Dakota's Yota Build (Long Travel, Chevy 63s, and BS)
Discussion in '2nd Gen. Builds (2005-2015)' started by dakotasyota, Mar 6, 2014.
  1. Nov 8, 2016 at 2:04 PM
    #3441
    SjTacoSharks
    SjTacoSharks Well-Known Member
    Larry
    Boise, Idaho
    09 DCSB SR5 Sport
    I was thinking more along the lines of Bernie....
    ChadsPride likes this.
  2. Nov 8, 2016 at 2:06 PM
    #3442
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I want the pony I was promised!
  3. Nov 8, 2016 at 2:09 PM
    #3443
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  4. Nov 8, 2016 at 2:14 PM
    #3444
    dakotasyota
    dakotasyota [OP] Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Take it easy guys, I forgot about COC lol
    AR15xAR10 and ChadsPride like this.
  5. Nov 8, 2016 at 2:23 PM
    #3445
    Speedytech7
    I've never read the COC...
  6. Nov 10, 2016 at 10:28 AM
    #3446
    dakotasyota
    Dakota
    Ellensburg, WA
    Did some more stuff to the other plano . Nice to have these things out of the backseat.
    NorthwestCruiser and ChadsPride like this.
  7. Nov 10, 2016 at 10:30 AM
    #3447
    ChadsPride
    Sponsored by TacomaWorld.com
    Awesome!!!!!!!!
  8. Nov 11, 2016 at 4:05 PM
    #3448
    AR15xAR10
    Dakota.
    Just did my power steering flush.
    Open hood. Leave key on acc so wheel is unlocked. Jack the front end up so the front tires are off the ground. Suck out all the old fluid from the reservoir. Then cycle the steering wheel from lock to lock 15-20 times (this will push the fluid out of the lines into the reservoir. Suck all that out and repeat until no more fluid is present. Then, refill the reservoir half way with your fluid of choice. I went with Mobil 1 synthetic ATF (which is what i've seen some of the first gen guys go to). Cycle the wheel back and forth 15-20 times slowly with someone watching the fluid so it doesn't puke out (if you put too much in). You will see that cycling the wheel sucked a bunch of fluid down into the lines. Add a little more fluid and repeat until the fluid level is no longer going down. Then, start the truck for about 10 seconds. You'll see that the fluid level went down again a tiny but (this is because the pump actually turned on and started to cycle). If need be. Top the fluid off to cold max. Go for about a 5-10 mile drive and do lots of turning and cycling of the wheel to get the fluid warm so you can check the hot level. This will also get rid of any bubbles in the lines.
  9. Nov 11, 2016 at 4:11 PM
    #3449
    AR15xAR10
    Top off again if needed after driving.
    I did not have to. I went to chickfila and came back and the fluid level never changed :thumbsup:
  10. Nov 11, 2016 at 6:49 PM
    #3450
    dakotasyota
    Dakota
    Ellensburg, WA
    Hell yeah thanks dude! I will do that.
    Also, chicfila is life!
    AR15xAR10[QUOTED] and ChadsPride like this.
  11. Nov 11, 2016 at 6:56 PM
    #3451
    AR15xAR10
    Chickfila is bae.
    But i'm not as basic as @Boogyman so i don't eat there at least once a day. More like once a week.
  12. Nov 11, 2016 at 6:57 PM
    #3452
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    I never go. It's too far away from me
  13. Nov 11, 2016 at 7:35 PM
    #3453
    AR15xAR10
    Likely story.
  14. Nov 11, 2016 at 7:46 PM
    #3454
    Boogyman
    Phoenix
    Corpus Christi, TX
  15. Nov 11, 2016 at 7:47 PM
    #3455
    AR15xAR10
    Don't be a pussy. Its not as if your truck doesn't already have 937,000 miles on it already anyway
    ChadsPride and dakotasyota[OP] like this.
  16. Nov 11, 2016 at 7:48 PM
    #3456
    Boogyman
    Phoenix
    Corpus Christi, TX
    I don't want to sit in my truck that long on the highway
    ChadsPride and AR15xAR10[QUOTED] like this.
  17. Nov 11, 2016 at 7:49 PM
    #3457
    AR15xAR10
    Chick
    Fil
    A
    Is
    Lyfe
  18. Nov 11, 2016 at 7:50 PM
    #3458
    AR15xAR10
    So you mean to tell me if i send you a chickfila gift card, you'll complain? o_O
  19. Nov 11, 2016 at 7:50 PM
    #3459
    Boogyman
    Phoenix
    Corpus Christi, TX
    I wish I had the time to go every day
    ChadsPride and AR15xAR10 like this.
  20. Nov 11, 2016 at 7:50 PM
    #3460
    Boogyman
    Phoenix
    Corpus Christi, TX
    Nah
