CV Boot is torn
Discussion in 'Suspension' started by FoxTaco, Nov 5, 2009.
  1. Nov 5, 2009 at 11:21 AM
    FoxTaco
    FoxTaco [OP] Hoyt and Tacoma for life!!
    Joshua
    Fresno/Kingsburg, Ca
    09 4x4 Fox coilovers w/black rims
    AFE cold air intake, TRD Cat-Bak, Fox 2.5" resevoir coilovers & 2.0 rear Fox Shox from All-Pro Offroad.com, Daystar 2 1/2" leveling kit, , RBP black mesh grille, Panasonic double din touchscreen (flush(no flip out))
    How hard is it to replace a cv boot on the front end of my Tacoma? And how is it done?
  2. Nov 5, 2009 at 11:26 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    not hard at all if possible go to advance auto and buy a 75 dollar axcel, imo its better than the stock, and some packing grease, im sure some one has a write up somewhere for it but it aint tough
  3. Nov 5, 2009 at 11:35 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It's easy but messy.
    - Buy paper towels.
    - Buy the Toyota CV boot kit. Comes with everything including grease.
    - Buy more paper towels.
    - Truck goes up on jack stands.
    - Drain the front differential.
    - Pull the front wheels.
    - Remove the dust cap in the center of the wheel hub.
    - Remove the pin and cap that will be exposed.
    - Using a 35mm socket, remove the nut at the end of the axle.
    - Remove the 2 bolts that attach the spindle to the lower control arm.
    - Swing the spindle out of the way. Use a dead-blow hammer to knock the end of the axle out of the hub while you're doing this and watch that you don't pull the brake lines. If it's too tight, remove the brake caliper and/or steering linkage to give you more room to work.
    - Use a pry bar to pop the inner CV out of the differential. It's a hassle but this is how it's done. Don't ask if there's an easier way -- just keep at it until you pop that thing loose.
    - Axle is now out of the truck.
    - Remove the boot and tulip cup from the inner CV.
    - Remove the retaining c-clip from the inner end of the axle.
    - Use a pulley-puller to remove the tripod from the end of the axle.
    - Remove the outer CV boot.
    - Apply masking tape to the inner end of the axle so you don't catch the new boots on the splines.
    - Grease up the outer CV as needed.
    - Slide the outer CV boot over the axle from the inner end.
    - Grease the outer CV, seat the boot, and apply the clamps.
    - Slide the inner CV boot over the axle.
    - Re-install the tripod for the inner CV.
    - Re-install the retaining clip.
    - Grease up the tripod and inside the CV boot.
    - Grease up inside the tulip cup.
    - Insert the tripod into the tulip, seat the boot, install the clamps.
    - Insert the axle back into the differential. I used a pry bar on the ridges on the outside of the tulip and a dead-blow hammer to knock it back in until it locks itself in place. You'll know when it's seated properly.
    - Reassemble everything in reverse order.
    - Tighten the 35mm axle nut to 120ft-lbs, I believe.
    - Repeat on the other side of the vehicle.
    - Refill the differential. I believe it uses a T55 Torx bit.
    - Grab a beer and a shower, not necessarily in that order. You're a damn mess!
  4. Nov 5, 2009 at 11:36 AM
    FoxTaco
    Joshua
    ok thanks! I will have to go later today and see what i can do. I mainly just wanted to make sure its something i can do myself or take it in to a shop.
  5. Nov 5, 2009 at 11:37 AM
    mjp2
    NJ
    Easiest option is to replace the whole axle. RockAuto.com sells refurbished ones for around $68 after the core return. Turns a sloppy mess into a 2-hour job including both sides and a few beer breaks.
  6. Nov 5, 2009 at 11:37 AM
    98tacoma27
    Ben
    Not Beech Creek
    You are under warranty, or are you worried the dealership will void it because of the shocks and leveling kit?
  7. Nov 5, 2009 at 11:38 AM
    mjp2
    NJ
    These trucks are easy to work on as long as you have the tools. 35mm socket is key, as is that T55 torx. The rest is basic hand tools and random cussing when trying to pry those axles out of the diff. :)
  8. Nov 5, 2009 at 11:43 AM
    FoxTaco
    Joshua
    98tacoma27 i actually was wondering if it is under warranty. I driving thru fields at work yesterday and my tire kicked up a stick and tore it. I have the AllPro fox 2.5 coils in the front and assumed it voided my warranty. Is that true?
  9. Nov 5, 2009 at 11:44 AM
    FoxTaco
    Joshua
    mjp2 Thanks for the instructions!! that helps a lot!!
  10. Nov 5, 2009 at 11:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    If the stick caused it then I would say it isn't a warranty item. But the suspension mods shouldn't void the warranty. It wouldn't hurt to have the stealership check it to see if they will repair it under warranty though.
  11. Nov 7, 2010 at 10:50 PM
    cgilbane
    cgilbane Well-Known Member
    Avon, CO
    07 Tacoma dbl cab
    remote reservoir fox shocks front and rear
    i have the same setup with the fox's. I talked to toyota personally and it does not void the warranty.
    Also there is some law that i''ve seen links to on this site that talks about how lifting the truck is legal.
  12. Dec 22, 2014 at 10:09 AM
    Lost pilot
    Lost pilot Well-Known Member
    Reid
    Nashville, TN
    04 TRD 4x4
    Front window tint, some other stuff
    I just tried this and it's fucking impossible. Ended up duct taping everything back together and limping into firestone to have them replace the axle.
  13. Dec 23, 2014 at 6:38 AM
    mjp2
    NJ
    What step got you tripped up? I just pulled the front differential out of my truck literally last night and it took less than 2 hours, including popping those axles out.
  14. Dec 23, 2014 at 7:21 AM
    stuartcnc
    stuartcnc Well-Known Member
    Adam
    Hammond, Louisiana
    13 SR5 4X4
    3" suspension lift
    Toyota just replaced my whole axle for free. They didn't bat an eye at my over-sized tires or suspension lift. Same thing, I was driving through a field, Well really I was bogging down a pipeline. but that's neither here nor there. Next day grease is everywhere due to a 1" rip in the boot. the even gave me a 6 speed FRS to cruise around in for a few days while the work was done.
    I LOVE TOYOTA
  15. Dec 23, 2014 at 7:21 AM
    stuartcnc
    Adam
    Hammond, Louisiana
    13 SR5 4X4
    3" suspension lift
    I LOVE TOYOTA
  16. Dec 23, 2014 at 7:23 AM
    stuartcnc
    Adam
    Hammond, Louisiana
    13 SR5 4X4
    3" suspension lift
    I believe they told me 60,000 miles was the factory cut off for that particular warranty item. Not sure on how many years.
    But if its out of warranty, just buy a new axle and rebuild that one in your spare time, then you got a spare for the next time you rip a boot.
