Darn it, stuck bolt, lower front strut
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wild Card, Sep 7, 2012.
  1. Sep 7, 2012 at 6:57 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    If you unbolt your lower ball joint you could free up some work space and even be able to scoot the CV a little further out of the way
  2. Sep 7, 2012 at 6:59 PM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    Also you said you don't have a big hammer that could be why it wont break loose. You need a small sledge and a punch or an impact. A big hammer/sledge will work wonders.
  3. Sep 7, 2012 at 7:02 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Again, hit it with a can of compressed air ($4 at wallmart or local computer shop). Hold the can upsided down and spray the bolt (get some good ventilation). The metal will contract and break the rust.
    Then try the BFH.
  4. Sep 7, 2012 at 7:10 PM
    Wild Card
    Wild Card [OP] Truck yeah!
    Doug
    Portland, MI
    02 TRD SR5 4x4 V6 Xtra Cab 5spd
    6" Deckplate. Trimmed TB gasket. Grey wire. Disable DRL's.
    Dang, I'm just afraid of bending that bracket even more so. But, I suppose it's worth a try. I'll pick up some compressed air while I'm at the store tomorrow.
    As I have said several times now, all the hammers have done is BENT my lower strut-mounting bracket. Which is bad. Because now I have to bend it back. And all of this bending fatigues the metal. Which makes it weaker. In a spot that supports a whole lot of weight. So, I'll give the hammer a couple more goes, but not much more. This truck needs to be back in working order before Monday morning. Can't go breaking things I don't need to break.
  5. Sep 8, 2012 at 2:51 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    How the hell did your a-arm move up and down if the bolt it that rusted in there? that's crazy.
  6. Sep 8, 2012 at 4:16 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Impact that shit out. Easy
  7. Sep 8, 2012 at 4:38 AM
    Wild Card
    Doug
    Portland, MI
    Do you read the whole thread?! Can't get a socket in on the bolt-head, for SEVERAL reasons! How can I impact it out if a socket won't physically fit under there? The ONLY thing that fits is a spanner wrench. That's it. I've actually said that at least twice now in this thread.
    2nd gens are NOT 1st gens!
    Oh my. Thanks for the lack of input, it's awesome! We'll see how it goes this morning. Getting some new sawzall blades in about 30 minutes.
  8. Sep 8, 2012 at 4:39 AM
    Wild Card
    Doug
    Portland, MI
    Perhaps it didn't move well. I always have one hell of a clunk when hitting a bump on my front-driver's side. This may be the culprit. I'll see once the new suspension is in.
  9. Sep 8, 2012 at 4:49 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Ive gotten impacts in there on 1st gens. Try with an extension, and post some pics of how the CV is in the way. Btw you can always remove the axle...just a 35mm nut IIRC
  10. Sep 8, 2012 at 4:51 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Pop off the hub, remove the nut. Remove the spindle. Tie the axle away. Takes less than 15 minutes. Sorry to have angered you, one thousand apologies to you and the internet gods
  11. Sep 8, 2012 at 5:09 AM
    Wild Card
    Doug
    Portland, MI
    Do not have 35mm socket or wrench. Cannot do that. Do not have air compressor. Or air tools. :)
    Truck is sitting, non-functional, in my driveway, not able to move at the moment, so no going to the hardware store until my "ride" gets here.
    Yes, if I could remove the CV, things would be ALOT easier.
    But honestly, if I had air tools, I would've just used an air-chisel against the bolt where the nut goes on and jack-hammered it out in the first place. Just don't have them nor access to them.
  12. Sep 8, 2012 at 5:51 AM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I have dealt with your same exact problem, the bolt is frozen to the sleeve inside the busing. Sure the bolt will spin, but it is just the sleeve spinning inside the bushing.
    Make sure you have the right blade for your saws-all and it also helps to have the angle grinder. I had to take the spark guard off my angle grinder to have room. I just kept cutting everything away, and took both sides of the bolt off.
    You are right that you have a problem with bending those tabs, can't keep doing that, luckily I got my frame replaced right after this job and got new LCA's with the frame replacement. If not, you are likely going to need to take those LCA's out, another big job and get those tabs straight and re-enforced with some triangles?
    Just go easy. Take your time.
    Here is the pic of the carnage in the middle of my job.
  13. Sep 8, 2012 at 6:04 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Have you unbolted the lower ball joint from the spindle yet? If you do, you can swing the spindle and cv to the side to give yourself a little more working room.
  14. Sep 8, 2012 at 6:14 AM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    To clarify, I have never drilled out the bolt you are trying to remove. But I have drilled out bolt on front suspensions before. If you can acces one side of the bolt with a drll, you may be able to drill right through, if your drill bits are long enough. But looking at the pictures again, I see your concern with the cv boot, Can't access one side, and may puncture the boot if you drill through. Tough call All I can say is GOOD LUCK.
  15. Sep 8, 2012 at 10:31 AM
    #35
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Hit it with the entire can all at once but be careful not to breath it in. Try to hit just the bolt and nothing else (use a straw). It will work.
  16. Sep 8, 2012 at 12:49 PM
    #36
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If the nut spins freely, run it out to where its flush with bolt end & just blast away with BMFH until the sleeve seperates from grommett (since sleeve is froze to bolt, )
  17. Sep 8, 2012 at 12:56 PM
    #37
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Did you losten the bolts on the lower arm so it can droop more? Maybe it has too much pressure from the strut pushing on the arm.
  18. Sep 8, 2012 at 1:44 PM
    #38
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Ok Dougie, this is your fix, after thinking a bit this is what you need to do get a can or 2 of carb/choke cleaner & get as much of that lube/grease off as you can & the area around the shock mount, get a propane or MAP gas torch & heat the front of that bolt (nut end) & heat the area on the shock eyelett (NOT SHOCK BODY THO" ! ) for obvious reasons, get it good & hot THEN beat it with hammer The idea is to get the rubber inside the shock eyelett to almost melt & there will probably be a flame up or 2 but nothing that'll get out of control
    since your changing shocks anyway who cares if gromett is ruined this process will get the bolt/sleeve out & won't melt your cv boot either..
  19. Sep 8, 2012 at 2:42 PM
    #39
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    If something is stuck, you want to either freeze and contract it, or heat and expand what its stuck in. Why would he heat the bolt and expand the bolt? It will just get stuck even more :notsure:
    Freeze that bish enough and you will be able to pull it out with your fingers (wear some heavy gloves ;))
  20. Sep 8, 2012 at 2:58 PM
    #40
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    So, how's it going Doug?
