Dakars or 3leaf progressive AAL?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GYOAZ, Nov 14, 2017.
  1. Nov 14, 2017 at 2:24 AM
    GYOAZ
    GYOAZ [OP] Well-Known Member
    Gary
    Tucson, AZ
    2015 Tacoma SR5 4X4 MGM access cab
    Billies and Eibachs, Camburg BJ UCAs, Demello hybrid sliders SOS HC rear bumper, SOS front bumper, Warn M80000, fully armored, Safari snorkel, No-slip locker, diff breather, bumper and roof mounted light bars, onboard Viair, 275/70 17 BFG ATs, and a badass sound system.
    Im planning to upgrade from my AAL in the rear of my AC. I'm on ome 886s up front and have an empty box 75% of the time as it's my DD. I load up 2-3 hundred pounds for camping and Wheeling. Also I pull a 5k# trailer or boat with an SOS HC bumper hitch. Last time I was out Wheeling I bottomed out a couple of times with under 200# in the bed. I'm looking for something that'll make the rear end less flopy and will stay stiff while I'm towing. Right now I'm thinking of either Dakars or a wheelers 3 leaf progressive AAL. Would the Dakars be too stiff under an empty bed?
  2. Nov 14, 2017 at 2:38 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Colorado Springs
    21 Sport AC MT S/C
    Go with the Dakars. I had the Wheelers 3leaf added to a brand new TSB leaf pack with the overload left in and changed it out for EL095R Dakars less than a year later. The progressives are fine when unloaded but can’t carry a load and squat with just a few hundred pounds on the truck or hitch. The Dakars are a little stiffer when unloaded but it’s not bothersome.
  3. Nov 14, 2017 at 2:58 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I like my Dakars ,but I always have the load of my Allpro rack. I'm not sure how it would ride with no weight in the back. The Flex off-road is pretty dam good also.
  4. Nov 14, 2017 at 3:24 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Dakars - done​
  5. Nov 14, 2017 at 5:13 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    '11 TM DCSB & '13 BRM regular cab
    Leather seats, WeatherTech's, Access LiteRider tonneau cover, extra D-rings in bed & tailgate. Pelley lightbar with Hella 700FF's. Temp./compass O/H console.
    Another vote for Dakars. I’m really happy with the way my truck rides and I run around unloaded the majority of the time.
    ChadsPride and TacoTRD78 like this.
  6. Nov 14, 2017 at 5:15 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    Dakars and Fluid Film!
    boogie3478 and ChadsPride like this.
  7. Nov 14, 2017 at 5:26 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    This should be an auto reply to every post.
    timbobzimbob and ChadsPride like this.
  8. Nov 14, 2017 at 5:33 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    As someone who has switched up their rear suspension 4 times now, go with Dakars. Buy once cry once. Do it right the first time.
    motodude95 and ChadsPride like this.
  9. Nov 14, 2017 at 5:35 AM
    GYOAZ
    Gary
    Tucson, AZ
    I did that with my front. Finally settled on the 886s with billies.
    geekhouse23 likes this.
  10. Nov 14, 2017 at 5:46 AM
    geekhouse23
    Curious what you have them set to..
  11. Nov 14, 2017 at 5:53 AM
    GYOAZ
    Gary
    Tucson, AZ
    Lowest setting, I went 886 because of bumper, winch and skids. I previously had eibach 620# set at .75 but I like the ride much better now.
  12. Nov 14, 2017 at 5:56 AM
    boogie3478
    boogie3478 Tacomaholic & Hollywood
    Northern Virginia
    14 TRD Off-Road V6
    All the mods
    I'm running dakars and the only weight I have in back is probably 100lbs from my Voodoo rack and gear. Feels just like stock to me.
    ChadsPride likes this.
  13. Nov 14, 2017 at 5:58 AM
    geekhouse23
    Do you have the AAL too or just the stock Dakar pack?
  14. Nov 14, 2017 at 6:23 AM
    boogie3478
    Northern Virginia
    14 TRD Off-Road V6
    All the mods
    Just the dakar pack.
  15. Nov 14, 2017 at 6:37 AM
    GYOAZ
    Gary
    Tucson, AZ
    I'm sitting pretty level right now with a 2" AAL. Will Dakars give me back a little bit of a rake?
  16. Nov 14, 2017 at 6:39 AM
    geekhouse23
    Yes
  17. Nov 14, 2017 at 6:41 AM
    TacoTRD78
    Stuart,fl
    They will increase the rear height approx. 3/4 of a inch if there is no additional weight back there.
  18. Nov 14, 2017 at 6:48 AM
    GYOAZ
    Gary
    Tucson, AZ
    Thanks for all the input. Is that 3/4 without the Dakar AAL? Will the AAL add more height or just extra weight capacity,
  19. Nov 14, 2017 at 6:49 AM
    geekhouse23
    Without.
    Also, from Wheeler's website:
    "Two extra leafs made specifically for the CS047 leaf spring set that raises the spring height by 15mm and increases the spring rate for increased heavy load stability."
    TacoTRD78 likes this.
  20. Nov 14, 2017 at 6:55 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    As someone that went with the dakars originally in the same situation of mostly empty bed and occasional towing, I ended up switching them out for some allpro standard leafs and sos concepts shackle flip with longer shackles to get my ride height. The dakars were just too stiff for daily driving for me.
    Bonus for you, I am selling this setup and am going to Tucson this weekend for a wedding. I'd be happy to deliver it all for you. Here's the links to my sale threads. Pm me with questions.
    Leafs
    https://www.tacomaworld.com/threads/allpro-standard-leaf-springs.511945/
    Flip kit
    https://www.tacomaworld.com/threads/sos-concepts-shackle-flip-kit-and-shackles.511941/
    Also have some extended stainless rear brake lines for $50
