Dakars and King (Rears)
Discussion in 'Suspension' started by Avex, Jan 12, 2016.
  1. Jan 12, 2016 at 11:08 AM
    Avex
    Avex [OP] Well-Known Member
    Alex
    PNW
    Hi All,
    I have the king 2.5 remote rears and an AAL currently in the back. Im looking at upgrading to the Dakars CS047R (removing the AAL) and keeping my Kings. Will i run into any issue with my current rear shocks and the Dakars? Extended they are 24.29", collapsed they are 15.83" for a travel of 8.46"
    Thanks
  2. Jan 12, 2016 at 1:27 PM
    Avex
    Alex
    PNW
    I guess what i really should have asked is what is the worst that could happen? I dont off road heavily. Mainly forest service roads to hunting and fishing locations. With the occasional off roading 1-2 times a year if that.
  3. Jan 13, 2016 at 5:37 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Should be fine, an AAL isn't going to make that big of a difference. Thats already a short shock for standard Dakars.
  4. Jan 13, 2016 at 5:46 AM
    ZIB
    ZIB Well-Known Member
    Zach
    Rhode Island
    2014 TRD DCLB Sport
    Pelfreybilt front bumper steel full hoops Warn Zeon 10s winch Caliraised 20" slim light bar and amber 18w pods TRD exhaust Century High-C topper Stubs Welding SKO sliders Pelfreybilt Skids King 2.5 RR extended travel coil over with 650 springs and King 2.5 RR rear shocks Dakar leaf pack Total Chaos UCA BFG KO2 265/70/17 Cobra 75 wx st CB w/ 4' Firestik FS Rotopax 4 gallon gas can
    I just bought this set up, and I know Down South Motorsport has a specific rear shock for the Dakars. Give Micha a call and verify or to see if there is anything else you might need, longer bumpstops(?). If you're not wheeling it hard you'd probably be ok, but defiantly worth a call or message.
  5. Jan 13, 2016 at 6:00 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Those measurements are for Kings OE spec shocks. He will be fine.
    I run a 10" travel shock on mine with Dakar packs w/ a 16" collapsed length. The shocks will become your limiting factor out back, some say you will need limit straps...but you will be fine without. I'd be more concerned with adding extended rear brake lines :D
  6. Jan 13, 2016 at 6:05 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Did you need to extend your bumpstops with the collapsed length of16"?
  7. Jan 13, 2016 at 6:07 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    I run hydro bumps...so little bit different.
    Few folks I know running similar length shocks have spaced their bumps a bit. It really depends on what bumps you have installed, U bolt flip etc. Only way to know for sure is cycle your suspension!
    303tacoma[QUOTED] likes this.
