cv Boots Third set
Discussion in '2nd Gen. Tacomas (2005-2015)' started by indigobob, Aug 7, 2009.
  1. Aug 7, 2009 at 11:46 AM
    indigobob
    indigobob [OP] Active Member
    Bob
    wisconsin
    2007 trd sport
    Icon front and res. coilovers..deaver 11 pk secondary air filter removal, grillcraft grill,extang trifold soft cover, afe intake an exhaust ligt racing uca kennesaw front bumper
    Currently running a 07 Tacoma DC/LB TRD Sport....installed an OME setup approx 20, 000 mile ago front and rear..886 coils upfront with no weight up there...an aal in the rear....been ripping inner cv boots regularly with mostly highway driving...Question is it the 886 coils with no additional weight causing my issue....would adjustable coilovers set a lesser height help? Thanks:cool:
  2. Aug 7, 2009 at 11:48 AM
    rick
    rick `
    are you running wheel spacers?
  3. Aug 7, 2009 at 11:50 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Did you install the Diff drop spacer?
  4. Aug 7, 2009 at 11:50 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    I wonder if better aftermarket boots are available?
    Years ago I put some on my Mazda when the OEM's first ripped, & they outlasted the engine.
  5. Aug 7, 2009 at 11:51 AM
    indigobob
    Bob
    wisconsin
    2007 trd sport
    Yes I am Spidertrax....with...LR UCA's with 275x70x17 Goodyear Wrangler ATS
  6. Aug 7, 2009 at 11:51 AM
    indigobob
    Bob
    wisconsin
    2007 trd sport
    Also diff drop...thanks for the reminder
  7. Aug 7, 2009 at 12:54 PM
    mpleitez
    mpleitez Well-Known Member
    valencia
    03 toyota tacoma double cab 4x4
    Rear E-Locker TRD supercharger w/URD 7th injector 3 in. lift (soon) Icon coil overs front (soon) Icon UCA (soon) K&N air intake DT Headers (one day)
    :eek:
    did you put in the diff drop kit? I had that problem on my tundra and it needed a diff drop kit and that fixed it or could also possibly be the spacers
  8. Aug 7, 2009 at 12:59 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    just a theory.
    Check your cv boots at ride height with the wheels strait. are the fins touching? if so there is your problem. the angles may be to severe, if the fins are tuching with the wheels strait and sitting at regular ride height, when you take turns the fins rub even more possibly causing them to rip.
  9. Aug 7, 2009 at 1:11 PM
    indigobob
    Bob
    wisconsin
    2007 trd sport
    Yes the fins are touching... exactly as you stated....is there a fix.....I am looking currently at a different setup.....which would be Icons front and rear with a deaver spring pack, which would allow me adjustability in the front on the cv angle. ?
  10. Aug 7, 2009 at 1:20 PM
    Dark Knight
    Jeff
    NC/SC
    the cv angles are directly related to lift height (0-3" of lift). so yes the Icons will allow you to adjust the lift height. with my coilovers i'm a little under 2.75" lift height, the cv boot fins dont touch, and I still run my 285's with 4.5" back spacing wheels with no rubbing.
  11. Aug 7, 2009 at 1:24 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
  12. Aug 7, 2009 at 1:26 PM
    indigobob
    Bob
    wisconsin
    2007 trd sport
    Thank you for your help....I beleive that will be the route I take. Is there anything to the wheel spacers also contributing to this issue as the other TW member indicated in your opinion. At 2.75 is your truck sitting level? Thanks again
  13. Aug 7, 2009 at 1:30 PM
    Dark Knight
    Jeff
    NC/SC
    The Skyjacker Rear springs are 2" lift so the rear sits a tiny bit higher. I am almost 100% certain that the SpiderTrax have no contribution with the cv oots ripping, I ran a set before I got new wheels and had no problems...
  14. Aug 7, 2009 at 1:31 PM
    mpleitez
    valencia
    I'm currently selling my Icons for $900.00 I'm uprgrading to the ones with resevoirs Icons are the SHIZZZZZ let me know and good luck with the CV boot;) tore my tundra 4xs and they were replaced under warranty except the last time and it cost me about $500 TO HAVE THE STEALERSHIP DO IT:mad:
  15. Aug 7, 2009 at 1:47 PM
    indigobob
    Bob
    wisconsin
    2007 trd sport
    Thanks again.....Those are same Icons I am looking at.....and yes the delaership did the first set of boots under warranty....and then decide on the second it was the lift.
    I kinda have to agree at 3 inches with that OME lift those cvs are stressed. Again being a new member thanks for your help
