Dakota's Yota Build (Long Travel, Chevy 63s, and BS)
Discussion in '2nd Gen. Builds (2005-2015)' started by dakotasyota, Mar 6, 2014.
  1. Nov 28, 2015 at 3:16 PM
    #1521
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    The bed cubby keeps it pretty protected. It's not been in there too long at this point so time will tell.
    dakotasyota[OP] likes this.
  2. Nov 28, 2015 at 6:28 PM
    #1522
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    37's and crawlin gunna break sum shiiiit.....
  3. Nov 29, 2015 at 6:54 PM
    #1523
    dakotasyota
    dakotasyota [OP] Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    TO-DOS:
    • Replace driver & passenger front wheel bearings (received)
    • Remove passenger CV and install new boots (recieved)
    • Install new OE F*CKING M alignment cams on passenger side (just need rear)
    • Shorten Tie Rod End Extensions by 1/2"
    • Call Total Chaos on Monday to see about fixing driver side LCA
    • Install Pelfrey Blue Seas mounting plate (ordered)
    • Clean up rats nest and wire up Blue Seas (recieved)
    • Wire up and mount ARB Compressor (recieved) :yay:
    • Fix rattling cat
    • Replace gas cap that keeps throwing CEL
    • Get a real alignment and tack the cams
    • Wash/clay bar/seal/wax truck for winter prep
    Truck is all put back together.... minus a pin holding in the rear of the LCA lol... I messed around with my compressor some more. I need to make a mini heat resistant hose for it that will run into the back of the cubby. @northwesttaco how did you make your hose heat safe?
    Retorqued everything since it was hand loose :eek: It's a real pain in the ass to retorque the uniball because you have to move the CV out of the way...
    lonewolf1911 likes this.
  4. Nov 29, 2015 at 7:04 PM
    #1524
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    I had a shop make one for me. Not sure exactly what they used but I can find out if you'd like
  5. Nov 29, 2015 at 7:04 PM
    #1525
    dakotasyota
    Dakota
    Ellensburg, WA
    Also I need your guys advice... I can't figure out why my cat is rattling... must be the heat shield but the bolts are so corroded I cant tighten it more. Think I should lay a few tacks between the two pieces of heat shield? I HATE the sound of it rattling... especially when I'm trying to talk to the pretty gal at the coffee stand in the morning and it echos off the wall :frusty:
    NorthwestCruiser likes this.
  6. Nov 29, 2015 at 7:04 PM
    #1526
    dakotasyota
    Dakota
    Ellensburg, WA
    Hmmm
  7. Nov 29, 2015 at 7:05 PM
    #1527
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Weld it. What's it matter?
  8. Nov 29, 2015 at 7:06 PM
    #1528
    dakotasyota
    Dakota
    Ellensburg, WA
    I like your thinking brotha!
  9. Nov 29, 2015 at 7:09 PM
    #1529
    MatthewMay1
    Matthew
    Lone Star Republic
    That's what I'm here for! I got coffee from a pretty girl today too.
  10. Nov 29, 2015 at 7:14 PM
    #1530
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Mine does the exact same thing. It's annoying as shit.
  11. Nov 29, 2015 at 7:47 PM
    #1531
    dakotasyota
    Dakota
    Ellensburg, WA
    I'm in love with my coffee gal... :(
    Yeah freaking stupid!
    Sje1124[QUOTED] likes this.
  12. Nov 29, 2015 at 8:07 PM
    #1532
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Take the fucking heat shield off.
  13. Nov 29, 2015 at 8:10 PM
    #1533
    dakotasyota
    Dakota
    Ellensburg, WA
    That seems retarded...
    nerd.
  14. Nov 29, 2015 at 8:15 PM
    #1534
    AR15xAR10
    Its not necessary. I've seen people coat hanger them on, i've seen people punch the bolts out with a screw driver and throw the heat shield away. Both fix the problem.
  15. Nov 29, 2015 at 8:22 PM
    #1535
    AR15xAR10
    My buddy's 4cly has had no heat shield for 2 years now...and they're the same cats as our trucks.
    There is a heat shield above it bolted to the body...the heat shield on the cat itself is primarily to protect it from starting fires when parked in tall grass or weeds...
    Is it necessary? Probably.
    But are emissions necessary? Probably not, global warming is already in full force. We fuct
  16. Nov 29, 2015 at 8:32 PM
    #1536
    dakotasyota
    Dakota
    Ellensburg, WA
    LOL
  17. Nov 29, 2015 at 9:09 PM
    #1537
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    emissions are required here.. :(
  18. Nov 29, 2015 at 9:15 PM
    #1538
    dakotasyota
    Dakota
    Ellensburg, WA
    Not here :D #WestSideSucks
    AR15xAR10 likes this.
  19. Nov 29, 2015 at 9:16 PM
    #1539
    AR15xAR10
    EWWWWWWWW!!!!!!! Commies!
  20. Nov 29, 2015 at 9:16 PM
    #1540
    MatthewMay1
    Matthew
    Lone Star Republic
    Global warming my ass. This has been the wettest year in history, and water is all you need!
