Custom roof basket access cab build
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bradpad, Apr 18, 2012.
  1. May 14, 2012 at 8:29 PM
    #141
    Bradpad
    Bradpad [OP] Well-Known Member
    Brad
    MASS
    07 SR5 Access Cab V6 4x4
    K&N polished intake QTP electronic exhaust cutout
    pics of the rack test fitted (all of the brackets fit perfect! :D ) with the new guessets welded on
  2. May 14, 2012 at 8:30 PM
    #142
    Bradpad
    Brad
    MASS
    close up of the brackets with guessets - feels so much more solid than before guessets
  3. May 15, 2012 at 9:20 AM
    #143
    Bradpad
    Brad
    MASS
    anything you guys think i should add or change before it gets bolted on in a couple days???
  4. May 15, 2012 at 9:32 AM
    #144
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Looks good. I probably would have taken the gussets all the way to the top so it ties all the pieces together, but it's too late for that. I think you have covered the area of the biggest concern.
    Anyway, job well done. Load 'er up!
  5. May 15, 2012 at 1:34 PM
    #145
    Bradpad
    Brad
    MASS
    thanks man!
    And yea the weakest point is definitely that bend so i wanted to cover the bend up to the top of the premade bracket, the top piece I welded on the makes it extend horizontally is actually very strong so i didn't think it would need but like you said it's already welded so no going back now :D
  6. May 18, 2012 at 5:17 PM
    #146
    Bradpad
    Brad
    MASS
    The rack is getting mounted this Monday for those still waiting to see the mounting process and the rack loaded up!
    I can't wait!
  7. May 18, 2012 at 8:19 PM
    #147
    weazel
    weazel Well-Known Member
    I second this and only because the way the rack sits all the forward/backward movement on the rack is on the weld and flat section.
  8. May 18, 2012 at 9:00 PM
    #148
    Bradpad
    Brad
    MASS
    the weakest link is the bend (if you didnt read whole thread) at the base of the bracket, that has been reinforced with the gusset. i already said that i Should have gone all the way to the top of the brackets but as it sits now there is virtually no movement when smashed with a hammer
    i appreciate the concern.
  9. May 21, 2012 at 5:37 PM
    #149
    Bradpad
    Brad
    MASS
    ALL DONE AND MOUNTED. I LOVE IT!
    very very solid, has no flex in any direction when I push on it
    does make a "wind" noise when driving at any speed over 40mph but that cant be heard is windows are down or music is on
    rubber "flange" in between the actual metal of the truck and the metal bracket
    THOUGHTS?
    i will have more pics tommorow!
  10. May 21, 2012 at 5:38 PM
    #150
    Bradpad
    Brad
    MASS
    my buddy at his shop who did the actual install used a locking agent on the bolt and nut to make a moisture and water proof barrier
