Custom Billet Shift Knob for Toyota Tacoma (2-1/4" diameter). ***Utilizes factory boot.***
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 7r41lbr34k3r, Feb 15, 2018.
  1. Feb 10, 2021 at 8:59 AM
    #2881
    7r41lbr34k3r
    7r41lbr34k3r [OP] Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Correct. In your first quoted post "#8-A engravings" refers to the 6spd shift pattern (8) and TRD (A), respectively. Those codes are taken from the picture (I will post it below) that I have linked in the first post.
    tonered likes this.
  2. Feb 10, 2021 at 12:00 PM
    #2882
    TPMO
    TPMO Well-Known Member
    2017 Tacoma SR Utility 4x4 MT
    As the order date approaches let me try to make sense of my anticipated order. I believe Ill go with the V.1 as that will work with my existing collar. I want aluminum with temp resistant copolymer ring and grip groove. The s12 (SR) top engraving. I am hoping for a nice weight for the knob and here is where my confusion lies. Do I need to add the brass core? And if so does that require the hybrid collar?
    Thanks in advance for the help!
    Trying to be concise. My order is as follows:
    V1 MT Hybrid (Copolymer core) w/ temp-resist Copolymer ring [220g] $99.99
    Top engraving #12 $14.99
    Grip Grooves $19.99
    Shipping & Paypal $14.80
    Total $149.77
  3. Feb 10, 2021 at 1:17 PM
    #2883
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Close, you're only missing the copolymer hybrid core charge.
    But yes, if you want weight I'd go brass, otherwise, this configuration would not be much heavier than your stock knob. I can do brass on either V1 or V2 to the aluminum base material.
    I do not have the exact weights of the V1's as they have been redesigned slightly.
    Here is a sectional view showing what the new design will look like. The OEM chrome pc will still be utilized for V1's as always, but it will be completely covered. This allows for graphics on the side (Plain blank, TRD, SR, etc ... ) of the collar cover area. There will be no charge for the side graphics on V1 MT, as they will be 3D printed and not machined.
    This is a similar idea to the part I already sell on Etsy, except it attaches to the knob:
    https://www.etsy.com/listing/893156536/2016-toyota-tacoma-shift-boot-retainer?ref=shop_home_active_1
    TeecoTaco likes this.
  4. Feb 10, 2021 at 1:38 PM
    #2884
    TPMO
    Excellent! Thanks man... No need for exact weight as I trust the brass core will suit my needs.
    So the revision should be:
    V1 MT Hybrid w/ temp-resist Copolymer ring $99.99
    Brass core hybrid $24.99
    Grip Grooves $19.99
    And I'll take the SR printed collar covered area.
    Total $174.76
    If I'm missing anything just let me know so I can fire the correct order off to you on the 15th.
    Thanks again!
  5. Feb 10, 2021 at 1:43 PM
    #2885
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Yep, that looks good. I expect it would be in the 350-400g range but I will get that all figured out before machining begins.
    TPMO[QUOTED] likes this.
  6. Feb 10, 2021 at 4:10 PM
    #2886
    TRDCal
    TRDCal Well-Known Member
    Canada
    2018 DCSB Sport MT
    I would like this exact shift knob (v2 with TRD on the collar and shift pattern on top) with aluminum as the metal (I say that incase the one pictured is Stainless) also no brass core needed.
    Is that enough of a description for the 15th or do I need to provide specifics. Also do you ship to Canada?
  7. Feb 10, 2021 at 5:05 PM
    #2887
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    That one is titanium, no takesie backsies!
    I kid. That is enough information. I would only ask if you wanted the outlined shift pattern like that one, or the fully pocketed option. The pocketed option is only available for shift patterns on aluminum, and costs no extra.
    TeecoTaco and tonered like this.
  8. Feb 10, 2021 at 5:16 PM
    #2888
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Ti?
    Did someone mention Ti?
  9. Feb 10, 2021 at 5:17 PM
    #2889
    TRDCal
    Canada
    2018 DCSB Sport MT
    Oh wow Titanium! Aluminum is fancy enough for me, I would got fully pocketed. I have my alarm set to the 15th so I hope I get a spot. I take it shipping to Canada is not an issue.
    Any idea on how much will that setup weight compared to stock? I don't want a super heavy knob but slightly more than stock would be nice
  10. Feb 10, 2021 at 5:18 PM
    #2890
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Get some!!!
    7r41lbr34k3r[OP] likes this.
  11. Feb 10, 2021 at 5:24 PM
    #2891
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    It's 270g, close to 100g more than stock. Yep, I have always shipped to Canada ... not a problem.
    TeecoTaco and TRDCal[QUOTED] like this.
  12. Feb 10, 2021 at 5:36 PM
    #2892
    Ooh-it's all squishy!
    Ooh-it's all squishy! Where's the kaboom?
    Rod
    OK
    2020 Black TRD Pro MT
    KDMax Pro Tune, debadge, tonneau, hood struts, some ME-SO goodies, JL-Audio
    Speaking of Ti :D
    After digging myself out of a pile of work, I experimented a bit, and decided the weight of the Ti will be about perfect (plus, it's titanium).
    Probably going to shoot for just a straight Ti knob, 6-speed engraving (maybe TRD on the boot collar). I kind of like the copolymer ring, but I may want to color the metal at some point (how hard is it to unpin the ring and repin it?).
    tonered and TeecoTaco like this.
  13. Feb 10, 2021 at 5:49 PM
    #2893
    TeecoTaco
    SW Ontario
    This is madness...MADNESS I say!
    Bless your soul
  14. Feb 10, 2021 at 5:52 PM
    #2894
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I would say it's impossible to unpin without destroying the ring, unfortunately.
  15. Feb 10, 2021 at 5:55 PM
    #2895
    Rod
    OK
    I was thinking that might be the case. I might still get the ring though (and not try to remove it :D), if I don't mess with coating the Ti (I like to 'unshiny' as much as possible in the truck), the ring will add some nice contrast.
  16. Feb 10, 2021 at 6:15 PM
    #2896
    TeecoTaco
    SW Ontario
    For what its worth, here is my input...solid Ti guy, no ring (was kinda early adopter)
    Cosmetically I really like the Ti with ring. Had that been an option I would have heavily considered it. I dont think the ring option on Ti would nominally alter the feel weight of the Ti with the non ring option.
    Temp tolerance wise...the Ti is most friendly. Again, no ring on mine and unless the knob is in direct sun thru glass it doesnt heat up as much as my Al, dissipates much, much more quickly and its the same with the cold...it just seems to strive fo a balanced temp very quickly.
    Feel wise...well, until you have had 454g of solid, un-impeded by co-polymer, finely machined Titanium in your hand...thats something in itself.
    It has a frequency to it...mebbe im :rasta: (I am) but there truth there...hard to explain
    Dont be afraid of solid Ti environmentally Edit: by enviromentally i mean temperature wise
    Rick fears his bits tho :sorry:
  17. Feb 10, 2021 at 6:41 PM
    #2897
    kaotic
    kaotic Active Member
    kyle
    Salem,OR
    2020 super white DCSB TRD sport 6MT
    I am going to be that guy. I’ve look through this thread a lot but haven’t seen what exactly each metal looks like in color. Is there any way you can post pictures showing each? I really like the 3rd pic of the original very first post. Price will dictate which way I go unfortunately
  18. Feb 10, 2021 at 6:43 PM
    #2898
    TRDCal
    Canada
    2018 DCSB Sport MT
    Why must you tempt me!?! My one concern about going to a metal knob is driving in cold weather. Titanium does sound way better
  19. Feb 10, 2021 at 6:53 PM
    #2899
    TeecoTaco
    SW Ontario
    I went down baker street twice...first was Al. Then I went Ti...cuz I'm kinda a freak that way. I digress...but I didnt go Ti because of temps (it is a huge difference tho) but because Im a freak...that being said, the Ti is the most temp friendly of the metals.
    And it shows the best.
    Either way one decides to square the equation of cosmetics vs feel vs cost...baker street is the way to go
  20. Feb 10, 2021 at 7:26 PM
    #2900
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
