Damp Carpet...
Discussion in '1st Gen. Tacomas (1995-2004)' started by emglishe30, Sep 15, 2008.
  1. Sep 15, 2008 at 2:27 PM
    emglishe30
    emglishe30 [OP] Well-Known Member
    NJ
    2010 SR5 Base 4x4 DCSB
    Pioneer Touch Screen, Sub, Diode Dynamics SS3 Sport amber fogs, Oem skid plate, led accent lights, led 3rd brake, 2011 color matched honeycomb grill. Plasti dipped pieces.
    I was cleaning out my truck and noticed that the passenger side floor was wet. Is it possible that the drain for the AC is clogged causing it to build up on my floor?
  2. Sep 15, 2008 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its very likely. Its pretty easy to get to. Check it, and post back. :)
  3. Sep 15, 2008 at 6:37 PM
    emglishe30
    NJ
    haha yeah I will get right on that, one question anyone have a clue where its at...
  4. Sep 15, 2008 at 6:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, sorry. Its under the dash on the passenger side, near the center. Under the hood you can see where it comes out of the fire wall. :)
  5. Sep 16, 2008 at 1:49 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I had the same problem a while back. The tube came out the firewall and was turned upward. I just turned it back down and no more wet carpet.
  6. Sep 16, 2008 at 10:38 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    also if you notice any smell or the windshield fogs often it can be a heater core leak (not really known to happen on toys but still)
  7. Sep 16, 2008 at 11:18 PM
    nktrnl
    nktrnl Active Member
    I had a bad body seem on my 96. You could see the water drip in right between the body panels behind the carpet. I siliconed the crap out of the area in the engine compartment from the fender to the firewall. It seemed to work.
  8. Sep 19, 2008 at 3:37 PM
    emglishe30
    NJ
    I looked for anything that would look like a hose or drain tube and came up with nothing, if someone could take a pic of what I am looking for that would be great..
  9. Sep 22, 2008 at 7:33 PM
    Fuzzyman81
    Fuzzyman81 The New Guy
    Jax, FL
    04 PreRunner TRD
    Turned upward actually inside the cab?? Like under the glovebox area? I am also having this issue...
  10. Sep 22, 2008 at 7:38 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    The tube is in the engine compartment, on the passenger side. It comes straight out an inch or 2 and makes a 90* bend. It(the tube) is open on the end. I think that's a drain for the condensor. When I turned the tube to point down, I stopped getting wet spots on the carpet.
  11. Sep 28, 2008 at 6:28 AM
    Fuzzyman81
    Jax, FL
    04 PreRunner TRD
    Ok - Well I checked the tube and it's pointing down... but still getting damp carpet... any other ideas where it may be coming from??? Is there a way to "flush" that pipe and see if it's clogged?
  12. Sep 28, 2008 at 6:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Disconect it and blow some ait thru it. Is it going all the way thru the fire wall?
  13. Sep 28, 2008 at 6:45 PM
    Fuzzyman81
    Jax, FL
    04 PreRunner TRD
    Don't know... didn't get too into it just happened to look at it and see the 90 degree pointing downward.
  14. Sep 28, 2008 at 6:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is it pointing downward in the cab, or in the engine bay?
  15. Sep 28, 2008 at 6:52 PM
    Fuzzyman81
    Jax, FL
    04 PreRunner TRD
    engine bay. I couldnt see anything in the cab. (I am a bigger guy so it's alittle harder for me to see under the dash.. lol )
  16. Sep 28, 2008 at 7:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, you could try and push some wire up into it and hopefully break what ever is blocking it. :confused:
