D-Ring question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Jun 17, 2012.
  1. Jun 17, 2012 at 12:25 PM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    not sure if this is possible or if anyone has tried it. is it possible to add d-rings to a stock 2nd gen tacoma and have them actually be functional? i bought one for the front and a mount from a member on the forum, is there anyway to add them to the rear bumper without having to upgrade to an all metal bumper?
  2. Jun 17, 2012 at 12:29 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You could make D-ring recovery points mount to the rear, just make sure they bolt through the bumper to the frame or get a receiver mounted D-ring from Harbor Freight or one of the vendors on here.
  3. Jun 17, 2012 at 12:31 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    are you talking about shackles or d-rings? d-rings go inside the bed, shackles go on bumpers and rec hitches usually.
  4. Jun 17, 2012 at 12:34 PM
    danteisme
    South Western PA
    sorry shackles, not d-rings.
  5. Jun 17, 2012 at 12:35 PM
    danteisme
    South Western PA
    i was thinking of mounting them to the bumper itself, i was just worried the first time i go to use them, it would bend the bumper all up from the force of pulling etc..
  6. Jun 17, 2012 at 12:37 PM
    Brunes
    Brunes abides.
    Rotorhead
    They make reciever hitch shackle mounts...Otherwise you'll need to fab something up.
  7. Jun 17, 2012 at 12:48 PM
    Pugga
    Massachusetts
    The bumper itselt won't withstand a recovery. You'd have to brace it back to the frame of get a hitch mount shackle.
  8. Jun 17, 2012 at 2:59 PM
    danteisme
    South Western PA
    i do not have a factory reciever, i just have a bumper reciever
  9. Jun 17, 2012 at 3:03 PM
    Pugga
    Massachusetts
    You can add one easily enough. I put a Hidden Hitch Class III on mine but there are lots of brands available, or pick up a used factory receiver for sale on here. Mine took about 30 minutes to install in a parking lot on my back. Then you could get the hitch mounted D-ring. If you plan on frequent hard recoveries, I'd look for a factory receiver. They seem to be a lot beefier than the aftermarket versions.
  10. Jun 17, 2012 at 9:41 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
  11. Jun 18, 2012 at 4:56 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    For the front, I am making a simular attachment point like the one on our truck's passenger side that a shackle can mount to when needed. :cool:
