Custom LT kit
Discussion in 'Long Travel Suspension' started by 661prerunner, Aug 6, 2012.
  1. Aug 6, 2012 at 11:34 PM
    661prerunner
    661prerunner [OP] Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
    I am going to be trading my MTB that ive use a handful of times for this kit.( if the guy doesnt back out) Since i never use my bike id figure Id try it out and see if it works out
    What are your thoughts on it? Opinions Please some insight would be helpful
    Here are the specs per post
    I have a custom long travel suspension kit with heims. Was built for a 2wd Tacoma but with custom mounts on the frame can be run on any thing pretty much. Comes with upper and lower A arms, custom spindles with brake calipers. Does NOT come with wheel spacers or rotors. Cycles 15" at the wheel and is about 3" over per side on a tacoma. It's a 6 lug but was on a 5 lug taco. Heims all around. Also comes with complete steering rack with extensions and heims. $700 or trade for DH bike or 35" + tires
    This is the post info doesn't have the steering rack and brakes But comes with everything else
    *** from what he told me he bought the truck with the kit on and said the kit was built by Trail gear.
    Hows does this sound? does it seem like i can Prerun it or just a Street Queen
  2. Aug 7, 2012 at 12:09 AM
    661prerunner
    Santa Clarita
    01 prerunner
    This is some info he gave me????? Thoughts ??????
    Ok so the three frame mounts you have to weld to frame are very simple. Bolt the lower control arm rearward bushing into stock location and line up the forward one then weld in. Bolt the spindle to lower CA and then to upper CA. Line the upper mounts up on top of the frame and weld in. To get the full range of motion with this kit I'd recommend a 10 or 12" coilover. Use probably 350 over 450 springs. Set ride height with 60% of shaft showing for best high speed/jumping performance.
  3. Aug 7, 2012 at 6:34 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  4. Aug 7, 2012 at 7:19 AM
    661prerunner
    Santa Clarita
    01 prerunner
    well i do respect you response
    but im sure your gonna have a great response So i have to ask WHY?
  5. Aug 7, 2012 at 7:51 AM
    Davidd
    Davidd Well-Known Member
    David
    San Jose, CA
    02 PreRunner
    Truck Built by DMZ
    Because the kit was built for a 2wd Tacoma which pretty much means a 5 lug. You do not want to mix suspension components from another frame. It will cost more money and not work correctly.
    Also, the spindle will not work for your truck. You would either have to get one built, which is more money, buy one or modify the kit to work with your current spindle.
    So save your money for a kit that would work with your specific truck mate.
  6. Aug 7, 2012 at 8:59 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    yeah thats a 5 lug kit, not worth your time.
  7. Aug 7, 2012 at 9:04 AM
    661prerunner
    Santa Clarita
    01 prerunner
    the only reason im thinking about this is cuz its for a MTB i dont use
    It comes with the spindle
    Seems i would have to find brakes for it and aslo have an enging cage done for it to be done right. In pic its a 6lug but it was put on a 5lug.
    I know it would cost some money which is why im asking get this one or Save and buy
    and by the few responses and the more I think I would probably spend the same or save money (and headaches buying new)
    and i know if I trade and dont want it itll be hard to sell or trade again
  8. Aug 7, 2012 at 9:05 AM
    661prerunner
    Santa Clarita
    01 prerunner
    yeah It seems Im gonna save some more cash.....I guess ill try to sell my MTB again:D
  9. Aug 7, 2012 at 9:08 AM
    97yota4wd
    Eric
    Mesa, AZ
    yeah thats your best bet, that kit in the picture was not origionally for a 6 lug, hes yanking your chain.
  10. Aug 7, 2012 at 9:16 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Wow pass on that. His instructions on installing are far from easy and why is he using donuts? that gives the best high speed and jumping? That guy has no idea what he is talking about. How much is your MTB worth?
  11. Aug 7, 2012 at 9:31 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
  12. Aug 7, 2012 at 9:33 AM
    Davidd
    David
    San Jose, CA
    02 PreRunner
    Truck Built by DMZ
    Even though it comes with a spindle, it is not meant for your truck. 5lug vs 6lug spindles are way different.
    I may sell my Camburg LT kit next year. Be on the look out for that as i will let it go for pretty cheap :)
  13. Aug 7, 2012 at 9:47 AM
    661prerunner
    Santa Clarita
    01 prerunner
    CR250 $1000 new in Late 08
    Yeah Im gonna back out in this on
    Davidd If you do Pm me if you do what are your plans you going custom
  14. Aug 7, 2012 at 11:20 AM
    661prerunner
    Santa Clarita
    01 prerunner
    Well Im passing on this deal and continueing to save....
    If anyones looking to buy a MTB pm me
  15. Aug 7, 2012 at 10:53 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Wow that's terrible
  16. Aug 9, 2012 at 9:35 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    That thing is siiiick broo ham. It's got long travel for days bro. Who cares about, camber, caster, kpi, or bumpsteer yo.
