DAMN Jetta won't start!!
Discussion in 'General Automotive' started by DeeKay21, Jan 24, 2009.
  1. Jan 24, 2009 at 8:21 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
  2. Jan 24, 2009 at 8:22 PM
    Monkeysuncle
    Kevin
    Florida
    WW Firefighter, I'll PM You.
  3. Feb 1, 2009 at 3:05 PM
    Monkeysuncle
    Kevin
    Florida
    Sorry it took so long to get back to you, the answer I got was GROUNDS. Make sure all battery to chassis grounds are secure and clean. From what my buddy said, going back to air cooled VW's, the grounds have always been an issue and a good place to start. He adds grounds to the cars he owns and drives. It sounds simple I know, but thinking back to when I had a 1971 VW Bus, (5 years ago) I did add a ground strap from the starter to the frame and also I added an inline relay between the starter/battery because the relay only needed milli amps to trun the starter once the key was turned. ( in my case remember the key was up front, the battery and starter were at the rear being an air cooled rear engine) but he said to me that is a good place to start. Kevin
  4. Feb 1, 2009 at 3:08 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Sounds like loose battery or starter cable to me.
  5. Feb 1, 2009 at 3:10 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    Hey firefighter, is the no start more often when it is cold out?
  6. Feb 1, 2009 at 3:10 PM
    Monkeysuncle
    Kevin
    Florida
    I was going to add that also.
  7. Feb 1, 2009 at 3:13 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    is it a carb engine? it could be something with the carb if it is.
