Dangers of brake drag?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tathambenjamin, Mar 12, 2020.
  1. Mar 12, 2020 at 7:51 PM
    tathambenjamin
    tathambenjamin [OP] Well-Known Member
    ben
    2008 4Runner SR5
    -2.5/1.5 spacer lift -270/65/17 Cooper AT3
    Have had passenger side drum dragging for a couple days due to e brake cable being fubarred. Cant get shoe to fully release. Today noticed my wheel and drum had really heated up. Had rear wheel lock up pulling out of parking spot.
    Am I gonna damage anything if I wait til Sunday to pull the cable off?
    Am I destroying my brake shoes or drum by driving 10 miles a day with all the extra drag?
    Am I cooking the oil in the rear diff?
    Thanks guys!
  2. Mar 12, 2020 at 7:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Its not good, can you adjust the cable off? Or back off the shoes?
    If you pull the plug off, its a pain, but you can back off the shoes slowly and it should get you to the weekend.
  3. Mar 12, 2020 at 7:55 PM
    tathambenjamin
    ben
    2008 4Runner SR5
    I can probably pull the console off tomorrow and take off the tensioner nut. I am assuming that is the easiest way to get some cable play?
  4. Mar 12, 2020 at 7:56 PM
    tcjacado
    tcjacado Well-Known Member
    Careful you don't set fire to the truck driving it
  5. Mar 12, 2020 at 7:58 PM
    tathambenjamin
    ben
    2008 4Runner SR5
    ok? Hadn't really considered anything involved a combustion risk... sarcasm?
  6. Mar 12, 2020 at 7:59 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Do these have the little star wheel behind the inspection cover? Usually you can spin those to back off the shoes.
  7. Mar 12, 2020 at 7:59 PM
    tcjacado
    No sarcasm... dragging brakes can catch fire
    06Tacooo likes this.
  8. Mar 12, 2020 at 8:00 PM
    Bishop84
    Especially with a touch of an axle seal leak haha.
    06Tacooo and tcjacado[QUOTED] like this.
  9. Mar 12, 2020 at 8:01 PM
    tathambenjamin
    ben
    2008 4Runner SR5
    Good to know! Had never heard that, but it makes sense I suppose. I will try to release the cable tension before I drive it to work tomorrow!
    tcjacado[QUOTED] likes this.
  10. Mar 12, 2020 at 8:02 PM
    tathambenjamin
    ben
    2008 4Runner SR5
    It does have the star wheel, but when I tried to crawl under to adjust the ebrake cable in the Fall, I had a hell of a time getting it to turn through the window with a flathead scredriver. I adjusted it when I did the rear shoes and had the drum off.
    0xDEADBEEF[QUOTED] likes this.
