CV Joint Issue. Please help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kaveman, Jun 9, 2011.
  1. Jun 9, 2011 at 5:18 PM
    Kaveman
    Kaveman [OP] Member
    Hey everyone, I am new to this site and was hoping to get some advice from some people who know Tacomas well.
    My truck was leaking grease in my driveway!! So I looked under it and the boot on my CV joint is ripped open. The problem is, I need to use it to drive to work the next 5 days! Will it harm anything if I drive it the way it is? The boot is ripped on the part towards the motor side, not the wheel side. This is the second time it has happened on my truck.. so I am not sure if lifting it is the reason it does that?
    I have a 2001 Tacoma, 4X4 V6 with a 2 1/2 spacer lift in the front and an add-a-leaf in the rear.
    Any advice would be tremendously appreciated since I need to get it figured out fast.
    Thanks!
  2. Jun 9, 2011 at 5:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! I dont think anything horrible could result from driving it for a few days.
  3. Jun 9, 2011 at 5:27 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    My taco is burnt :( ^ isn't that a small problem? :D
  4. Jun 9, 2011 at 5:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    You'll be ok driving it for a lil while.... just replace the cv when you get a chance.
  5. Jun 9, 2011 at 5:44 PM
    Kaveman
    Kaveman [OP] Member
    Wow... thanks for the quick responses guys!
    Will I be okay just replacing the boot?
  6. Jun 9, 2011 at 5:54 PM
    fj6high
    fj6high Well-Known Member
    Howard
    Tarpon Springs
    07' Fjcruiser
    6"Fabtech +OME Heavies and Custo Skyjackers. Way to much to list.
    If your going to go thru that much trouble to replace a rubber boot $40 plus all the time...Just buy the whole Damned CV joint new from Auto Zone for less than $80 bucks...You have to remove the same shit to do either job.
  7. Jun 9, 2011 at 6:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    X2.............in the long run......better off replacing whole shaft. I got mine brand new from advanced auto for around $75.......lifetime guaranteed.
  8. Jun 9, 2011 at 6:03 PM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    I have never replaced the boot on my older Toyota, although I'm sure I should. I just periodically pack grease on the splines.
  9. Jun 9, 2011 at 8:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    There is a good chance that it is the lift that is causing you to tear boots. High axle angles can cause the boot fins to rub. If they rub too much a tear will occur. This does seem to happen more often on the inner boots, if it happens.
    Was it the same boot both times? If so, how many miles did you get on the replacement boot before it tore the 2nd time?
  10. Jun 9, 2011 at 8:16 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I tried putting on high angle cv boots last night and it did not end well. I decided to instead get set some remanufacturered cv axles from autozone. They come with a lifetime warranty so any time I rip a boot or somehow break the axle I just have to go over to autozone for a new axle. Oh and you can drive it the way it is with the torn boot.
  11. Jun 9, 2011 at 8:29 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I would agree about replacing the whole axle instead of just the boot. Been there done that. And if you're worried about driving it like that, your biggest problem is moisture. What you can do is go to the parts store and get a lil thing of speedy boot, that's what it's called, it's green grease specifically for cv axles. Squirt that in the cv and then duct tape it shut. I would suggest cleaning surfaces with some sort of solvent before putting on the duct tape so you get maximum adhesion. You gotta put the duct tape on a certain direction so it doesn't come unraveled driving down the road. Easieast way to do that is to jack the truck up, spin the wheel in the direction that it would travel when driving forward and spin the duct tape on that way. I had an old subaru that had your problem and I did that, and never had a problem with the axle after that. You can even go anther step further and zip tie the ends of the duct tape to keep a seal. Good luck, and if you need advice wit swappin out your axle, well c'mon back.
