Dakars minus the one overload leaf
Discussion in 'Suspension' started by Blk04SR, Aug 17, 2010.
  1. Aug 17, 2010 at 9:32 PM
    Blk04SR
    Blk04SR [OP] Well-Known Member
    SoCal
    '20 TRD Offroad 4x4 DCSB 6 Speed Manual
    AccuTune Fox 2.5's, Camburg Billets A-Arms, Enkei+Toyo AT3's, Deaver Overland Stage 2, Demello Front Bumper, Go Fast Camper
    Well I have been reading that people can take out one overload leave and it will give them less of a lift, I am only really looking for 1.5" or 2" max seeing I have the front just set to 2"
    Can I remove a overload leaf and an regular leaf?
    Will I still be able to tow and haul stuff without a overload and regular leaf?
    This is on the 2nd gen Tacoma BTW...
  2. Aug 18, 2010 at 12:25 PM
    Blk04SR
    SoCal
  3. Dec 31, 2012 at 12:43 PM
    Blk04SR
    SoCal
  4. Dec 31, 2012 at 12:44 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I removed the 3rd leaf down in my dakars, left both overloads. With 885s up front i am 1/2 higher in the rear.
  5. Dec 31, 2012 at 12:46 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    If you are looking for only 2" of lift, look into the ironman4x4 leaf pack. It is only a 2" lift in the rear. They haul extra weight great too.
  6. Dec 31, 2012 at 3:37 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    In for some more answers or options, I'm in the same boat
  7. Dec 31, 2012 at 4:09 PM
    Blk04SR
    SoCal
    That would be around 2" taller than right? The 885's are 1.75" tall lift in the front. My coilovers are set at 2.0" but I might step it up to 2.5" so down the line I can run a 255/85/16.
    Hmm who sells them? I would like to take a look at them? Do you know anyone running them?
  8. Dec 31, 2012 at 4:11 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Does the overload leaf come into play at all when the truck isn't loaded? I think by removing the overload leaf, your only height loss would be the thickness of the leaf itself.
  9. Dec 31, 2012 at 4:21 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    Sierra expeditions. And I am. Just check my pictures
  10. Dec 31, 2012 at 4:26 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    I got about 2.5 inches of lift from 885s. My center of hub to fender measurement in the rear is about 23 3/4
    Nope only matters with a load, or with alot of flex and with the dakars i would imagine a pretty heavy load. Ya you would only lose about 5/8 of lift.
  11. Dec 31, 2012 at 4:40 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    I have these on my truck.. If you want a HD spring and your doing alot of hauling YES. American made. They are Fing HEAVY..
    Ride is not so bad after they wear in..
  12. Dec 31, 2012 at 5:02 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This
  13. Jan 1, 2013 at 12:33 PM
    Blk04SR
    SoCal
    Would Deaver's and air bags for the load?
