Custom vehicle harnesses made to order
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by daveeasa, May 25, 2021.
  1. Sep 30, 2021 at 7:54 PM
    #301
    daveeasa
    daveeasa [OP] FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Work list in rough order, I might mixy mixy a little bit:
    1. 24 position GEP pos switched headlight harness for @Shadowhunter
    2. 24 position GEP neg switched headlight & horny harness for @Empty_Lord
    3. Rock light harness with bed light trigger for @Dean62 for 10 cyclones
    4. ECT extension harness for @TahKo (need length estimate or go with 45" as we've done in the past?)
    5. AMP 3-position Y splitter + grille light harness for @AbnMP13
    6. Light bar harness for @DaddyRy19 with design tbd
    7. Bumper harness for @Formidable with design a little tbd
    AbnMP13 and Shadowhunter like this.
  2. Sep 30, 2021 at 10:21 PM
    #302
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Schweet
  3. Sep 30, 2021 at 10:22 PM
    #303
    Empty_Lord
    Dan
    If you happen across a 2 pin weatherproof connector small enough to fit through a 1/2” circle. Let me know. I need one for my 3rd brake light
  4. Sep 30, 2021 at 10:29 PM
    #304
    daveeasa
    David
    PNW
    @kmorgan3 has the skinny on the vled ones but not 100% sure we confirmed they are sub 0.5" ?
  5. Oct 2, 2021 at 12:22 AM
    #305
    daveeasa
    David
    PNW
    Got a bit of a start on @Empty_Lord and @Shadowhunter ’s projects since the fat GEPs arrived this week. I think I have most of the layout squared away. Triggers next and then it’s just a matter of the output feeds.
    @Shadowhunter you may want to start thinking about mounting locations as I stuffed the fuses inside the GEP which means it has to be within 18” of the battery post. For @Empty_Lord ’s setup I had to use an external fuse pack. I am curious how that part will play out but for now I’m filing it under not my problem :)
    12980F9F-F71C-49C5-B82A-EA5A59AC01EF.jpg FD0C8690-0989-4CD2-8ADF-A6534C80B83A.jpg 5CA7C304-C1DE-4558-855B-6F99376A17B9.jpg F4EBAAAA-B6C6-4D78-8BCD-3532ECA4451C.jpg 7D3EE62C-745A-47E0-9371-0F31539CFEE5.jpg 6EF9CB65-9F9F-466F-B294-2B2582717173.jpg ECD9BB0A-0872-46BA-96B6-DF830915DF74.jpg 2284D722-C7A4-4B89-8953-0EFB96E6A79C.jpg
    my personal plan on the fuse side may be to employ the aid of MRBF fuses. I rather like them.
    Shadowhunter and Empty_Lord like this.
  6. Oct 2, 2021 at 1:31 AM
    #306
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    I can make it happen. I have a hammer, vice, drill and sheet metal. I can bend something to stick it on.
    daveeasa[QUOTED][OP] likes this.
  7. Oct 2, 2021 at 4:53 AM
    #307
    AbnMP13
    AbnMP13 Well-Known Member
    Shelby
    2020 TRD Crew Long Bed
    Sleeping on the job. That Pup needs a TREAT!
  8. Oct 2, 2021 at 5:02 AM
    #308
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Amateur… all you need is Duck Tape and Bailing Wire.
    EDIT: Yes, I know it’s Duct, but the young-uns know it better by the brand, which made it into the vernacular like Kleenex or Xerox with their fashion line.
  9. Oct 2, 2021 at 5:14 AM
    #309
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    I noticed that too… it’s probably hard for him to keep up… Dave expects him to do twice the crimping.
  10. Oct 2, 2021 at 6:28 PM
    #310
    NJOffRoad
    NJOffRoad Well-Known Member
    Anthony
    Pine Barrens, NJ
    2021 Cement TRD OR 4x4
    -Off-Grid Engineering Dual Battery system with Redarc BCDC1225D and Full Throttle Group 35 AGM -SPOD BantamX -Expedition Essentials 3TPAM -Spiker Engineering hood struts -Taco Vinyl raptor grill -Baja Designs Squadron Sport fogs -Baja Designs Squadron Pro ditch lights -KC Cyclones under-hood lights -ARB Twin Compressor -Mobtown Offroad Skids & Sliders -Diamondback Tonneau Cover
    I received my harness in the mail today and I've got to say, Dave does some quality work. The thing is super solid and feels durable. I am very satisfied with the purchase and highly recommend his custom harnesses to others! I can finally clean up the only wiring I don't like in my truck by ditching the add a fuse.
  11. Oct 2, 2021 at 7:11 PM
    #311
    daveeasa
    David
    PNW
    Kimo the dog is the supervisor. Sometimes he will run in his sleep if he thinks I made a bad crimp.
