Damaged nut on O2 sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by Petrol, Jun 7, 2014.
  1. Jun 7, 2014 at 1:56 PM
    Petrol
    Petrol [OP] Well-Known Member
    Central Va.
    Tacoma
    Finally broke down and purchased a new upstream Air/fuel sensor (sometimes referred to as an O2 sensor ) Put Kroil penetrating oil on the studs the night before and went to take it off this morning.
    One of the well rusted nuts rounded off and of course it was the one that was the hardest to reach. I couldn't grab it with visegrips or drive a splined socket on it.
    I was able to use a cut-off wheel on a Dremil tool to cut a notch in the nut. I then used a screwdriver and a hammer to rotate the nut just enough to break it free. I was able to force a 6 point socket on it and get it all the way off.
    Thought I'd share that technique.
    Anyhow, new Denso sensor in place, no more Check Engine Light, truck runs better - All is well
  2. Jun 7, 2014 at 3:23 PM
    AKADriver
    AKADriver Active Member
    NoVA
    03 base 2WD
    I'm dreading ever having to do this job for the same reason. The nuts on mine are just round. Maybe if I'm lucky they'll just disintegrate and fall off like they did on my 4Runner!
  3. Jun 7, 2014 at 4:19 PM
    Petrol
    Central Va.
    Tacoma
    Not much room up there. it wouldn't be that tough if there was just a bit of clearance. The Dremil tool really did the trick!
  4. Jun 7, 2014 at 4:27 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    damn that sounds like a 30 minute project that turned into a few hours project. lol. i just ordered 2x new o2 sensors. hopefully my install goes a little more smoothly.
  5. Jun 7, 2014 at 6:48 PM
    Petrol
    Central Va.
    Tacoma
    It was more like a 45 minute project but I got lucky when I was able to break it free!
    Well 50 minutes if you count the beer.
    I'd rather be lucky than good any day of the week !
  6. Jun 18, 2014 at 1:11 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
  7. Jun 18, 2014 at 2:41 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I broke the upper stud off (accidentally) and just used a hose clamp to hold that side of the O2 sensor on. It works and I'm not worried about it, it should last until I can afford a new header.
  8. Jun 18, 2014 at 6:53 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    ^My upper stud broke as well but I just modified an exhaust u-bolt to hold that side of the O2 down.
  9. Jun 21, 2014 at 11:56 PM
    Tahokie
    Tahokie Member
    2000 Tacoma 4x4 Xcab SR5 3.4
    I did my upstream today. Some how managed to thread the bolt out when the lower nut hung up. Couldn't believe I didn't snap it!! Was able to thread it back in and got the nut tightened back up. The downstream will be a different story. I can feel the nuts are rusted to shit! Can't see because the heat shield. CEL is off and running better than ever. Thanks to TW for helping w the ridiculous location of the plug over the tranny!!! Would have never thought to go in thru the gear shift.
