Custom vehicle harnesses made to order
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by daveeasa, May 25, 2021.
  1. Jun 4, 2021 at 7:35 AM
    daveeasa
    daveeasa [OP] FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    JFanaselle, Zumozuzu7 and RyanDCLB like this.
  2. Jun 7, 2021 at 9:32 PM
    daveeasa
    David
    PNW
    I received the wire I need to finish up harnesses for @ljh824, @RyanDCLB and @JJD92 today.
    I also went to my first Jiu Jitsu class so I’m beat. And I have a 5am call tomorrow. So I hope to finish tomorrow night and ship out on Wednesday. I know it’s been a long wait.
    Here is where Lou’s harness stands.
    ljh824 and RyanDCLB like this.
  3. Jun 9, 2021 at 6:36 AM
    daveeasa
    David
    PNW
    More progress on Lou’s harness. @Puppypunter how does it look? I think your relay is the last little cherry on top, unless you see something. The Y between input power, GEP and output feed could be a little cleaner but other than more tape I’m not sure what to do with that.
    JFanaselle, Zumozuzu7 and ljh824 like this.
  4. Jun 9, 2021 at 12:28 PM
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    There's something to be said for some high-quality wiring. Quite...invigorating.
  5. Jun 9, 2021 at 1:29 PM
    ljh824
    ljh824 Regular Guy
    Lou
    Kabul, Afghanistan / Oviedo, Florida
    -21 AG Sport 4x4 DC
    Concur. It's like a work of art!!
    CAG Gonzo[QUOTED] likes this.
  6. Jun 9, 2021 at 2:18 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Check out this post! :eek:
  7. Jun 9, 2021 at 3:04 PM
    CAG Gonzo
    2018 OR DCLB BarRed
    Holy mother of panels. That is slick.
  8. Jun 12, 2021 at 12:37 AM
    JJD92
    JJD92 Well-Known Member
    JORGE
    Springfield, MA
    2020 TRD OR DCSB
    Dave,
    Thanks, got my stuff. This is going to be a clean install, love it.
    daveeasa[OP] likes this.
  9. Jun 12, 2021 at 3:41 AM
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    Thanks for all your hard work!!
  10. Jun 21, 2021 at 12:09 AM
    daveeasa
    David
    PNW
    Working through a repeat of @ljh824’s harness, this time intended for @Zumozuzu7. Effectively exactly the same, just a different output connector and I’m still waiting to hear on whether I need a halogen DRL tap or LED DRL tap.
    Inventory:
    1. GEP 12 position enclosure
    2. Omron relays, one SPST and one SPDT
    3. Amp male 2 position DRL trigger 24”
    4. 14 gauge power input 36”
    5. 14 gauge 3 conductor output 84”
    6. 18 gauge LED trigger 84”
    7. Cargo rocker T harness with JAE switch plug for LED trigger
  11. Jun 26, 2021 at 11:24 PM
    daveeasa
    David
    PNW
    The @Zumozuzu7 harness is nearly done. I’m just waiting on some 10 gauge weatherpack terminals so I can marry up the output leads since we have to go 1x14 gauge to 2x16.
    I’m going to start inventorying all the parts used, this one was a big one.
  12. Jun 28, 2021 at 2:04 PM
    Jeff Dartfrog
    Jeff Dartfrog Well-Known Member
    Jeff
    Chandler AZ
    2019 Cavalry Blue TRD Off Road
    Hey Dave, I have enjoyed viewing your handiwork – keep up the good work!! I just upgraded to a 2019 TRD OR 4WD from a 2018 TRD OR 2WD. I had rapture lights on that vehicle. If I recall correctly, I did some sort of vampire tap into the purple & white wires on the side marker light to have them activate with the running lights or when the headlights were on. I want to add the same simple lights to the new truck but want to avoid these type of splicing connections on this truck. Do you have a plug-n-play harness with a 2-wire connection that I could attach the aforementioned rapture light to? Something similar to the picture but with a 2-wire "t" that would take the place of me hacking into the side marker wire & associated ground wire.
