, new, and $75.00 a rim, before 13% tax would be applied.
    Review on the Pathfinder S/AT tire here on the forum:
    https://www.tacomaworld.com/threads/pathfinder-sport-s-a-t-first-hand-opinion.311861/
  20. Jul 28, 2016 at 11:16 AM
    #200
    HackD
    William
    If they got the look and fit for the truck that you are going for - i would likely go on that price. Make sure the center bore diameter is compatible with what you need first.
    The value of the OEM steel wheels is negligible, and potential buyers won't exactly be breaking your door down to get at 'em... you might get lucky, but i wouldn't bank on it.
