CV Axle oil seal LH vs RH?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by swiftjames, Jan 29, 2023.
  1. Jan 29, 2023 at 6:38 PM
    swiftjames
    swiftjames [OP] Member
    Hey all--
    I spent the weekend pulling my CV axles and rebooting them. I bought two oil seals part#9031147026 (41304P in diagram). When I pulled the passenger side though, the seal is completely different. From a previous thread (https://www.tacomaworld.com/threads/cv-axle-seal.427102/page-2) this part looks to be #90311-47013. But when I put that part number in the toyota parts site, it comes up as non compatible with my 2015 Tacoma 4.0L M/T 4WD EXTRA CAB. Is the parts diagram wrong? I bought my truck used--does this mean someone swapped out the housing that the passenger side CV axle goes into?
    Thanks!
  2. Jan 29, 2023 at 7:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Here is what I get for a 2015.
    No idea why the #s are different for 2015.
  3. Jan 29, 2023 at 7:46 PM
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x3
    Here are current part numbers for stock '05, should be the same unless prior owner changed the front diff somehow.
    90311-47027 is driver
    90311-47013 is passenger
    Might have these mixed up but these are the two!
    I would order a spare of each. Easy to drive them in too far. Or mangle them. There are specific depths for driving each--too far will leak.
    Good luck!
  4. Jan 29, 2023 at 8:23 PM
    TnShooter
    Deogee
    STOCK
    @Jeff Lange
    Anyway you can verify what one fits the 2015 models?
  5. Jan 29, 2023 at 8:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Interesting
    Those are the part numbers in my sig for a 1st Gen Taco/3rd Gen 4R
    Didn't realize they were the same for a 2nd Gen Taco
  6. Jan 29, 2023 at 8:55 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    One pops into the side shaft of the differential and the other goes into an ADD tube, they are different parts. The part #s for a 2015 will be the same for an 05
  7. Jan 29, 2023 at 9:06 PM
    TnShooter
    Deogee
    STOCK
    Thanks.
    I looked the parts up on Toyota and sure enough, as OP said, they only list the 2005-2014.
    They must have forgotten to add 2015.
  8. Jan 30, 2023 at 4:29 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The actual answer lies in which plant produced the differential itself, as there were different part numbers depending on the supplier. Frequently in cases like that one will be chosen as the prime after-sales supplier and the other will be replaced in the parts supply system. That sometimes happens right away, sometimes happens later while the vehicle is still in production, sometimes after production ends, and sometimes it never does.
    The answer is that they're all interchangeable, but here are the actual part numbers and what is supplied by Toyota in North America:
    90311-47010 - RH for 1995-2004 (Replaced by 90311-47013)
    90311-47011 - LH for 1995-2004 (Replaced by 90311-47027)
    90311-47012 - LH for all 2005-2010 and early 2011, and some 2011-2013 trucks from April 2011 production (Replaced by 90311-47027)
    90311-47013 - RH for all 2005-2010 and early 2011, and some 2011-2013 trucks from April 2011 production
    90311-47020 - LH for some 2011-2013 trucks from April 2011 production (Replaced by 90311-47027)
    90311-47021 - RH for some 2011-2013 trucks from April 2011 production (Replaced by 90311-47026)
    90311-47026 - RH for all 2014-2023
    90311-47027 - LH for all 2014-2023
    So to answer your question, 90311-47026 and 90311-47027 are the correct seals for your 2015 Tacoma, and will fit any Tacoma from 1995-2023.
    Jeff
  9. Jan 30, 2023 at 4:45 PM
    TnShooter
    Deogee
    STOCK
    Now that is a detailed parts list. :eek:
    Thank you sir.
  10. Jan 30, 2023 at 5:16 PM
    swiftjames
    TnShooter likes this.
  11. Jan 30, 2023 at 6:24 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    the snap rings hold the half shaft in the add tube. They aren’t outside the oil seal but that’s just how they drew them.
  12. Jan 31, 2023 at 9:09 PM
    swiftjames
    TnShooter and 6 gearT444E like this.
  13. Feb 1, 2023 at 4:46 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Sub'd to recall part number list.
    Thanks
  14. May 22, 2024 at 9:24 AM
    sikTacos
    sikTacos Well-Known Member
    Eric
    SoCal
    2Gen Tacoma (DC/LB/4X4)
  15. May 22, 2024 at 9:41 AM
    TnShooter
    Deogee
    STOCK
    sikTacos[QUOTED] likes this.
  16. May 22, 2024 at 3:31 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Remember the driver's side will stop at a lip in the diff. It will be difficult to drive the seal in too far.
    Passenger side you will need to measure it. 5.5mm all the way around. That is why people recommend buying 2, in case you mess up and go too far. It will leak.
    deanosaurus likes this.
  17. Jul 7, 2024 at 3:34 PM
    jarpil
    jarpil Well-Known Member
    Kalaheo, HI
    2017 Tacoma TRD OR DCSB, black
  18. Jul 9, 2024 at 11:12 AM
    Jeff Lange
    Calgary, Canada
    jarpil likes this.
  19. Jul 9, 2024 at 10:04 PM
    jarpil
    Kalaheo, HI
  20. Jul 21, 2024 at 3:45 PM
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
