Damn Toyota TPMS!
Discussion in 'Wheels & Tires' started by piercedtiger, Sep 9, 2008.
  1. Jan 30, 2012 at 6:47 PM
    #121
    A fire inside
    A fire inside Member
    If you guys are Costco members and need to get new sensors programmed, swing by the tire center. I can't speak for other locations but I can reprogram new sensors and write them to the ECU in under 5 mins. If someone pulled up to the shop I would have no issues reprogramming them for free.
  2. Jan 31, 2012 at 5:01 AM
    #122
    98tacoma27
    Ben
    Not Beech Creek
    I think you have to ground the blue (teal) wire.
  3. Oct 31, 2012 at 10:08 AM
    #123
    Goblin
    Goblin TSB 0305-08 Rev2 & TSB 0373-09 DONE
    VA
    09 SR5 TRD OFF ROAD
    STOCK TRD 4X4 OR DC
    Anybody have a solution to an 09? I had one fail today and refuse to pay $175 to replace it. I find them on the web for $35 but other post say aftermarket will not work. I prefer to disable the light all together.
    On another note; anyone have a sensor for sale? I'm talking reasonably priced. Thx.
  4. Oct 31, 2012 at 8:04 PM
    #124
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Be patient and you will find one here on TW. There is a set for sale almost every week in the marketplace. Maybe post a WTB thread there aswell. They usually go for $80-120 for all four.
  5. Nov 14, 2012 at 6:34 AM
    #125
    Me Taco Too Much
    Me Taco Too Much Good Job!
    Dennis
    Apache Junction, Arizona
    06 PreRunner
    Just let the light blink!
    take your dash apart and rip the friggin light out. Im sure there is a sticky here for removal....
    Who cares, fuck the TPMS I check my tires regularly.
    TPMS is for lazy ass fuck sticks that don't even know how to drive a fricking car.
    woops sorry for the mini rant.
  6. Nov 14, 2012 at 1:34 PM
    #126
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Do you realize I stopped worrying about this about 4 years ago? :rolleyes:
  7. Nov 20, 2012 at 10:48 PM
    #127
    jeffallen29
    jeffallen29 Well-Known Member
    jeff
    northeast Tennessee
    Ok guys i have an 06 SR5 and Im removing the stock 16s and replacing them with a set of 2012 TRD Sport 17" wheels and tires.The new wheels and tires im buying have the factory TPMS sensors still as they are simply Takeoff wheels and Im wondering If my 06 will work with these new 2012 TPMS sensors or will the new ones need to be recalibrated to work?
  8. Nov 20, 2012 at 10:54 PM
    #128
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    They need to be programmed into the ECU.
    Any decent tire shop can do it quickly.
  9. Aug 14, 2013 at 8:04 PM
    #129
    vanillion
    vanillion Well-Known Member
    Canadia
    09 trd offroad
    superduty axles swap, custom 3 link front, chevy 63's rear
    Does this actually work if the sensors are not nearby? or does it just reset the tire pressure when the sensors are still on the truck?
  10. Aug 14, 2013 at 8:16 PM
    #130
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Pressure vessel
  11. Aug 14, 2013 at 8:40 PM
    #131
    Rich91710
    Rich
    Los Angeles
    08 Base
    A.D.'s suggestion won't work anyways... with or without the sensors.
    Toyota did not make it that easy to disable the system.
    The TPMS is a federally-mandated item and there are legal liabilities for disabling it (thank you Ford and Firestone).
    The dealerships that are disabling the system using Techstream on the '12/'13 trucks are sticking their necks out... if they get caught in a sting operation, the service departments are going to be in trouble.
  12. Aug 15, 2013 at 3:54 PM
    #132
    vanillion
    Canadia
    09 trd offroad
    So the best option is to pull the plug on the TPMS unit behind the stereo? Or will this cause a check engine light?
  13. Aug 15, 2013 at 9:36 PM
    #133
    Rich91710
    Rich
    Los Angeles
    08 Base
    Pulling the plug won't quench the light either.
    Depending on the year, you need to pull the wire and either ground it or apply +5v to it. Some have run it to 12v... I wouldn't do that without a resistor, it triggers a TTL circuit.
  14. Aug 15, 2013 at 10:20 PM
    #134
    OZ-T
    Peter North
    British Columbia
    Pressure vessel
  15. Aug 15, 2013 at 11:18 PM
    #135
    OZ-T
    Peter North
    British Columbia
  16. Aug 18, 2013 at 6:33 PM
    #136
    SamSin
    SamSin I can resist everything except temptation
    Jersey Sam
    NJ
    Longbed 4x4 SR5
    Oil Free AFE Pro Dry S Air Filter, Nitrogen filled tires, Tonno Pro Tri-Fold Hard Tonneau Cover BLU Logic Handsfree
    To all those who have a problem with their tire pressure sensor dash light.
    My TPMS would not go out no matter what I did. I figured I would give it one more try as a last resort, before taking the dash apart and cutting any wires.
    1. Turn the ignition on, push the TPMS switch until the light goes out.
    2. Turn the ignition off
    3. Turn the ignition back on and even though the light is out . . . hold the TPMS switch until the Tire Pressure light flashes 3 times and shut the ignition off again.
    My TPMS light would come on exactly at 2 miles every time I reset the switch for over a year. I drove for 10 miles after doing the above and it did not come back on since the reset. [​IMG]
    I hope this post helps.
  17. Aug 18, 2013 at 8:45 PM
    #137
    Rich91710
    Rich
    Los Angeles
    08 Base
    Old reply I know, but America's/Discount did the same for me for free.
  18. Oct 12, 2013 at 8:09 PM
    #138
    tractng
    tractng Well-Known Member
    Does the tpms light blink like a christmas light? I am looking to get aftermarket rims and don't care about transferring them over. I read about the stock steelies don't work with other rims anyways?
    On m 350z years ago, the blinking didn't bother me.
  19. Oct 12, 2013 at 8:15 PM
    #139
    Rich91710
    Rich
    Los Angeles
    08 Base
    If you remove the sensors, it will only blink for a minute or so, then remain on solid.
  20. Oct 12, 2013 at 9:44 PM
    #140
    tractng
    You mean unplugging the wire inside the cabinet?:D
