Custom Sub Box Tacoma Xtra Cab
Discussion in 'Buy / Sell / Trade' started by monte1985, Apr 9, 2009.
  1. Apr 9, 2009 at 6:15 PM
    monte1985
    monte1985 [OP] Well-Known Member
    Stan
    Lancaster NY
    09 Tacoma Dbl Cab 4.0 S/C
    Supercharger, Magnaflow Exhaust. Audio System . Gauges TRD CAI
    You are looking at a custom sub box for a Toyota Tacoma Pickup.Also my fit other extended cab trucks with a little work . I built this and had it in my 2000 tacoma. It should fit 95-00 Tacomas that are the Xtra Cab. It may also fit 01-04 but im not sure . This box has 4 10" Kicker Subs in it . The box has a 3/4" thick Plexiglas face and is built out of 3/4" MDF board. Inside is 2 blue neon lights along with 2 white strobe lights. It also has 2 blue neon lights under the faces of the speakers . Also there is a Plexiglas mirror that slides under the bottome to see the faces of the speakers and to make it look like you have 8 speakers. The Speakers are Kicker Impulse L10 , they are 4ohm 125w single voice coil. I ran these with a Orion 2150XTR amp and the box hit 143db in SPL. The top and the face of the box are removable and are carpeted panels. The color is a light Grey silver color. The amp rack is also included and was built to fit 2 Orion 2150 xtr amps. Also in the center was an opening for a fuse block. If other amps were to be used you would have to build a new cover to fit your amps. All this fits behind the front seats . You do however need to remove the back fold down seats for this to fit . What you will get is the whole box, both top and front covers. Upper and lower amp rack mounts. The 2 amps and the fuse block are not included. The speakers and the neon lights and strobes are included. Looking to get $450 or best offer. Can Only be local pickup too. To big and heavy to ship.
  2. Nov 19, 2010 at 11:07 AM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    Holy Cow! did you build that yourself?!
  3. Nov 19, 2010 at 11:09 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Little small isn't it? Where do i put all my guns?
  4. Nov 19, 2010 at 11:09 AM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    That's sick! Goodluck!
  5. Nov 19, 2010 at 12:21 PM
    militaco
    militaco Well-Known Member
    Hawaii
    2009 Double Cab, '99 Regular Cab
    Totally sick....wow
  6. Nov 19, 2010 at 3:48 PM
    monte1985
    Stan
    Lancaster NY
  7. Nov 19, 2010 at 3:50 PM
    707tothe907
    Jake
    Chico NorCal
    05 DCSB Off Road
    Wow... Good job on the thread revival Drewboto.
