cutting the exhaust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Jun 6, 2010.
  1. Jun 6, 2010 at 5:15 PM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    does cutting off the exhaust at the axle make a sound difference, on a stock muffler :confused:
  2. Jun 6, 2010 at 7:13 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I have mine cut over the axle. No difference. I've heard some have said cutting it before the axle increases the sound in the cab a bit.
  3. Jun 6, 2010 at 8:18 PM
    gcwaterski
    gcwaterski Well-Known Member
    No difference for me in or out the cab. I love it! No more soot on the side of the truck....
  4. Jun 6, 2010 at 8:26 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    what about cut at the axle with a magna flow?:cool:
  5. Jun 6, 2010 at 11:46 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    215,000 and counting
    Can't speak for a magnaflow but I did a dynomax with a dump before the axle and I'm happy with that set up. Good sound under normal driving and you can hear it with spirited driving sessions
  6. Jun 7, 2010 at 5:38 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    No, no real change, maybe a hair deeper. Modding the intake did way more for noise then that. But its not like I was doing it for sound. I just hated looking at a rusting exhaust tip.
  7. Jun 7, 2010 at 5:42 AM
    KPT
    09 Prerunner
    Mines a magnaflow, but cut after the axle.
  8. Jun 7, 2010 at 6:40 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    What about heat issues or condensation issues on the under side of the bed or on the axle from doing this? That's probably the only thing keeping me from doing it.
  9. Jun 7, 2010 at 8:18 AM
    flightcancled
    I would think that the in terms of latent heat the pipe would get the spare hotter then the exhaust which is instantly whisked away while driving. The exhaust is cooled rapidly by the air even while standing still.
  10. Jun 7, 2010 at 9:14 AM
    lazaro
    lazaro Well-Known Member
    Garry
    Chesterfield, Virginia
    2010 DC BSP 4X4 TRD Off-road
    Stainless Nfab Steps painted black, Acces Tonneau cover, LED dome and map lights, Weathertech floor mats, EGR slimline visors, Wicked Flow 13 mufflers, ultragauge and 4X4 illuminated switch mod, receiver shackle from Timichi and Redline QL plus hood struts.
    I was thinking of dumping/cutting the exhaust pipe on my 3 month old magnaflow. It seems that there are times that the deep sound comes and goes. What I mean is there are times that the sound is not as deep at times especially if the outside temp is not warm. If its a warm day I noticed that is when the sound is rich and deep/mellow. Have you guys with magnaflow experienced any of these? I have a 5X8X18 OC 2.5 pipes in and out welded.
    Now I have a Wicked Flow 13SC250 coming in on Wednesday. I might have it swapped once I have a day off (good luck with that).
    Any experience you would like to share from guys w/magnaflow? Thanks
  11. Jun 7, 2010 at 9:19 AM
    KPT
    09 Prerunner
    My magnaflow volume changed drastically depending on the RPM's, and had an annoying drone at some RPM's. I dumped it after the axle, and the change in the weight of the system altered the resonance frequency enough that the drone was gone, and the system sounded much better. Sounds crazy I know....
  12. Jun 7, 2010 at 9:36 AM
    lazaro
    Garry
    Thanks for the response, I appreciate it. It looked over your build, man your truck is very clean looking. I looked at how the exhaust tip does not show in the back. I never realized how slick looking the truck looks w/o the exhaust tip. :drool:
    If you have any pics of your exhaust dumped/cut I would really appreciate it man. There are times I just want to take a cutting wheel and just cut it my self. Alas! My balls are not made of brass.:(
  13. Jun 7, 2010 at 9:52 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    I dumped mine at the axle and it is a bit louder. Just take a sawzall to it and will only take about 5 minutes. It is super easy.
  14. Jun 7, 2010 at 10:35 AM
    KPT
    09 Prerunner
    Thanks. I don't have any pics of it dumped.. It's cut in the exact same place that SecretSquirrel posted. I could take some pictures tonight if you want.
  15. Jun 7, 2010 at 10:44 AM
    lazaro
    Garry
    Thank you KPT. :D
    The drone you were talking about, is it the humming sound that could be heard at certain RPMs and gear? I hear something but to me it sounded more like a purrr, reminding you the exhaust is there for you.
    I am thinking the drone is a resonating sound affecting the cabin, like the metal body somehow sonically vibrates.
    The bottom line is I just want to "consistently (in a good way) " hear the mellow, deep, throaty sound these exhaust do.
  16. Jun 7, 2010 at 10:52 AM
    lazaro
    Garry
    kinkrider, what size manaflow you got?
  17. Jun 7, 2010 at 10:58 AM
    KPT
    09 Prerunner
    The drone I was talking about was loud enough that it actually felt like it was rattling my brain around in my skull :D.
  18. Jun 7, 2010 at 10:59 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Getta Flow Master Super 44 and then chop it...sounds beast IMO :eek:
  19. Jun 7, 2010 at 11:02 AM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    so if cutting it doesnt make any sound difference then how do people get the LOUD fart sound without upgrading the exhaust.
    my friend billy has a 4banger taco he cut the exhaust, you can hear that thing from a mile away
  20. Jun 7, 2010 at 11:10 AM
    KPT
    09 Prerunner
    He must have a cutout before the muffler. We're talking about cutting it after the muffler, so you can't see the tailpipe.
