Cylinder 2 Misfire Help!
Discussion in '1st Gen. Tacomas' started by cjy5005, Mar 12, 2012.
  1. cjy5005
    cjy5005 [OP] Member
    Oregon
    99 Toyota Tacoma SR5 TRD
    So today I was driving to work and my truck started to sputter when I tried to put the the gas pedal to the floor, then the check engine light came on. It seemed to be running pretty rough so I figured a misfire. Took it to the local auto parts store and had them run a diagnostic check and it threw a code for cylinder 2 misfire (P0302 i think). Took it back home and pulled the #2 cylinder plug it was fine and so was the wire. Decided to pull the #5 cylinder plug just to be sure and it was coated in oil!! I was having problems with the same thing about a month ago but in cylinder #1. I thought it was just the spark plug tube seals but at this point I am pretty sure it is something worse.
    So I guess what I am getting at is where does this leave me? Engine rebuild?
