Dakota Universal Speedo Corrector: An easy alternative to the HyperTech
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EatSleepTacos, Aug 1, 2019.
  1. Sep 3, 2020 at 11:05 AM
    #61
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    Thanks Jeff, appreciate the explanation. Glad to know what was going on. I tapped into the same wire in position #6.
    Anyhow, I pulled the device today, spliced the wire back together, and I had been running it without a correction factor in the interim - in the event that the signal was getting used by something (which it looks like it was).
    I've installed a hypertech unit that I bought new off ebay for $168. Compared to the Dakota and materials to install, it's about a $40 difference.
    I am about to go road test it.
    #61
  2. Sep 3, 2020 at 11:10 AM
    #62
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    I’m curious to see if it works. The way I understand it, the hyper tech is just essentially a plug and play version of the Dakota, meaning it just intercepts the speed input and modifies it, which means it wouldn’t work. But I could very well be wrong. I’m learning a lot from this thread.
    #62
    Bwthomas77[QUOTED] likes this.
  3. Sep 3, 2020 at 3:32 PM
    #63
    Bwthomas77
    North Carolina
    Hypertech unit works well. The model number for the 2012 Tacoma is 730117.
    I didn't get the truck over 45 mph on the way to work, but compared to my GPS the speed is tracking within 1mph difference, the speedo is now reading a touch fast.
    Programmed the unit using the software that came by DVD. Using the stock tire size from my door jam and current tire size, it gave a correction factor of 1.07. Software will also calculate if you have non-stock gearing, mine are stock but, it's an option.
    Because tires are about 4 years old I'm guessing the diameter is a little smaller and I probably need a correction factor of more like 1.05-1.06 to be 100% accurate. I'm going to wait until I test it on the highway at higher speed to see if it is very far off before messing with it though.
    I did leave the USB cable plugged in and routed down to behind the coin drawer near the fuse box so I could reprogram if necessary with my laptop and not have to disassemble my dash again.
    As for the actual install - it is stupidly easy. There is a small unit that is programmed via the computer, it plugs into a circuit board, which has a slot for the wire harness and a second wire harness that plugs into the instrument cluster. There is plenty of room behind the instrument cluster to fit everything.
    Thanks everyone. Hopefully I didn't mess anything up sending the modified signal to my ECU and ABS. I did read in the Dakota instructions that the signal should not be going to ABS... That said, I don't appear to be having any issues.
  4. Sep 20, 2020 at 4:48 PM
    #64
    Canyon lands
    Canyon lands Well-Known Member
    Bill
    Colorado
    2015 red Tacoma TRD off-road
    3” lift, leer topper, James Baroud tent, Lund bull bar, 4 wheel running boards, Pioneer stereo, fosgate speakers, amp, bed slide, Thule racks, road shower
    Damn, really appreciate the work and info you guys put into this thread. Hoping I got this all correct, but, it seems that the Hypertech would be the way to go for my 2015 4.0, automatic.
  5. Sep 20, 2020 at 6:01 PM
    #65
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you read back a little bit on this page, it appears it won’t work on 2012-2015.
  6. Sep 20, 2020 at 6:14 PM
    #66
    Canyon lands
    Bill
    Colorado
    After reading
    Bwthomas77 reply a couple above, it sounded like he had success with the hypertech
  7. Sep 20, 2020 at 6:19 PM
    #67
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    My apologies, I skimmed your reply. I thought you said you were going to try the Dakota. You’re correct that the hyper tech will work well for you.
  8. Sep 20, 2020 at 6:22 PM
    #68
    Canyon lands
    Bill
    Colorado
    Didn’t mean to yell at you in caps! Couldn’t figure out why it was bold caps:boink:
  9. Sep 21, 2020 at 9:07 AM
    #69
    Bwthomas77
    North Carolina
    yep, definitely want to go hypertech for your 2015. Mine is now spot on.
  10. Sep 22, 2020 at 6:10 PM
    #70
    Canyon lands
    Bill
    Colorado
    Thanks everyone for a lot of great info. Definitely a learning curve from the diesel world!
    outxider likes this.
  11. Apr 7, 2022 at 5:27 PM
    #71
    Neptune
    Neptune Member
    Donner Summit
    2009 AC 4x4 SR5 MT
    New frame, King/TC, this and that
    Just installed the Dakota Digital SGI-100BT per the OP's directions on my 2009 SR5 v6 6-speed with 4.88s and 34s. Write-up matched perfectly for my truck, and the now corrected speedo is spot on! The bluetooth version and the DD app are great - makes calibration super easy as the app includes a GPS speedometer. Thanks so much for your write-up OP!
  12. Apr 7, 2022 at 5:41 PM
    #72
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s great to hear! Thanks for the feedback and I’m happy to have helped out.
    Torspd likes this.
  13. Jun 22, 2023 at 7:47 AM
    #73
    Wolftaco
    Wolftaco Well-Known Member
    Luke
    Philadelphia, PA
    06 Overland Build
    Old Man Emu, Leer 100cc, Blacked Out Billet Grill, ARB Bumber, Warn M8000-s winch with under hood solenoid relocation, Stubbs HD Standard Sliders, diff breather
    Subbed, just ordered Dakota SGI - 100BT for $109 on Amazon for my 2006 Tacoma 4.88 on 34s. Thanks to the OP and @Neptune for confirming this setup works.
    Torspd and EatSleepTacos[OP] like this.
  14. Jul 4, 2024 at 2:41 PM
    #74
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Old thread bump
    Do you recollect the settings you selected with the app interface? And which output did you use? My speedo is stuck at 30mph. Changing the frequency has dramatic effects.
  15. Jul 2, 2025 at 9:15 AM
    #75
    airkewled
    airkewled Well-Known Member
    Kevin
    Moab
    2006 Tacoma DCSB
    Installed SGI-100BT on 2006 DCSB Automatic 4x4 TRD. Used purple, white/black for power and ground, red/yellow for my speed sense, out-2 for speed signal out. Left all the settings default (L/L, 33k, pull-up, etc) only adjusting the calibration. Found that putting the unit into adjust mode while driving and just using the +/- buttons was the easiest to dial it in. Works great. I *did* try the Hypertech unit as well which *did not* work for my truck.
    EatSleepTacos[OP] likes this.
