CV Axle ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tjgraner09, Feb 28, 2009.
  1. Feb 28, 2009 at 2:33 PM
    tjgraner09
    tjgraner09 [OP] South Carolina Member
    TJ
    Conway, SC
    97 XtraCab
    Bilstiein 5100 w/ TRD Coils in the front, new fog lights, 2 12" isignia subs,
    So i went to get my cv's today and the guy at advanced asked me if i had automatic disconnect or no? I was like WTF i dont know what that is so can some one it explain it to me please. Also i have a 97 tacoma 4x4 and manual hubs...
  2. Feb 28, 2009 at 2:54 PM
    jwscoot
    jwscoot Well-Known Member
    Mississauga, ON
    98 Tacoma v6 4x4
    Bilstein 5100 shocks all the way around, add a leaf in the rear
    If you have manual hubs then you don't have the automatic disconnect.
    the A.D.D system uses vacuum to apply the front diff... the hubs are always locked.
  3. Feb 28, 2009 at 3:05 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    A.D.D Automatic Disconnecting Differential.
    Actually the A.D.D is electronically controlled. If you have the push button 4WD button on the side of the transfer case shift lever then you have the A.D.D
    I've attached a PDF with the location of the items.
    • loca.pdf
      File size:
      29.7 KB
      103
  4. Feb 28, 2009 at 4:01 PM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    I think your wrong. A.D.D is vacuum controled(maybe by an electric solennoid) but not by the switch, you do not need a push button to have A.D.D..
    refer to your manual it's in there.
    Lots of Info:
    http://www.off-road.com/trucks4x4/article/articleDetail.jsp?id=399612
  5. Feb 28, 2009 at 4:18 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i think jwscoot is right...because i have ADD and i DONT have a pushbutton
  6. Feb 28, 2009 at 4:23 PM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    I also have ADD and no push button.
  7. Feb 28, 2009 at 4:47 PM
    tjgraner09
    TJ
    Conway, SC
    97 XtraCab
    so you guys are saying since i have manual hubs then i do not have the automatic disconnect
  8. Feb 28, 2009 at 4:53 PM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    Exactly.
  9. Feb 28, 2009 at 4:58 PM
    tjgraner09
    TJ
    Conway, SC
    97 XtraCab
    thanks for the help dude! rep to you:D
  10. Feb 28, 2009 at 4:58 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    On the Tacoma's it is an electric actuator. See attached.
    There are 2 different types of selectors. Without push button and with.
    • insp.pdf
      File size:
      34.4 KB
      122
  11. Feb 28, 2009 at 5:13 PM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    I've knocked the vacuum hose off durring an oil change once.. (it connects somewhere near there).. I had no add control with the vacuum hose running to the ADD disconnected, therefor no 4x4.
    There is electrical involved, the switch is inside the transfer case in the tacos without a push button switch.
  12. Feb 28, 2009 at 5:32 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I didn't look at the year of your Tacoma. On the 2001-2004 Tacoma's it's an electric actuator not a vacuum actuator.
  13. Mar 1, 2009 at 6:13 AM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    That makes sense, you can clearly see it's electric in the pdf. your put up in the last picture. I just knew mine wasn't.:)
