DAC Operation Question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Nov 1, 2009.
  1. Nov 1, 2009 at 8:07 AM
    OffroadToy
    OffroadToy [OP] kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yesterday while comeing down a steep hill (loose gravel, dirt, rocks) I was in 4LO with the automatic in low gear with no problems and decided to use the DAC (downhill assist control). Once I pressed the DAC button the traction control went into effect and started the pulsating brake thing...made a hell of a noise! When I switched the DAC off, the truck went down the hill smooth and at a slow rate of speed. My question...is it normal for the traction control to work the brakes while in DAC mode? I was under the impression the DAC used the engine for braking. It doesn't mention this in the manual, but would it be better to hit the DAC switch when stopped completely, rather than while crawling...maybe a little slippage occurred before the DAC went into effect causing the traction control to work the brakes to control slippage?
  2. Mar 16, 2010 at 3:14 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    My experience was the same as yours. It was very noisy and it uses the brakes. I did not like it at all. I don't understand the usefulness of the DAC feature while offroading.
