Current wheels set ups
Discussion in '5 Lug' started by Poot Klopp, Dec 8, 2010.
  1. Dec 2, 2014 at 10:21 AM
    #121
    SxSW
    SxSW Well-Known Member
    Joe
    NM
    14 Base
    Just put these on my 2014 5 lug 2wd.
    Wheels: ProComp 7069 - 15x8's
    Tires: Factory 215,70,15
    Mods to Fit:3mm spacer on front
  2. Dec 20, 2014 at 7:34 PM
    #122
    lloyd
    lloyd Active Member
    Texas
    15 Tacoma Access 2.7
    HID headlights, LED interior lights, Hella and stock HID foglights, Hella HID driving lights, backup camera, Wiper mod, cruise control mod, higher rate springs , X- runner Rear rollbar and x-brace, K&N air filter, Amsoil in trans and diff, EBC yellow stuff pads pads, stainless brake lines, 18x8 40mm wheels with 235 55r 18 tires, oil cooler with remote big oil filter
    Enkei 18x8 +40mm with 235 55R 18 tires.
  3. Feb 24, 2015 at 10:57 PM
    #123
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
    Wheels: Stock
    Tires: BFG KO's 235/75r15
  4. Aug 24, 2015 at 6:01 PM
    #124
    SleazyPetey
    Pete
    2013 Regular Cab
    bump. I need some options on which wheels to get! If you have any aftermarket wheels please post pics! :D:thumbsup:
  5. Aug 24, 2015 at 7:54 PM
    #125
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    I didn't purposely set out to get this particular set, or style of rims - these are shown on the manufacturer website as being used on low-slung sporty things with low profile tires, than my ugly duckling. I happened upon a deal, when i inconveniently realized that time had expired for my OEM Dunflops, and needed a new set of tires PDQ. A browse upon kijiji.ca (Ebay Classifieds for the Americans) found this set of 5 just around the corner with LT225/75/R16's already on them with better than 80% wear, for less cost than the tires. RTX Arsenic 16x7 aftermarket rims, with an offset of 40. They were originally on a 2002 Jeep Liberty. Although they are relatively skinny rubber, they were ideal for an immediate throw-on upgrade, as i hadn't yet done my level-lift. When the rubber wears out, I can replace with up to 265/75R16 rubbers, if i so wish. They've grown on me, and they look distinctive from the rest of the Tacoma herd.
    http://www.rtxwheels.com/en/wheels/rtxwheels-arsenic-black-machined
    Close-up, immediately after purchase, propped up against my front wheel:
    Mounted on the truck, with stock suspension, no lift:
    And most recent, two weeks ago, after my Readylift SST kit install:
    SleazyPetey likes this.
  6. Aug 24, 2015 at 7:58 PM
    #126
    SleazyPetey
    Pete
    2013 Regular Cab
    It does look distinctive, but it still looks good! Any plans on moving to a more thicker tread; such as Duratracs or KO's?
  7. Aug 24, 2015 at 8:04 PM
    #127
    HackD
    William
    When they wear out, I'll look at more aggressive tread block patterns. I'm a cheap bastid in that way.
    I am actually eyeballing LT235/75R15 Duratrac's at the moment, for winter/snow tires on my stock steelies. I need to do that first and foremost, before the winter hits. These aftermarket rims definitely won't stand up well to our road-salt encrusted winter environment.
  8. Aug 26, 2015 at 4:00 PM
    #128
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Rims: Mickey Thompson Classic 3 15x7
    Tires: BFG KO's 235/75R15
    Mods to fit: Black box and 1/4 in spacer
  9. Aug 26, 2015 at 4:01 PM
    #129
    SleazyPetey
    Pete
    2013 Regular Cab
    stock suspension?
  10. Aug 26, 2015 at 4:02 PM
    #130
    5 Lug Fury
    Kenny
    Knoxville, TN
    Yup I did add the TRD bilsteins in the back but that only made it stiff not raise it.
  11. Aug 26, 2015 at 4:03 PM
    #131
    SleazyPetey
    Pete
    2013 Regular Cab
    How do you like it? Are the TRD Billies 5100's?
  12. Aug 26, 2015 at 4:07 PM
    #132
    5 Lug Fury
    Kenny
    Knoxville, TN
    No just TRD Bilsteins I got a full set from a 2010 for $30 :D
  13. Aug 26, 2015 at 4:08 PM
    #133
    SleazyPetey
    Pete
    2013 Regular Cab
    whatttt how?? :confused:
  14. Aug 26, 2015 at 4:10 PM
    #134
    5 Lug Fury
    Kenny
    Knoxville, TN
    Craigslist
    They were a bit hard to put in since its 3in longer but it was definitely worth it.
    SleazyPetey[QUOTED] likes this.
  15. Sep 4, 2015 at 6:18 AM
    #135
    SleazyPetey
    Pete
    2013 Regular Cab
    Quick question. Will 15x8 wheels work with 235x75 tires? Any issues with that?
  16. Sep 4, 2015 at 9:06 AM
    #136
    yeauxta330
    yeauxta330 Member
    Lorenzo
    Lafayette, Louisiana
    '12 Reg Cab 2WD 5lug auto
    Yoko Geolandar A/T-S 235/75/R15s on stock wheels
    from stock steelies and 215/70/15 tires to stock steelies and Yokohama Geolandar A/T-S 235/75/15 tires:
  17. Sep 4, 2015 at 2:16 PM
    #137
    HackD
    William
    Should be fine.
  18. Oct 18, 2015 at 2:42 PM
    #138
    SleazyPetey
    Pete
    2013 Regular Cab
    bumpity bump
  19. Oct 19, 2015 at 3:28 AM
    #139
    FlipTaco808
    FlipTaco808 Active Member
    Lj
    Hawaii
    2013 Red Double Cab 4 Banger
    6k Hid Hi/low 235/75r15 Winda All terrains
    Wheels: 1999 ford xlt Aluminum rims.
    Tires: Insignia 225/75 r 15
    Mods to fit: Grinded caliper about 2mm to clear.
    Thinking about upsizing to 235/75's or 30x9.5 soon.. Any suggestions guys
    k3v11n likes this.
  20. Oct 19, 2015 at 11:33 AM
    #140
    SleazyPetey
    Pete
    2013 Regular Cab
    Looks good!! I have 235/75's on mine and I like them, but I want to get bigger tires in the near future. Have you thought about getting a lift on yours?
