Cv axle won't go in all the way
Discussion in '1st Gen. Tacomas (1995-2004)' started by Frazier314, Nov 16, 2016.
  1. Nov 16, 2016 at 1:09 PM
    Frazier314
    Frazier314 [OP] Member
    1996 Tacoma
    I recently swapped my front diff on my 96 Tacoma. Mine was an ADD and the used differential I bought came off a 98 with manual locking hubs. I swapped everything over got it back in, no issues. Passenger side cv slid right in with ease. Gave it tape and it went in completely.
    Now the driver side, I put it in, gave it a tap also but there's still a gap. Lifted her, threw it in 4wd and let the wheels spin and all 4 spun like normal. So it's obviously sittin in there fine, just not going in all the way and I'm slowing loosing gear oil from that gap.
    Anytime I try to hit it in, it almost feels as if it's just hitting a wall.
    I've pulled it out plenty of times, turned it and tried again but no luck. Everything looks fine from the c-clip to the splines.
    Anyone know what's going on?
  2. Nov 16, 2016 at 2:05 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Take the axle out and put some grease on the c-clip to help keep it in place. Now, with the opening of the c-clip pointing down, get it started on the splines. Grab a long pry bar or similar tool and rest the end on the flange of the inner joint. Strike the end of the tool with a hammer and knock it in. In the video below, watch between play time 53:40 to 55:00. This is the technique that worked for me to get the driver's side in but not the passenger side. In the video time between 53:40 to 55:00, I'm working on the passenger side. I was able to push the axle in just with arm strength on the passenger side.
    Also, start watching again at 1:17:30 to see how I check to make sure the axle is fulling seated.
    By the way, this is on a 2002 4runner but I imagine they are very similar.
    If the thought of pulling the axle out again isn't all that appealing, I'd try to pop it in from one position giving it a few whacks with a hammer and pry bar. If it doesn't go, rotate it a quarter of a turn and try a few more whacks. Hopefully you'll find the sweet spot and the mofo will finally pop in. Good Luck!
    <iframe width="560" height="315" src="https://www.youtube.com/embed/vcCT4UgFUTw" frameborder="0" allowfullscreen></iframe>
    CBrob likes this.
  3. Nov 16, 2016 at 2:31 PM
    Frazier314
    1996 Tacoma
    Weird. I've read many posts of people saying the c-clip opening should be facing up. Not down..
    Maybe that's my biggest issue. Sure hope so
  4. Nov 16, 2016 at 5:00 PM
    Timmah!
    TIM
    The FSM definitely suggests having the opening of the c-clip facing down.
  5. Nov 16, 2016 at 9:33 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Dab the clip with grease and try to keep it from sticking out one side or the other and then put it in. Smack the end of the axle with a rubber mallet.
    Clucky likes this.
  6. Nov 17, 2016 at 1:39 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    These axles were in or out when you bought the complete set up??
    I have heard of different length axles .
    ADD CV axles and locking hub axles are quite different if your trying to use your ADD axles
  7. Nov 18, 2016 at 12:47 AM
    Frazier314
    1996 Tacoma
    I just bought the clamshell.
    So I'm re-using my old cvs from my ADD.
    But if that were the case, why would the passenger side sit normal?
  8. Nov 18, 2016 at 10:05 AM
    jaunty
    jaunty Well-Known Member
    99 V6 TRD Automatic 4x4
    just double check the one you're trying to fit is exactly the same size. I bought one once that wouldn't go all the way in because it was about 1/4" too LONG! There I was bashing on it for a few days.
  9. Nov 18, 2016 at 1:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Compare the tube length on the passenger side of the clamshell to verify that tube is the same length between your original and the new clamshell.
  10. Nov 18, 2016 at 4:34 PM
    Frazier314
    1996 Tacoma
    So I took off the c-clip from the axle to see if the c clip was the problem but even without the c-clip it hits and isn't sitting all the way in.
    So I'm assuming the Cv axle is slightly too long.
    Anyone know where I can get something a little shorter?
    Need help ASAP! Gotta get my truck back before the weekend is over
  11. Nov 19, 2016 at 7:55 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    No actual experience here, but ....
    It sounds like your problem may be due to trying to use an ADD CV axle with the non-ADD clam shell.
    According to the RockAuto web-site the ADD axles are about 3/32" longer (compressed length) than the non-ADD axles.
    I don't know where the difference in length comes from, but it could be in the stub that goes into the diff.
  12. Nov 19, 2016 at 10:20 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This is true.
    But this is odd as manual cvs are shorter. So if anything he should be having issues binding. Not a gap.
    OP: did you swap the ADD tube over as well? I would hope you did.
    Are the cv axles OEM?
  13. Nov 19, 2016 at 4:33 PM
    Frazier314
    1996 Tacoma
    Yes sir I did. I had to swap the tube over in order to get the vaccum lines back.
    So anyone have a way to find the right cvs?
  14. Nov 20, 2016 at 1:08 PM
    Frazier314
    1996 Tacoma
    Oh yea, I also forgot to mention it has a lock right locker in it. Not sure if that could possibly have anything to do with it.
  15. Nov 20, 2016 at 4:32 PM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Contact the locker Mfg. Tell them your story. They might have a oh yeah moment to share.
    Check your loss with a ruler if you can first. Compare axles at Napa or a junkyard. Get what you need.
  16. Nov 21, 2016 at 12:49 PM
    Frazier314
    1996 Tacoma
    Thanks! All look into all of it as soon as I can
  17. Jan 21, 2020 at 3:26 PM
    Falkor1
    Falkor1 Well-Known Member
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    2,000 Tacoma rear axle with E-Locker.
    What was the solution to this problem?
  18. Aug 22, 2020 at 10:52 AM
    jaywill808
    jaywill808 Well-Known Member
    2001 Tacoma
    I too am interested... mine is currently stuck on the last 1/4"
  19. Aug 23, 2020 at 9:23 AM
    camwb72
    camwb72 New Member
    Cam
    O1 Tacoma 4x4
    Super charged
    I’m stuck on this too, my drivers side has a 1/4” gap and is just about shot
  20. Aug 23, 2020 at 9:59 AM
    jaywill808
    2001 Tacoma
