Dakar leaf springs , actual lift measurement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OZ-T, Jan 31, 2010.
  1. Jan 31, 2010 at 11:21 AM
    OZ-T
    OZ-T [OP] You are going backwards
    Peter North
    British Columbia
    Before I get flamed , I've searched and my research shows that the Dakar pack should get you 2.5 - 2.75 " of lift over stock .
    My canadian truck has the 4 leaf ( tsb ) pack which is 1" higher in the back than the stock 3 leaf US truck rear . So I was expecting to get the rear end up an additional 1.75 - 2" over my current height with the Dakars .
    Just about to pull the trigger on the Toytec ULK with the Dakars and I started to follow My50cal ' s build , he is on 265/70/17 like me and has the regular Dakar pack in the back and his rear measurement is at 41" which is almost 4" above my current 4 leaf pack measurement .
    What gives , I don't want to be that ass high as I only intend to go up 1.75 to 2.5 up front .
    I know there is lots of guys running the Dakars , can you help a Taco Brother out and give me your rear measurement from the centre of wheel to the underside of the fender as that will eliminate any tire difference .
    I want to order my lift , but I was waiting with the billies on backorder and now I'm not sure if the Dakars are the way I should go .
    Thanks to all for the continued handholding ,
    Go Canucks ,
    OZ
  2. Jan 31, 2010 at 11:26 AM
    DuderAbides
    DuderAbides Well-Known Member
    Tom
    Vista, CA
    2010 DC SB TRD OR 4X4
    I'd like to know as well as i am planning on doing the same lift as you in the future.
    Go Rangers!:spy:
  3. Jan 31, 2010 at 11:47 AM
    OZ-T
    Peter North
    British Columbia
    Canes ? Really ?
    Not digging their treatment of Brind'Amour
    OZ
  4. Jan 31, 2010 at 11:53 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I'm assuming you are talking about 5100s that were onbackorder at Downsouth Motorsports. They no longer are. I talked to Sony yesterday and ordered mine. He did say they were going fast!
    Good luck with your build.
  5. Jan 31, 2010 at 12:35 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    I would do a full OME setup with 885 springs and 2 trim packers on the driver side. Give Toytec a call up and see what the damage is going to be
  6. Jan 31, 2010 at 2:32 PM
    OZ-T
    Peter North
    British Columbia
    Anyone with Dakars to offer up some measurements ?
    OZ
  7. Jan 31, 2010 at 2:33 PM
    OZ-T
    Peter North
    British Columbia
    Just rattling your cage , your boys have managed a couple wins in the last few games , and Ward looked airtight in the last contest .
    OZ
  8. Jan 31, 2010 at 6:31 PM
    OZ-T
    Peter North
    British Columbia
    Nobody with Dakars will chime in ?
    OZ
  9. Jan 31, 2010 at 9:45 PM
    OZ-T
    Peter North
    British Columbia
    bump
  10. Jan 31, 2010 at 10:14 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Alright, since you asked like 20 times. 24" from center of hubcap to bottom of fender. Just under 40" from ground to fender through the center of wheel. That's with 285/75/16 Toyo M/T's. That 41" measurement you referenced seems a bit high with 265/70/17 tires, does he have an extra leaf or something?
    mabepossibly and MTopp like this.
  11. Jan 31, 2010 at 10:23 PM
    OZ-T
    Peter North
    British Columbia
    Finally , thanks for the input , I asked the same question about whether it was the ' basic ' Dakar pack or with the additional leaf but he said it was the regular pack .
    Not too sure how that works , but whatever , thanks again for the help :D
    OZ
    MTopp likes this.
  12. Feb 1, 2010 at 3:24 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Hey bro I believe you can remove a leaf from the dakars to lower the rear a bit if u so choose?
  13. Feb 1, 2010 at 7:50 AM
    OZ-T
    Peter North
    British Columbia
    Yes , I should have mentioned that I may do that as an option , but I just wanted to see what guys were getting in the real world for a lift from the stock pack ,
    Anyone else with the Dakars ?
    OZ
  14. Feb 1, 2010 at 7:51 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Just remember, the rear will almost always settle some - sometimes significantly, depending on the leaf spring and how hard you use it.
  15. Feb 1, 2010 at 8:51 AM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    Yes, GO CANES!!! :D :)
    (They haven't been doing too bad these past few games. :cool:)
  16. Feb 1, 2010 at 9:30 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    i have the dakars with a leaf removed and i got about 2 inches from it off my 4 leaf. I'll find the measurements.
  17. Feb 1, 2010 at 9:34 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
    24 inches from the center of the wheel to the bottom of the fender.
  18. Feb 1, 2010 at 2:56 PM
    OZ-T
    Peter North
    British Columbia
    Thanks to all ,
    OZ
  19. Feb 1, 2010 at 3:01 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    I took out the 3rd leaf from my Dakars so the ass end wasn't so high, it sits pretty level now. I have a camper shell though.
  20. Feb 1, 2010 at 3:08 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    first off...how do you know the TSB gives you 1" lift? i know when i replaced my leafs w/ the TSB ones, i gained nearly nothing...
    i just installed some used dakars a few weekends ago, i'll get you the center of the axle to bottom of the wheel well measurements if you would like.
