Dakar Leaf Packs...
Discussion in 'Suspension' started by type o negative, Jan 29, 2009.
  1. Jan 29, 2009 at 8:45 PM
    type o negative
    type o negative [OP] Well-Known Member
    UT
    09 Double Cab TRD Sport - White
    I dont know anything about the OME Dakar Leaf Packs other then I hear they are a better alternative to AALs. How true is that statement? And which do you recommend as it looks like there is quite a few variations on the ARB website.
    Thanks dudes.
  2. Jan 30, 2009 at 4:37 AM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    They absolutely rock. IMO
  3. Jan 30, 2009 at 4:46 AM
    SnoBoarder
    Lost
    Everything was cheapest at trdparts4u.com (when I shopped it)
    2 Leaf Packs: CS047R 05+TAC $166.94ea
    4 U-Bolts: OMEU53A TACOMA 05 $6.89ea
    4 Rear Bushings, 2 per leaf: 90389-A0003 BUSH $5.02ea
    2 OME Rear Shocks: OMEN182 $74.82ea
  4. Jan 30, 2009 at 7:02 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Thanks for the heads up! I have plans to order these next week and was planning on going with wheelers... Mind if I ask what shipping was?
  5. Jan 30, 2009 at 7:09 AM
    Dustin03
    Dustin03 The Cooler King
    Arizona
    Expeditionary vehicle in training.
    Old Man Emu 2.5" lift, brush guard (about to be changed), grey-wire mod, custom bed mounts for 4 jerrycans, custom survival box, maglite mount, KC Dayliters.
    I have Dakar springs on my 1st Gen, and I love them! Don't know what to tell you about the different choices, because I got the only ones they offered for my year. Maybe someone else has had experience with this?
  6. Jan 30, 2009 at 7:18 AM
    SnoBoarder
    Lost
    I paid $109 for shipping. The leafs are about 60Lbs each if I recall.
  7. Jan 30, 2009 at 7:38 AM
    type o negative
    UT
    So this kit does look like it has the Dakar packs in it...
    COILS OME 886 2
    FR SHOCKS N140S 2
    REAR SHOCKS N182 2
    D/S SPACER FK29 1
    TOYOTA BUSHES 90389-A0003 4
    UBOLTS OMEU53A 4
    REAR LEAFS CS047R 2
    Is this all I need to get a full 3 inchs? And are those the actual shocks most of you run? You can get this kit with 885 as well... Nt quite sure which one I need, 885 or 886?
  8. Jan 30, 2009 at 7:46 AM
    LonghornTaco
    Minnesota
    OME coils paired with OME shocks is a great choice! It's not what I run, but those who do rave about them...
    Regarding the 885 vs 886, since you have a double cab, the 885s should be fine. 886 might be a little too stiff, unless you plan to run a really heavy bumper (200+ lbs) like the road armor, iron bull, etc...
    The one thing that this kit doesn't include are new upper control arms. They're not absolutely required, but they'll be necessary to correct alignment issues after lifting it 3".
  9. Jan 30, 2009 at 7:52 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    is that a kit you found somewhere?? (Linky please if it is)
  10. Jan 30, 2009 at 8:55 AM
    type o negative
    UT
  11. Jan 30, 2009 at 9:19 AM
    type o negative
    UT
    Do the Dakars with the OME shocks give you enough lift for 33's or do you have to add the extra leaf?
  12. Jan 30, 2009 at 10:34 AM
    sonjay
    sonjay Well-Known Member
    +1 on the Dakars, there is only one spring pack for our trucks, CS047R is the correct number! You won't get a full 3" in the front with the 885. maybe 2 1/2" or so? I have the 885 with OME shocks and there great, stock UCA isn't ideal but it works for now. You will not be able to run anything bigger then 265/70/16 without a new UCA and wheels. I plan on getting the light racing UCA when the dollar looks better!
  13. Jan 30, 2009 at 12:18 PM
    type o negative
    UT
    Really? I was under the impression you could fit 285s with 885 and OME shocks.. So you would have to use 886 to fit 285s?
  14. Jan 30, 2009 at 12:34 PM
    LonghornTaco
    Minnesota
    I'll add to that a bit...
    If you run 285s on STOCK rims, even with new UCAs you'll rub them. You'll need spacers to clear the UCAs.
  15. Jan 30, 2009 at 1:38 PM
    type o negative
    UT
    Ahh stock wheels... Ok. So its all in the offset. So does that kit look like it includes the shims to even out the "taco Lean"?
  16. Jan 30, 2009 at 1:44 PM
    LonghornTaco
    Minnesota
    Yep, it's all about the offset. The stock offset is ~5.5" I believe. If you look at aftermarket rims, look for 4.5" or less.
  17. Jan 30, 2009 at 1:50 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Nope (lean) -- but you can order those relatively cheaply at EDIT: Beat me to it... lol
  18. Jan 30, 2009 at 3:30 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    So this makes me wonder- Will it all be level front to back if I go Dakars and 885s?? I'm not so hung up on 3 inches-but it does need to be level and higher. (I'd like the full three- but it's not a deal breaker)
  19. Feb 5, 2009 at 5:29 PM
    ghostboy808
    ghostboy808 Well-Known Member
    Silver Mica Prerunner TRD Sport
    Gibson SS, TRD S/C
  20. Oct 23, 2013 at 11:08 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    quick question, do you have to purchase bushings for an OME dakar leaf pack install or can you reuse the factory oem bushings? thanks
