Darton Sleeves
Discussion in 'Performance and Tuning' started by Torspd, Sep 11, 2012.
  1. Aug 10, 2013 at 5:05 AM
    #221
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yeah. Not just pump and go. Lol.so are all things checking out well, and ready to drive it to the tuner's?
  2. Aug 10, 2013 at 5:34 AM
    #222
    Torspd
    Tor
    The Great America!
    Did you get a cooler T-Stat? If not, I am quite anxious to see how cool your water temps stay, due to the fins on the sleeves and the E-Fan. Hoping that they rarely raise.
  3. Aug 10, 2013 at 9:27 AM
    #223
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Ya everything is cool I have 2 replace a oring on the high side pressure hose for my a/c it's leaking but other than than its good. I do have a cooler tstat an I have a lower pressure radiator cap for a fail safe for the copper headgaskets and all. But I set the fan 2 kick on at 175 and it takes down to about 160/165 so it's nice
  4. Aug 10, 2013 at 9:44 AM
    #224
    Torspd
    Tor
    The Great America!
    Wholey smokes. Gets that nice and cool! Can't wait to get new radiator with dual SPAL fans installed now!
  5. Aug 10, 2013 at 11:30 AM
    #225
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Get it son it's awesome especially for big hp. You got any pics of your build?
  6. Aug 10, 2013 at 5:38 PM
    #226
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    So tor how much can a stock crank hold hp level I want 600 rwhp
  7. Aug 10, 2013 at 5:52 PM
    #227
    Torspd
    Tor
    The Great America!
    That has been tested and proven. It was running 630-650whp regularly.
  8. Aug 10, 2013 at 5:58 PM
    #228
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Dude you just made my life!!!! I can accomplish my goal of 600whp. O I saw you YouTube start up vid. I love that clear coolant hose.
  9. Aug 12, 2013 at 10:56 AM
    #229
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Also how did you come up with those numbers on the crank?
  10. Aug 12, 2013 at 11:50 AM
    #230
    Torspd
    Tor
    The Great America!
    That glass is from www.killerglass.com Very very strong material. It has saved me quite a few times. I got a Valentine's package deal a few years ago. Upper and lower piece. Toon has the lower piece.
    As for the crank, I called PSI Racing in Florida some time ago, to ask them about the twin turbo XR that they built. The intake manifold in specifc. We talked about the truck as well. The owner confimed the numbers and said that it would have made betted power with better turbos, at a little lower psi.
  11. Aug 12, 2013 at 1:41 PM
    #231
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Sweet. I'm gonna probably shoot for a little under 600 since my Trans is rated for 750 crank and my turbo is also rated for that
  12. Aug 12, 2013 at 1:44 PM
    #232
    Torspd
    Tor
    The Great America!
    Sounds plenty smart to me. How is the tuning coming along?
  13. Aug 12, 2013 at 4:29 PM
    #233
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    My truck is sitting. I'm gettin it dyno tuned Saturday so excited. The tuner is coming 2 my house 2 set base timing and a few other things then I'm gonna drive over 2 the dyno which is 3min from my shop and then we are off 2 the races
  14. Aug 12, 2013 at 5:13 PM
    #234
    Torspd
    Tor
    The Great America!
    House calls. I like. :)
    Can't wait to see how this setup performs!
  15. Aug 12, 2013 at 5:26 PM
    #235
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I know me 2. I want 2 see yours. What do you have 2 do 2 yours?
  16. Aug 12, 2013 at 5:30 PM
    #236
    Torspd
    Tor
    The Great America!
    Get it .......
  17. Aug 12, 2013 at 6:15 PM
    #237
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Get your engine?
  18. Aug 12, 2013 at 6:16 PM
    #238
    Torspd
    Tor
    The Great America!
    Correct.
  19. Aug 12, 2013 at 6:20 PM
    #239
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Putting extra butter on my popcorn for the finale of your two builds boys. Tires are gonna shred I can smell it already :burnrubber:
  20. Aug 12, 2013 at 6:37 PM
    #240
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Lol we shall see. Tor where is your engine? Also what else do you need