    Thanks! I am sure most will read this as utter BS but it's the genuine truth, I do what I do in pursuit of that which you've described. Not necessarily the words themselves, but knowing (or at least hoping) that I'm able to contribute towards a build that someone takes pride in. In the end it's all just stuff, but at the same time there's something rather pure about getting an inanimate object dialed in to serve a goal. That intangible feeling of satisfaction, it's just so damn elusive. I definitely do not get anything close to that feeling from parenting :)
    For tonight I'm wrapping up a quick T for @SkyDivinTaco (shaka) and I'm going to attempt my first Tundra DIR for my running pal who has a 2016 and doesn't know he needs one yet :)
    Then maybe tomorrow back into the headlight harness stuff, unless I feel like chipping away at that a bit more tonight.
  12. Oct 2, 2021 at 10:06 PM
    #312
    daveeasa
    David
    PNW
    Baby’s first Tundra DIR. The extra jumpers don’t make it extra fun really.
    JFanaselle and The Pirate like this.
  13. Oct 3, 2021 at 9:53 PM
    #313
    daveeasa
    David
    PNW
    @AbnMP13 I skipped the line for yours just to get something out the door.
    AbnMP13 likes this.
  14. Oct 4, 2021 at 10:08 AM
    #314
    boulderoffroader
    boulderoffroader Well-Known Member
    Colorado
    2018 TRD Pro
    Just wanted to add my two cents to this thread and extoll the virtues of Dave and his harness expertise.
    I spent Saturday installing the 2020 OEM LED headlights and Meso V5 turn signals, and I can safely say that I still wouldn't be done were it not for @daveeasa and his products.
    Having the V5 DRL connector already integrated made things soooooo damn easy. And he responded to my DM's on the few issues I had (my own stupidity with flipped connectors).
    This may be understatement of the year, but you can buy from Dave with confidence that you are getting quality stuff. And he's a good dude to boot.
    JDSmith, AbnMP13 and JFanaselle like this.
  15. Oct 4, 2021 at 10:16 AM
    #315
    parel
    parel Well-Known Member
    Kin
    Calgary, AB
    (ex. 2014 Black Tacoma TRD)
    OEM FJ TRIBUTE EDITION (REPLICA)
    Do you crimp and then solder? Have you made a backup Light harness for crashnburn? Do you think it’s safe to worry that the taillight circuit wires run too hot with 2x35w bulbs? What’s the airspeed of an unladen swallow in flight? Will I ever find love?
  16. Oct 4, 2021 at 10:29 AM
    #316
    daveeasa
    David
    PNW
    1. No, solder first then crimp.
    1a. Shaken, not stirred
    2. No, but one day I hope to have something made which goes on his truck. That would be my crowning achievement, a Christmas gift for for the man who has everything.
    3. I like to worry about everything but I'm not sure worrying is safe, thread safe (computer joke) or important enough to lock in a safe (rich guy joke).
    4. African or European?
    5. There is no such thing.
  17. Oct 4, 2021 at 10:34 AM
    #317
    parel
    Kin
    Calgary, AB
    Lol, nice. I used to make OBD0-OBD1 conversion harnesses for Honda’s way back in the day. Tedious work… I’ll probably hit you up when I figure out something to harness up.
  18. Oct 8, 2021 at 2:53 PM
    #318
    daveeasa
    David
    PNW
    Work queue:
    3. Light bar harness for @DaddyRy19 with design tbd
    Completed / Ready for user acceptance testing (yay):
    1. Rock light harness with bed light trigger for @Dean62 for 10 cyclones
    2. AMP 3-position Y splitter + grille light harness for @AbnMP13
    3. Bumper harness for @Formidable with design a little tbd
    4. DIR for @TahKo
    Canceled (available elsewhere):
    1. ECT extension harness for @TahKo (need length estimate or go with 45" as we've done in the past?)
    And, I'm off to haul horsies Sat - Mon so no progress expected. I'll probably have a bunch of OG product to dish out when I return but from there the road to headlight nirvana seems paved with butter smooth asphalt.
    AbnMP13 likes this.
  19. Oct 8, 2021 at 6:52 PM
    #319
    The Pirate
    The Pirate Takoyaki Takoma
    8A53F452-D4E0-4E38-9741-4DAE17A60388.jpg This looks awesome, pink/white to the switchpros and red/white to the MESO V5’s. Thank you Dave!!! Hopefully I’ll get a couple days off work next week so I can install everything.
    daveeasa[OP] likes this.
  20. Oct 13, 2021 at 12:37 AM
    #320
    daveeasa
    David
    PNW
    Now that I’ve returned it looks like I’m behind on a few things which I’ll need to catch up on over the next few days.
    1 DIR
    4 headlight conversion harnesses
    1 LED T tap
    Shadowhunter likes this.
