Custom auxiliary fuse panel FS thread
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by tooblutacoma06, Jan 22, 2010.
  1. Jan 22, 2010 at 5:26 PM
    tooblutacoma06
    tooblutacoma06 [OP] Member
    Kellon
    Houston
    Following my post for my auxiliary fuse block install (http://www.tacomaworld.com/forum/2nd-gen-tacomas/69853-blue-sea-aux-fuse-block-install.html), I got quite a few inquiries on producing some extra mounting panels.
    So here's the deal:
    I will be making the panel I used in my install for anyone who wants one. The panels are CNC cut from 1/8" corrosion resistant aluminum. I offer a couple of different finishes: powder coated black or bead blasted. I can also include custom hole patterns for accessories.,I would just need the measurements. I will also be including stainless steel hardware that will allow you to bolt the plate up to the threaded holes on the fenderwall.
    Process:
    The way it will run is that whoever is interested can send me a PM with what option panel they want (from the list below). Payment will be via PayPal and once payment is received I will get the panel shipped out (depending on my inventory level). I do have a full time job (in Oil and Gas, no less, which operates 24/7/365) and I am doing this on the side just to help out fellow owners (after all is said and done I don't make too much off of these). So please bare with me on production times. I will ship USPS as they are the cheapest and easiest.
    All panels will come with the necessary stainless steel fasteners to mount it to the truck and to mount the support bracket.
    Currently, my design fits the following models:
    2005-current manual/automatic without ATRAC
    2005-current automatic with ATRAC
    Cost:
    So here is the current price break down:
    Option 1: panel with pre-drilled hole patterns for Blue Sea 5026 fuse block and Blue Sea model 187 surface mount breaker and powder coated black - $75 shipped inside continental US
    Option 2: blank panel with mounting holes only and bead blasted finish - $60 Shipped inside continental US
    Option 3: custom hole patterns drilled based on customer providing hole pattern dimensions of desired hardware - $65 shipped inside continental US
    Add ons:
    Support bracket including black powder coating - $7
    Black powder coating if your panel doesn't already come with it - $15
    If you have any questions or I did not cover something, certainly let me know and I'll clear it up. Thanks guys!
    Here's some pics of the original panel, and how it looks like mounted:
    Customer's custom finishing (he bought a blank panel and drilled his own bolt patterns):
    Here are some renderings of the CURRENT DESIGN that fits ATRAC (automatics) or non-ATRAC models:
    ATRACPanel_BS5026fusebox_BS187breaker_pe_62dfa24ea30fa999ece51e123883a95e65b6c1fc.jpg
    ATRACPanelAssemblywithBS5026fuseboxandBS_d841609d247156b56f13b7435f7133a9922c7b0b.jpg
    Customer's install with ATRAC:
    Let me know if you have any questions!
    ca08tacoma, angeldavid216 and Durdy like this.
  2. Jan 22, 2010 at 5:29 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    that's pretty slick! if i didn't have a pa speaker right there i'd be very interested.
  3. Aug 17, 2010 at 7:30 PM
    MJonesTrumpet
    MJonesTrumpet Well-Known Member
    Michael
    Central PA
    Nice set-up!!! Do you still make the brackets for these? I'll send ya a PM as well. Thanks!
  4. Dec 7, 2010 at 3:56 PM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
  5. Dec 7, 2010 at 4:09 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
  6. Dec 7, 2010 at 5:50 PM
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    still makin these
  7. Dec 7, 2010 at 7:43 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    Is there any problem using this system in conjunction with a dual battery set up with an isolator?
    PeterMN likes this.
  8. Dec 14, 2010 at 3:08 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    You still making these?
  9. Dec 30, 2010 at 2:43 PM
    RCL
    RCL Well-Known Member
    Bob
    Oklahoma
    2010 TRD Dbl. Cab
    Winch
    Checking to see if these are available.
  10. Jan 14, 2011 at 10:39 AM
    tooblutacoma06
    Kellon
    Houston
    PMs sent!
    For those interested, I'm still making these panels.
    One design change though:The bracket no longer requires modification to the truck for install. It uses a factory bolt location for the OEM fuse box.
    Also, I now am offering the option of an aluminum plate like mine. It is also 1/8" thickness. I have much more capable cutting equipment now. Here's the advantages to Al:
    -corrosion resistant
    -light weight (density ~1/3 that of steel)
    -can be anodized for custom colors
    -easier to drill into than steel (for additions to the panel)
    Prices:
    EDIT: See OP for pricing.
    Let me know if you have any questions. I'd be glad to answer them. Thanks!
  11. Feb 13, 2011 at 5:29 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Subbed for when I start this project. Great work Kellon
  12. Feb 16, 2011 at 7:36 PM
    tooblutacoma06
    Kellon
    Houston
    Just posting a little update. Three members' panels in three different stages.
  13. Apr 11, 2011 at 8:27 AM
    MHS2846bg8
    MHS2846bg8 Experienced Noob
    Nate
    South Coast of Oregon
    21 Tacoma TRD Off-Road Dbl Cab 4x4
    4WP Factory Front Bumper w/Warn VR EVO 10-S Winch, AuxBeam 8-Switch Controller, Redarc Trailer Brake Controller, ARE CX-Evolve Cap, Bedrug Liner, Ditch Pod Lights, Aftermarket LED (OEM) Bed Lights, Console Vault
    Nice job! Love your install btw...wish these were for a 1st gen...
  14. Apr 11, 2011 at 2:48 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    could you do this for a 1st gen??????
  15. Apr 11, 2011 at 3:00 PM
    sierrahsky
    sierrahsky Expedition Style
    Big question I have and I found this out the hard way. Can you make one for a 2009+, the engine bay is different on the config and my last purchase of one of these ( not from this forum) did not fit. It was for an 07 and I had to rebuild from scratch.
  16. Apr 11, 2011 at 3:50 PM
    MHS2846bg8
    Nate
    X2! :D
  17. Apr 11, 2011 at 8:10 PM
    sierrahsky
    I have the off road version with a-trac but I believe its the same set up for anything with a 6speed. I will double check the trucks on our lot that dont have atrac.
  18. Apr 11, 2011 at 9:08 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I have the same question. I'd like one of these, but I have a 6 speed OR with ATRAC and the typical mounting location is taken by a clutch fluid reservoir so the only real mounting location is on the passenger side...thus the design will be different.
  19. Apr 12, 2011 at 8:18 AM
    tooblutacoma06
    Kellon
    Houston
    Do you have a picture of the difference in the configuration? I don't have access to a truck with ATRAC but I might be able to figure something out if someone can post up some good pictures and measurements of the reservoir.
  20. Apr 12, 2011 at 8:20 AM
    tooblutacoma06
    Kellon
    Houston
    So the passenger side is empty right? Do you have a picture of it so that I can verify its the same as mine. If so, I can work up a design for the passenger side too, that way there will be multiple options.
