Custom vehicle harnesses made to order
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by daveeasa, May 25, 2021.
  1. Sep 25, 2021 at 10:24 AM
    #281
    The Pirate
    The Pirate Takoyaki Takoma
    So will I just need to insert one pinned wire and then run it through the firewall?
  2. Sep 25, 2021 at 10:25 AM
    #282
    daveeasa
    daveeasa [OP] FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Well, do you have puddles?
    if so you could grab parking from that harness and DRL from a pin
    or I can do what I did for ktbell and do a T harness to steal DRL and park as white and red just like the halogen tap does.
  3. Sep 25, 2021 at 1:28 PM
    #283
    NJOffRoad
    NJOffRoad Well-Known Member
    Anthony
    Pine Barrens, NJ
    2021 Cement TRD OR 4x4
    -Off-Grid Engineering Dual Battery system with Redarc BCDC1225D and Full Throttle Group 35 AGM -SPOD BantamX -Expedition Essentials 3TPAM -Spiker Engineering hood struts -Taco Vinyl raptor grill -Baja Designs Squadron Sport fogs -Baja Designs Squadron Pro ditch lights -KC Cyclones under-hood lights -ARB Twin Compressor -Mobtown Offroad Skids & Sliders -Diamondback Tonneau Cover
    Am I reading this correctly... You make a DRL T-harness that goes plug&play behind the headlight? One that I could connect my raptor lights to and remove my add-a-fuse currently powering them? That would allow me to go full stealth and control grill lights with the steering wheel stalk and not have to splice my factory wiring. Id buy that immediately for my 2021 with factory LED headlights.
    Edit: Just saw your dedicated thread and I'm ordering. My bad for posting before I found it!
  4. Sep 25, 2021 at 2:17 PM
    #284
    daveeasa
    David
    PNW
    All good, I appreciate the train of thought for others’ clarity. I don’t do a great job of explaining things.
  5. Sep 25, 2021 at 4:36 PM
    #285
    The Pirate
    No I don’t have puddles. But what if I just attached the DRL to the bright wire and didn’t dim the MESO lights?
  6. Sep 25, 2021 at 4:47 PM
    #286
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
  7. Sep 25, 2021 at 4:54 PM
    #287
    caribe makaira
    Caribbean, Puerto Rico
    Grab fused IGN power at the door then, no running wire to door-firewall...
  8. Sep 25, 2021 at 6:03 PM
    #288
    daveeasa
    David
    PNW
    Ok, so two options:
    1. same as ktbell’s T tap except 4 positions since yours taps 4
    2. A new 4 position male pigtail with one branch for Switch-Pros and one for v5’s
    i guess it maybe depends if you’ve done the Switch-Pros install yet?
    The Pirate[QUOTED] likes this.
  9. Sep 25, 2021 at 6:12 PM
    #289
    caribe makaira
    There are few more...one very simple and available at the each door (if no "control" over Bright n Dim are required)
    The Pirate likes this.
  10. Sep 26, 2021 at 9:18 AM
    #290
    The Pirate
    No, I haven’t done the switchpros install yet. I am planning to do it this week.
  11. Sep 26, 2021 at 9:23 AM
    #291
    daveeasa
    David
    PNW
    K, if you want to wait I can send a new male 4 pin with feeds for both. That’s the simplest option. Cool?
  12. Sep 26, 2021 at 9:33 AM
    #292
    The Pirate
    That sounds like a good idea, but me get back to you. Thanks.
  13. Sep 27, 2021 at 8:24 PM
    #293
    daveeasa
    David
    PNW
    Well, lucky lucky, @Empty_Lord and @Shadowhunter as it appears @Puppypunter has located 24 position GEP. This should streamline the harnesses and is just in time for me to get serious as winter is coming.
    Woohoo
    Shadowhunter and Empty_Lord like this.
  14. Sep 27, 2021 at 8:26 PM
    #294
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    PM me all the details and we can discuss layout that will work between both trucks (since our trucks are very similar but different in ways
  15. Sep 29, 2021 at 11:41 AM
    #295
    The Pirate
    Yes, let’s do this. I can send you the other one back to make a harness for someone else if you want as well.
  16. Sep 29, 2021 at 11:43 AM
    #296
    daveeasa
    David
    PNW
    I think just keep it for now? It’s worth about as much as the postage so not much point in sending.
    me remembering to do this is now the problem.
  17. Sep 29, 2021 at 11:44 AM
    #297
    The Pirate
    Awesome, thank you.
  18. Sep 30, 2021 at 1:06 PM
    #298
    daveeasa
    David
    PNW
    No actual progress on any of these yet. Hopefully soon once I’ve come up for air from the LED T taps.
    also + ECT extension for
    @TahKo
  19. Sep 30, 2021 at 6:50 PM
    #299
    daveeasa
    David
    PNW
    And look what arrived today. @Empty_Lord and @Shadowhunter there are officially zero excuses remaining for your goodies. I hope to start tomorrow if I clear the board on orders tonight.
    Empty_Lord likes this.
  20. Sep 30, 2021 at 7:34 PM
    #300
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Sweet! I can’t wait!
