CV half shafts for Lifted TRUCKS
Discussion in 'Technical Chat' started by BRP27, Jul 1, 2010.
  1. Jul 1, 2010 at 10:01 AM
    BRP27
    BRP27 [OP] When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    My inner boot was torn and the 04 tacoma has 76K on it so I had the CV half shafts replaced yesterday. The mechanic that did the work told me he had put Longer CV half shafts on Chevy lifted trucks. And that without them my boots would fail again( I knew they would fail again but had not heard the longer shaft theory). The failure mode on stock shafts was the boot being stretched when the suspension moved down on the inner CV boot as the shaft went down as the suspension moved. If the upper shaft of the CV that went into the Differential were longer the boot would be under less stress and would not fail on a lifted truck. I did some searching and I could not find after market CV half shafts that are modified like this.
    I had looked at boot failure as the more it was compressed(bunched up) the more likely it was to fail. the boot ribs rub and cause the boot to fail due to bending.
    There are a lot of lifted Tacomas why do the Chevys get the aftermarket parts? And does a longer shaft make sense
  2. Jul 2, 2010 at 8:04 AM
    BRP27
    04 4X4 Tacoma SR5
    I found info on CV Boot Slip Mod in these links. The Mod is to get a new stock upper boot, and clean the CV shaft, put the new upper boot on and slip it down out of its groove 5/8 in, glue it with 3M weather strip glue and clap it with a hose clamp or factory clamp
    http://www.tacomaterritory.com/forum/showthread.php?t=156764
    http://www.tacomaterritory.com/forum/showthread.php?p=1578517
    http://www.tacomaterritory.com/forum/showthread.php?t=91105
    and some boots that go over the boots?
    http://allprooffroad.com/9504frontsuspension/282
