Dakars make contact with shackle.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BroID, May 15, 2019.
  1. May 15, 2019 at 1:40 PM
    BroID
    BroID [OP] Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    Hey Tacoma world. I have run into an issue with my Dakars. First of all this is my setup:
    Front-OME 888 coils with bilstein 5100s
    Rear-RCD extended travel bilstein 5100s, OME HD Dakars, Wheelers super bumps bumpstops, stock shackle hangers and shackles.
    For what it’s worth 255/85r16 tires
    So as the title says I have contact from the leaf on the shackle on both passenger and driver side on both sides of the shackle. Driver outside being the worst.
    My first thoughts, I have bent the shackle hanger. Ordered The HD BAMF shackle hangers and shackle (not yet recieved). After thinking about it that can’t be it becuase of the contact on both sides of the shackle. Granted one side is much worse on the driver side.
    Leafs are straight and aligned with one another as well.
    I have about 15k miles on the setup
    Any thoughts?
  2. May 15, 2019 at 1:44 PM
    BroID
    The Gem State
    More pics
  3. May 15, 2019 at 1:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are the leafs installed in the correct orientation? i.e. the little arrow pointing forward.
    whatstcp likes this.
  4. May 15, 2019 at 2:07 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Check you U bolts and the centerin pin through the leaf pack... i would suspect something amiss in that general area
  5. May 15, 2019 at 2:17 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    In the last pic; the leaf with the hole is moving side-to-side, hitting both sides of the shackle?
  6. May 15, 2019 at 2:33 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yeah. I have no experience but it looks like the over load is loose and pivoting. I'd imagine the shackles get further away when the spring compresses no?
    BroID[OP] likes this.
  7. May 15, 2019 at 2:37 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    I'm gonna check my Dakars.
  8. May 15, 2019 at 3:36 PM
    BroID
    The Gem State
    Yes. Little arrow forward!
    Tonight I will put the truck up on stands and check u bolts etc. I have already checked the hardware at the shackle and hanger.
    Dakars and BAMF hangers with BAMF hangers are not compatible and require some trimming of the Dakars. As you mentioned. I plan to trim the Dakars or am hoping that some one comes up with something better.
    Thank you all for your responses.
    Bumble Bee Tuna likes this.
  9. May 15, 2019 at 6:35 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
  10. May 15, 2019 at 6:40 PM
    SpeySquatch
    2016 TRD OR DCSB
    Yep, this is normal for Dakars and you may hear a clunk from time to time as that military style wrap slaps the shackle during a bump while turning.
    I hated that sound which is why I did this
    sd1uh8as and BroID[OP] like this.
  11. May 15, 2019 at 6:52 PM
    BroID
    The Gem State
    Seriously!!! Is it just me or do I do I feel ARB has taken a step backwards on quality. Are those leafs the CS047s? Im curious if they are because I have the newer version. They could have fixed this issue when they did the update!
    SpeySquatch[QUOTED] likes this.
  12. May 15, 2019 at 6:59 PM
    BroID
    The Gem State
  13. May 15, 2019 at 7:31 PM
    SpeySquatch
    2016 TRD OR DCSB
    Yep they are the CS047
  14. May 16, 2019 at 3:25 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    OME did update the design, but this particular spot on the springs isn't much better on new EL095/96.
    Please call up ARB/OME and tell them the issue, they need to hear it so they can fix the problem. Get them to fix the problem they created.
    IMO, here's what happened: OME was used to making leaves for the Hilux with shackle design opposite of the Tacoma. On Hilux it is fine to stack leaves under the spring eye, nothing to hit on Hilux.
    Then someone decided it would be fine to use that Hilux friendly design on the 2nd gen Tacoma. Isn't the aftermarket great?
    Archive Hammer hangers are improved by moving shackle pivot rearward which helps with Dakars contact issue because shackle rotates away from leaves a bit. Because Dakars are so short, they get the most lift with Hh, but max out around 3/8" for HD Dakars since revision in September 2018.
    On BAMF side, the shackle he offers don't work with a standard spring eye, like Dakars and Alcan use. They only work for an English wrapped eye like Deaver uses. I watched it unfold, BAMF painted himself in a corner with the hanger design, his original shackles were rubbing the hangers with longer springs, so the shackles could only work the final way he now offers (for longer springs). But they do cost less.
  15. May 16, 2019 at 5:54 AM
    BroID
    The Gem State
    I emailed ARB but have yet to hear from them. I will be calling. Mind blowing ARB has allowed this. Upsetting because now I am looking at repairs and contemplating different leaf springs.
    Archive, excuse my ignorance but the stock shackle is 3.4”. You sell a 4.5” that would lower ride height with a spring over axle and Dakars, also the 4.5” might not flex fully as a spring over. You sell a 3.6” this would yield the same ride height?
  16. May 16, 2019 at 5:58 AM
    BroID
    The Gem State
    All hardware touching rear suspension is torqued appropriately.
  17. May 16, 2019 at 9:24 AM
    ARCHIVE
    Eric
    The 4.5 would lower the truck with Dakars, and only with Dakars they would not hurt flex.
    I'd recommend staying with stock length or 3.6" shackles for spring over
  18. May 16, 2019 at 12:32 PM
    Dee_Rail
    Dee_Rail Well-Known Member
    Dee
    SoCal
    '18 Tacoma Off Road 4x4
    Notice my Dakars did the exact same thing when I installed them back in January. Had one of the guys at RPM Garage look at it when I was getting an alignment, and he showed me a shackle that was beat to shit because of the same leaf packs, said the guy who had them wheeled a lot.