    Pic borrowed from @Puppypunter
  13. Jun 28, 2021 at 2:49 PM
    daveeasa
    David
    PNW
    Do you have LED headlights or halogen.
    I can do either but R4T also makes a DRL plug and play harness for halogen trucks.
    45C8991B-B045-4A27-B992-C5ED382566DC.jpg 3AB5D4C5-1215-4C82-B8EE-A2A4E22C9688.jpg
  14. Jun 28, 2021 at 3:31 PM
    Jeff Dartfrog
    Jeff
    Chandler AZ
    I think the DRLs are LED but I’m pretty sure the headlights are H11 or H9 bulbs
  15. Jun 28, 2021 at 3:40 PM
    #35
    daveeasa
    David
    PNW
  16. Jun 28, 2021 at 6:07 PM
    #36
    Jeff Dartfrog
    Jeff
    Chandler AZ
    Thank you. Do you know the brand - manufacturer of the waterproof connector is that they’re using?
  17. Jun 28, 2021 at 6:27 PM
    #37
    daveeasa
    David
    PNW
    Amp 2 pin female at the T, male on the light harness input. The white ones I don’t know but they sort of lock you in to those specific grille lights. The eBay ones I buy are amp on the light side too.
    Amp pigtails are super easy to find on eBay. I include them with my stuff and two heat shrink solderless butt connectors (see photos above.)
    #37
  18. Jun 28, 2021 at 6:41 PM
    #38
    Jeff Dartfrog
    Jeff
    Chandler AZ
    Awesome thanks. One last question. Are the amp connectors difficult to unpin? I would want to re-pin the cable coming off of the raptor light harness to attach to the R4T harness.
  19. Jun 28, 2021 at 7:03 PM
    #39
    daveeasa
    David
    PNW
    So the ebay lights I have are bare wire. Photo of yours?
    De-pinning a 2 pin male AMP I consider an act of congress (hard). Ironically, depinning the female is very straightforward. I suspect if I had a "just-right" tool maybe it'd be a different story? The R4T harness he gives you has the male on the 1-4 main trunk so de-pinning that would be the "hard" one. But if you're removing something which isn't an AMP to cut and pin to an AMP or just solder into the R4T you are going to cut off then that's easy.
    De-pinning doesn't make any sense unless you intend to put on the same type of connector (say going 2-3 positions on an AMP or something). The terminals are specific to the connector so you can't really de-pin and change connector types, you have to cut off and re-crimp.
    However, eBay has easy AMP pigtails which would eliminate any need to slice up the $49 R4T pieces.
    Now, to the un-asked question of would I build these for people, I think the answer is I'm ok with it in small quantities if we don't undercut someone else. So, I'm OK selling OEM LED conversion harnesses at Mike's price of $85 if done in low numbers because I don't think that takes away from his business in any significant form. Similarly I'll do a DRL grille light harness for $49 since that shouldn't take any bite out of R4T's sales provided numbers are small. And for the stuff I'm making I can customize a little bit. So, say you wanted to send me your harness, I can build it clean for you and send it back ready to rock. Stuff like that probably makes some sense.
    I just struggle with the ethics of selling something you can get elsewhere from a reputable vendor who does good work. If the only options were total garbage or extremely overpriced it might be one thing but anything in the reasonable price range and of good quality I don't want to undercut.
    Also, I'm particularly sensitive since MESO had a hand in the design and Stewie does more in a day than I do in a year so I tread super lightly.
    Hopefully that backstory adds some color?
    #39
  20. Jun 28, 2021 at 7:48 PM
    #40
    Jeff Dartfrog
    Jeff
    Chandler AZ
    I understand completely. That being said, I’d happily pay you $49 for a DRL grille light harness. The harness for the lights I will be using is just 2 wires - red & black. So, if the harness could include a pigtail for me to solder to my lights that would be great. Let me know if you’re comfortable with that.
    thanks Dave
