CVT/Cascadia Tents Group Buy Event -2014
Discussion in 'Group Buys' started by Cascadia Tents, Feb 15, 2014.
Thread Status:
Not open for further replies.
  1. Feb 28, 2014 at 1:05 PM
    #481
    skisailbike
    skisailbike Well-Known Member
    Colorado/Alaska
    '14 4x4 DCSB OffRoad
    Icon 2.5 ET coilovers, LR UCAs, Dakars, Icon 2.0 RR ET Rear Shocks
    I'm in Avon, so only one of us would need to run down. Perfect!
  2. Feb 28, 2014 at 1:09 PM
    #482
    skisailbike
    Colorado/Alaska
    2 more and we could do a pallet into the Vail/Summit/Glenwood Springs area...
  3. Feb 28, 2014 at 1:43 PM
    #483
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    I am not 100% yet, but I am down in Buena Vista, so avon or vail is only about an hour for me.
    What is the savings on doing the palletized shipping? If we get 4 would it split the shipping cost by 4? If so I am pretty sure I would do that and get the Mt. Bachelor.
  4. Feb 28, 2014 at 1:47 PM
    #484
    Calestus
    Calestus Active Member
    UT!
    13 Baja
    Anyone in SLC, UT want to split shipping?
    Also I have a question about mounting, is there a way to adapt it to wrap around 1.75" tubing?
  5. Feb 28, 2014 at 1:58 PM
    #485
    MTgirl
    Weesa
    Bob's secret mod lair
    I think you may have to buy longer bolts but yes, the tents can be mounted on round tubing and not just square. The bolts that come with the tent are like 2" so you might need to get some 2.5"
  6. Feb 28, 2014 at 2:24 PM
    #486
    skisailbike
    Colorado/Alaska
    Not sure how much the shipping cost reduction is, but I know its significant. I head down your way to Mtn. Bike occasionally, so meeting up wouldn't be a problem.
  7. Feb 28, 2014 at 2:30 PM
    #487
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    Yes - you'll need longer bolts and possibly will have to fabricate the bottom brackets (Just a metal bar with holes in it).
    I did this to mount my CVT to my rack and it's worked great for years.
  8. Feb 28, 2014 at 3:17 PM
    #488
    lortsie
    lortsie VaderTaco
    Adam
    ORYGUN
    '07 DCSB BSP TRD Sport PreRunner
    #FFFFFF. BHLM, Black Badges, Black Rims, Black Grille, Black bedsides, black exhaust.
    So do I need to post here to get the info I need to get in on the Group Buy?
    Edit: also can you guys recommend an exact rack system? I've looked at Thule and Yakima but I'm not sure I am looking at the right ones for my DCSB.
  9. Feb 28, 2014 at 3:18 PM
    #489
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    No sir, just look at the very first post by the OP and it gives you all the information you will need in order to make your purchase on the day the group buy opens :)
  10. Feb 28, 2014 at 3:42 PM
    #490
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    wow….. overs 500 post and GB not even open yet
  11. Feb 28, 2014 at 4:24 PM
    #491
    Scenekyd
    Scenekyd Not much of a member
    Jay
    Hendersonville, NC
    2015 Ford F-250, 2016 4runner Trail
    Sub'd :D ready for March 5th :cool:
  12. Feb 28, 2014 at 5:07 PM
    #492
    MTgirl
    Weesa
    No but you must send me a bottle of wine to get the super secret group buy code :spy:
    You have lots of options for racks. CVT carries some that are sort of a universal truck bed mount (like the Thule/Yakima) or you can get one fabbed up to fit your truck and your needs specifically (say if you wanted to have shovel/hi lift mounts, etc on the sides). There are a few folks on TW that make the racks, a few of us RTT owners have posted our set ups over here. It could give you some more ideas of what is available.
    Things to consider: how high do you want to mount the tent, if you want the tent to open to the side its best that the supports run the width of the bed, what else are you going to have in/over the bed of the truck...?
    and...??? Its TW, this sort of thing happens
  13. Feb 28, 2014 at 5:16 PM
    #493
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Hey I am a lot cheaper, send me some girl scout cookies.
  14. Feb 28, 2014 at 8:40 PM
    #494
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Here is a close up look at the stock bracket that comes with the CVT RTT. That is 1.5" square tubing. Pic courtesy of Blackdawg
  15. Mar 1, 2014 at 12:27 AM
    #495
    phisohex
    phisohex Well-Known Member
    pat
    Rocky Mountains, Colorado
    2002 Double Cab TRD Tacoma
    Ha! Im in Avon too..
    If we can get a ship to Silverthorne that would be awesome!
    Stop by pazzos on sunday or monday night, Ill buy you a slice!
  16. Mar 1, 2014 at 12:39 AM
    #496
    phisohex
    pat
    I dont have a rack for the tent... YET, so i just started fabbing one up, pretty simple design as i dont have a tube bender..
  17. Mar 1, 2014 at 4:51 AM
    #497
    1Tacoma3
    1Tacoma3 Member
    Byron
    Northern Virginia
    2013 TRD off road Tacoma
    Avid off road step bars, rear bumper guard, and front light bar. 4 Hella 700ff's converted to HID. HID head and fog lights. Softopper
    Hello any one looking to purchase one in northern Virginia or the surrounding area to save on shipping???
  18. Mar 1, 2014 at 4:52 AM
    #498
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    no "and…???" just an observation
  19. Mar 1, 2014 at 4:53 AM
    #499
    criticalmass
    criticalmass Member
    I want the room of a mt ranier RTT. I also want to mount on a bed rack. That said, it would be on a DCSB tacoma and have to hang off the back of the rack a foot. Would this be fine? or do I need to fabricate a rack with a cantilevered support for that last foot?
    It would seem like it would be fine since these are all mounted on 2 bar systems, so there will always be a significant part of the tent unsupported. Thoughts? Pictures?
  20. Mar 1, 2014 at 5:06 AM
    #500
    Cascadia Tents
    Cascadia Tents [OP] Well-Known Member Vendor
    Bobby
    Bend, Oregon
    Betty White
    Is this the rack system you are wondering about?
Thread Status:
