D-Ring installation problem.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kryten, Jul 14, 2011.
  1. Jul 14, 2011 at 6:53 PM
    kryten
    kryten [OP] Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    I installed front 2 d-rings but I was not able to remove the washers from those two bed bolts. Does everybody have a hard time removing them? This way I cannot install the d-ring in between the washer and the bolt head as its supposed to be done.
    I ended up putting 3 smaller washers I had lying around under the d-ring because the way the d-ring is designed it can only sit one way facing up. Those 3 washer enabled me to make enough room for the d ring to not interfere with the bed of the truck. On top of the d- ring is the original washer I was not able to remove.
    I don't think this is a good idea to have it like this. I lost of thread on the bed bolt this way already. Any ideas?
    [​IMG][​IMG] [​IMG][​IMG][​IMG]
    [​IMG][​IMG][​IMG]
    [​IMG][​IMG]
  2. Jul 14, 2011 at 7:03 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    There are ridges on the bolt that you have to sand/dremel off to get the washer off.
    Just remember to paint the exposed metal left behind.
  3. Jul 15, 2011 at 9:55 AM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    And use Loctite Red when putting back together. You can use a file to get the ridge of. Just look at it, its obvious.
  4. Jul 15, 2011 at 10:32 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
  5. Jul 15, 2011 at 10:33 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    I just coated it with a very thin layer of silicone. If you think about it, once you crank down on these, they dont go anywhere, and even if they come a little loose, they arent doing much. You have 6 bolts that just keep this bed bolted to the frame. I wouldnt go crazy
    To the OP .. the above posts were correct. There is a very small ridge that keeps the washer from coming off. Just use a grinder or file to remove the ridge.
  6. Jul 15, 2011 at 10:49 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i used a hand file. it took surprisingly little effort to take the washers off. i just painted them black, and put it all back together. that nut is attached at the bottom, so it wont fall off. if anything gets loose, you will know. you'll see it loose in the bed.
  7. Jul 15, 2011 at 2:33 PM
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    Hand file works good and quick
  8. Jul 15, 2011 at 2:44 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I did my buddies with a dremel to trim down the ridges. But with mine, I used a vise and a big ol hammer!!!
  9. Jul 15, 2011 at 3:09 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Support the bolt inverted on a vise by the washer and hit it a few times with a hammer and it'll pop right out.
  10. Jul 15, 2011 at 3:56 PM
    JKD
    JKD Well-Known Member
    I tried using a large socket to hammer the washer down over the ridges on the bolt, and it just bent (dished out) the washer. I dremeled the ridges down and it took all of two minutes per bolt to make the washer come off.
    Flattening out the washer after it was dished was a little annoying.
  11. Jul 16, 2011 at 10:37 AM
    kryten
    Canada
    Thanks everyone, I have to find some time this weekend and redo it.
  12. Jul 16, 2011 at 1:27 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I used a pedestal grinder to remove the ridge. It took all of 2 minutes to do. I didn't put any loctite or anti-seize on the bolts either when I reinstalled them. I check them periodically to make sure they aren't loose...and so far 20,000+ miles and they haven't budged.
  13. Jul 16, 2011 at 2:25 PM
    JKD
    I did put anti-sieze on the threads, because there was noticeable dirt/corrosion in the threads that went down past the frame nuts. I figure it's cheap insurance against having them frozen in place.
  14. Jul 17, 2011 at 6:25 PM
    kryten
    Canada
    Re-done today the right way. Thanks again TW!
  15. Jul 17, 2011 at 6:45 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    :thumbsup:
    Fwiw, I didnt use any loctite, anti-seize or anything of the sort when reassembling mine, and they've been great ever since install (as in, they havent loosened up or whatever)
