CV Axle Replacement ... express method!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roboots21, Mar 3, 2013.
  1. Mar 1, 2021 at 5:37 PM
    #101
    6 gearT444E
    Deep South
    Herculiner Hootus
    The clip is either distorted or it’s moving prior to install, if it faces open side down it will pop in with little effort.
  2. Mar 1, 2021 at 5:50 PM
    #102
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Well it’s done! My mechanic friend came by and as I started explaining my ordeal with him- he knelt down grabbed the cv and on the the very “FIRST” try slid it in like butter!! I nearly had a fuckin’ meltdown!!
    I was ready to smack the thing with a hammer. I guess there is a sweet spot and he just so luckily got it or I’m just an asshat lol. Thanks for your time gents.
    Crow Horse and 6 gearT444E like this.
  3. Jun 2, 2023 at 4:57 PM
    #103
    aktaco14
    aktaco14 New Member
    2014 Tacoma Sport 4x4
    Rigid Industries 20" E2 Light Bar Tekonsha Trailer Brake Controller Block/Battery Heater
    I spent 4 days on and off trying to find that sweet spot and finesse the stupid axle in. Toyota raised the price of the axle to $500 and I REALLY didn’t want to do something to mess it up. I think I watched every video and read every forum related to the dang thing. C clip down, lube, screwdriver and hammer on the divets…no joy. I was ready to light the dang thing on fire. Finally called my mechanic dad and he said to “use a bigger hammer.” Which is honestly his advice for most things. Haha
    Anyway, got a 3 foot pry bar and an 8 lb sledge. Set the pry bar in the divots on the housing and 3 taps later the axle was seated. Super easy.
  4. Aug 17, 2023 at 10:05 AM
    #104
    PlaynWithMyToy
    PlaynWithMyToy New Member
    2007 Red 4door 4x4
  5. Aug 17, 2023 at 10:07 AM
    #105
    PlaynWithMyToy
    2007 Red 4door 4x4
    Replaced my axels this AM. This worked like a charm. 07 tacoma. Glad I ran across this..
  6. Oct 19, 2023 at 4:12 PM
    #106
    SURFTACO
    SURFTACO Well-Known Member
    New Jersey
    09 TRD SPORT
    3'' Lift: Bilstein 5100’s, SPC UCAs, All Pro 3” leaf packs, Bilstein 5125’s, Kenda 33X10.5R17 Tires Flat Black Stock Rims Seat Belt Chime off Fog Lights On anytime Jet pilot interior All weather floor Mats Tonneau Cover Cali Raised Ditch Lights Snorkel
    Best way to do it. Just swapped them out today.
    No need to remove tie rod end, and sway bar link. Just the two 19 mm on the knuckle.
  7. Oct 19, 2023 at 5:03 PM
    #107
    awbrey50
    awbrey50 New Member
    2014 Tacoma TRD
    Bilstein 6112/5160|ECGS Bushing|285-70-17 Nitto Ridge Grapplers
    25 mins for everything but removing the axle itself. Took me like two hours to do that, lol.
  8. Oct 20, 2023 at 3:15 PM
    #108
    tyjoja
    tyjoja Well-Known Member
    Oregon
    2008 off road trd, Rugged Trail
    lift
    I'm sure its been said stock cv axles way better than most you can get... I got the stock boot kit and put those on my stock axles and never looked back so far. did the boot slide mod and my bands holding the boots on kept sliding off so got some good quality radiator clamps and tightened them till I thought they were going to break... still holding fine after couple years.
  9. Aug 26, 2024 at 11:14 AM
    #109
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    Old thread, but OP's steps worked fine for me. No need to disconnect tie-rods. It was a bit tricky to do it alone, lifted the knuckle, flipped it as much as I could (careful with ABS + brake cables as well as rear knuckle seal) and gently put the CV on the side on a jackstand as strait to it's entry point in the differential as possible, and added another jackstand under the knuckle. I would highly recommend being two for this. A few good taps with a chisel and hammer on the CV notch near the differential and it popped out easily. Same procedure to put the new one in. I replaced both CV axels and seals, as well as installed the ECGS bushing. After 150K miles with a few 10K miles on washboard laden gravel roads, I had A LOT of slop in my CV's. Not any more!
  10. Dec 6, 2024 at 6:37 PM
    #110
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    i read this whole thread and dread having to do this on a trail let alone my garage. mechanic did mine with warranty aftermaket on my 4runner a few times when i had torn boot. but i want to try it someday. need a second vehicle if economy ever improves
  11. Dec 7, 2024 at 4:37 AM
    #111
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Put a cv in 2 weeks ago
    Took 41/2 hrs
    I’ve done it before but never had to cut out the sway bar links
    Even after cutting both sides had trouble gettin piece out from sway bar
    Lucky for me auto zone had the end in stock
    Cv not leaking but boot ribs are rubbing wearing them down
    Wanted to change before it leaked and was middle of winter
    I have to try the boot slide mod
    Anyone ever do that?
  12. Dec 8, 2024 at 10:39 AM
    #112
    High Desert Taco
    High Desert Taco Well-Known Member
    Wyoming
    2012 Pyrite DCLB
    I have done this so many times. It takes 30 minutes to 3 hours depending on location and how recently it was done. If possible give yourself time for it to take longer, and if it is fighting you go have a cupa and a snack and come back. :)
    Rob MacRuger likes this.
  13. Feb 10, 2025 at 2:54 AM
    #113
    50huesofgreene
    50huesofgreene New Member
    B
    08 trd
    Bubble gum n duck tape
    In case anyone is looking for this in 2025...
    Lug nuts
    Wheel
    Dust cap
    Axle nut
    2 LCA bolts
    Cv shaft
    Reinstall reverse order. Ez pz. Don't over think it.
