Dakota's Yota Build (Long Travel, Chevy 63s, and BS)
Discussion in '2nd Gen. Builds (2005-2015)' started by dakotasyota, Mar 6, 2014.
  1. Nov 3, 2015 at 3:09 PM
    #1281
    dakotasyota
    dakotasyota [OP] Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Reasons why I'm mad at life:
  2. Nov 3, 2015 at 3:12 PM
    #1282
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Can you cut the extension on your bump stops and weld them back up shorter so you can get more travel?
    What do your leaf springs look like sitting on your bump stop?
  3. Nov 3, 2015 at 4:57 PM
    #1283
    dakotasyota
    Dakota
    Ellensburg, WA
    Yeah I can. I can see the two lines on the shock. Upper is where it's at when flexing. The lower more defined line must be full compression. Looks like the superbumps compress bout 3/4".
    So it looks like I could shorten it 1.25" and still be safe. That would be nice. Would give me approximately 3" before I hit bumpstop. Still though... that's not that much :mad: My bump plates are worn down to bare metal... that should give you an idea how much I hit them.
    My leafs are almost flat at full stuff. I don't mind a little bit of negative arch on the 63s... they're such a flat leaf to begin with.
    QUESTION: Would a 2" stroke air bump be a good idea?? If I'm gonna hit bumpstops so often it would probably be nice to enjoy it a little more.... Or do I not have enough uptravel to properly use air bumps? Where's my LT guys at?!
    MTopp likes this.
  4. Nov 3, 2015 at 4:58 PM
    #1284
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    I know nothing
    MatthewMay1 and dakotasyota[OP] like this.
  5. Nov 3, 2015 at 5:53 PM
    #1285
    dakotasyota
    Dakota
    Ellensburg, WA
    But you're here for morale support! That's what counts!
  6. Nov 3, 2015 at 5:54 PM
    #1286
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    This is all i see reading this^
  7. Nov 3, 2015 at 5:55 PM
    #1287
    AR15xAR10
    My bump stops are getting worn too...but for the wrong reasons
    (saggy leafs)
  8. Nov 3, 2015 at 5:58 PM
    #1288
    dakotasyota
    Dakota
    Ellensburg, WA
    Aww too much hoonign on stock leafs with da cap
    AR15xAR10[QUOTED] likes this.
  9. Nov 3, 2015 at 6:01 PM
    #1289
    AR15xAR10
  10. Nov 3, 2015 at 7:16 PM
    #1290
    SjTacoSharks
    SjTacoSharks Well-Known Member
    Larry
    Boise, Idaho
    09 DCSB SR5 Sport
    Dakota you should just stop being a pussy and SAS that bitch
    dakotasyota[OP] and AR15xAR10 like this.
  11. Nov 3, 2015 at 7:22 PM
    #1291
    AR15xAR10
    On 44s
    dakotasyota[OP] likes this.
  12. Nov 3, 2015 at 7:22 PM
    #1292
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Math problems... :(
  13. Nov 3, 2015 at 7:39 PM
    #1293
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I wouldn't trim too much on that bump spacer. They compress more than you think. Slide that little rubber washer up on your shock to the shock body, go for a good romp and try to bottom the rear out hard, maybe flex once good too. You'd be suprised how much those superbumps compress when smashed on. Heres the best pic I could find, and this is static weight of the truck too on a jack, imagine what that would compress to when the momentum weight of a hit comes down on it.
    I dont have much up travel either. I'll take pictures of my setup tomorrow with no weight in the bed. I have the pelfrey kit with 2.0's air bumps. They have maid a big difference in what little uptravel I've got when i'm weighed down on trips.
    Pirhett likes this.
  14. Nov 4, 2015 at 7:15 AM
    #1294
    dakotasyota
    Dakota
    Ellensburg, WA
    Lol speaking of math problems I wanna know your final drive ratio :drevil:
    Oh wow! Dan at wheelers was telling me they compressed that far but I was shocked. Ok will go attempt to jump ;) for science.
    I am very interested in seeing your setup. What are you running for psi in the 2.0s?
  15. Nov 4, 2015 at 7:17 AM
    #1295
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Thursday.
  16. Nov 4, 2015 at 7:18 AM
    #1296
    SconnieHailer
    Marc
    105 psi. But 80-90 is probably better for a empty bed. I'll take some pics tonight
  17. Nov 4, 2015 at 10:19 AM
    #1297
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    low.low:stupid.low :notsure:
    the crawl box is a 4.7 reduction. the stock t-case low is a 2.3 or 2.8 reduction.
    In compound low in 6th gear it won't go faster than 15mph if that.
  18. Nov 4, 2015 at 12:51 PM
    #1298
    dakotasyota
    Dakota
    Ellensburg, WA
    Yeah I was thinking 80
  19. Nov 4, 2015 at 12:51 PM
    #1299
    dakotasyota
    Dakota
    Ellensburg, WA
    Hell yes :drool:
  20. Nov 4, 2015 at 1:01 PM
    #1300
    dakotasyota
    Dakota
    Ellensburg, WA
    Did it for you 229.68:1
