CV Axles replaced, 1 leaking from input shaft
Discussion in '1st Gen. Tacomas (1995-2004)' started by GA1044, Apr 4, 2011.
  1. Apr 4, 2011 at 7:55 AM
    GA1044
    GA1044 [OP] Well-Known Member
    San Marcos, TX
    2002 trd 4x4
    Air Hog, Grey-Wire Mod, Fabtech Coilover 3.5 Lift, Deck Plate Mod, Rear Diff Breather Mod, Magnaflow Exhaust
    I recently replaced my front cv axles on my tacoma. My driver side cv is good and not leaking. My problem is in my right axle. I replaced this one the same way, and well this one is leaking from the input shaft to the differential extension arm where the metal retainer on the shaft and the rubber seal in the extension met. Has anyone had any problems with this when replacing the cv or am i doing something wrong.
  2. Apr 4, 2011 at 12:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it happened the first time i replaced my cv's. the clip on the end tore my seal a bit. i got my seal from the dealership and install it..and then put the cv back in without a problem. it helps to put a little grease on the clip and point the ends of it down when putting a cv in. the seal isnt too bad to replace...just go slow and use something with a smooth flat end. i used a socket on one side...and then a long punch on the other.
  3. Apr 4, 2011 at 3:08 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I just fore warned another member about this when he replaced axles , those inner seals are super soft ,expensive & tear easy as hell
  4. Oct 3, 2011 at 2:08 AM
    20toytaco03
    20toytaco03 20toytaco03
    dylan
    cleveland tennessee
    03 tacoma 4x4
    My right side axle is leaking in the same spot. But it has alittle sliding where the boot meets the diff. How can i fix
