Cv axle boots busting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08FireRescueTaco, Jul 31, 2015.
  1. Jul 31, 2015 at 10:22 AM
    08FireRescueTaco
    08FireRescueTaco [OP] 08Blue_Beast
    Hunter
    Roanoke
    08 Tacoma Manual 6spd
    2008 off road 6spd manual Procomp stg 1 6in lift Allpro hd expo leaf pack 16in fuel boost wheels 315/75r16 motto trail grapples Flomaster duel 40s exhaust Doug Thorley LTH Volant CAI Relentlessfab front bumper Fox 2.0 coilovers Prinsu designs roof rack Sport hood Urd short shifter Nfab side steps Bushwacker flares
    I have a 2008 Tacoma V6 4x4 I put a pro comp sage 1 6in lift on in October of 2013. In June of this year my driver side cv boot busted when I replaced it I noticed my passenger side did the same but looked to be dry rotted due to age so both were replaced a week apart. A week went by and I noticed the driver side had grease all over it again and it had torn so again I replace it (#2) also 3 day after that the passenger side AGAIN BUSTED. I'm about to be on my 3rd set of cv axles I need an inspection but dot wanna replace them again if they are just gonna keep busting. I don't know why this keeps happening my buddy works at an auto shop and suggested that the hight is why and every time I turn the wheels it's stressing the boots and causing them to bust. Does anybody have a solution to help me out???
  2. Jul 31, 2015 at 11:21 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    high CV angles wil do that.
  3. Jul 31, 2015 at 11:32 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Do you have any pictures of your setup?
  4. Jul 31, 2015 at 1:06 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Can you put on a front differential drop kit or does your suspension setup not allow that? I know there are guys getting the CV's done about once every 6 months, but a week is just ridiculous.
  5. Jul 31, 2015 at 6:09 PM
    08FireRescueTaco
    Hunter
    Roanoke
    im having issues posting photos i will do so as soon as i can. these are busting weird like i said the passenger side looked like a pen hole and the driver side was torn right where the boot met the shaft and the metal ring was put on to secure it. ill post photos when i get it working
  6. Jul 31, 2015 at 6:37 PM
    akamrkent
    akamrkent Well-Known Member
    Kent
    San Jose
    2004 Black Tacoma TRD
    Homemade Bumper and Skid plate, OME lift, Powertrax auto locker(front dif) and a Leer Shell
    Like Nighthawk said, a diff drop kit will help a little if it hasn't been done yet. The Pin hole could of come from over extension during installation. If the tulip bearings get pulled out of their bearing race(this is the inner cylinder that slides into the diff. Not sure of the correct name) the baffles of the boot can get pinched between the bearing and race.
    I did a DIY high angle boot build that incorporated the boot slide mod, that might help.
    https://www.tacomaworld.com/threads/high-angle-inner-cv-boot-with-boot-slide-mod.382314/
    https://www.tacomaworld.com/threads/boot-slide-mod-no-more-blowing-cv-boots.146070/
    One thing to help boot ware on higher angle applications is extending the boots down the shaft just enough so at normal ride height, the baffles aren't rubbing. Also making sure that the boots are not under negative air pressure as well.
  7. Jul 31, 2015 at 6:42 PM
    08FireRescueTaco
    Hunter
    Roanoke
    the first link is how i learned to take the axle in and out helped out a lot. i guess im gonna have to try the mod next....
