Darton Sleeves
Discussion in 'Performance and Tuning' started by Torspd, Sep 11, 2012.
  1. Aug 23, 2013 at 3:46 PM
    #301
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well I really hope one of them has a spare for you. I'd much rather that then part with mine, if I don't have to.
    Any upgdates from either of them?
  2. Aug 23, 2013 at 3:48 PM
    #302
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    No not yet
  3. Aug 23, 2013 at 9:32 PM
    #303
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    I have a crank but some counterweights were somewhat damaged by flying debris when the rods let go. It may be useable? I have no clue
  4. Aug 24, 2013 at 7:16 AM
    #304
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I appreciate the offer but I don't want 2 take any chances lol
  5. Aug 24, 2013 at 8:52 AM
    #305
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    U no want franken engine?:p
  6. Aug 24, 2013 at 9:59 AM
    #306
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Lol I've had that twice already don't want it again
  7. Aug 26, 2013 at 1:02 PM
    #307
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Got a crank from gadget this morning took it 2 darton they should have it done by the end of the week
  8. Aug 26, 2013 at 1:15 PM
    #308
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
  9. Aug 26, 2013 at 7:14 PM
    #309
    Torspd
    Tor
    The Great America!
    Alright man. Good stuff. Take a picture of how you fix that plug too, if you don't mind. :)
  10. Aug 26, 2013 at 7:45 PM
    #310
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I'm gonna find a pipe end cap tht is the same size an thread it in there that sucker won't come out. You should ask darton 2 do that 2 yours
  11. Aug 26, 2013 at 7:47 PM
    #311
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    surprised that the plug came loose. glad your getting it back on track.
  12. Aug 30, 2013 at 12:43 PM
    #312
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    update number six rod was hurt also they are gonna try and machine it to make the bore right will make the rod a hair shorter but will probably be a good thing so next week should get my engine back and ill start assembly again
  13. Aug 30, 2013 at 1:57 PM
    #313
    Torspd
    Tor
    The Great America!
    Poor rod. :pout:
    Best of wish all else turns out just fine. :thumbsup:
  14. Sep 5, 2013 at 8:00 AM
    #314
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Ok update on this money pit i call a truck the rod was able to be machined an everything else is ok with my engine. I start my new job Monday so ill be humping all weekend 2 finish my truck. Then next Saturday ill be getting it tuned again. Everybody start prayin that everything goes smooth
  15. Sep 5, 2013 at 8:06 AM
    #315
    Torspd
    Tor
    The Great America!
    Well that there is a sigh of relief, for the rod. I have a strong feeling that you will be able to knock it out pretty quickly. Did last time.
    Got to get some videos and pics of the turning.
  16. Sep 5, 2013 at 11:40 AM
    #316
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    good luck with the new job and gettn the truck back running!
  17. Sep 5, 2013 at 12:59 PM
    #317
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Thanks man
  18. Sep 9, 2013 at 8:29 PM
    #318
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Just little update truck is running no issues new fabd aluminum radiator is in new oil return setup is done an just drove it with the tune I had before I lost oil pressure last time 11 psi with 378whp that is fun but Saturday the real tune is happening 550whp is what I'm gonna do 2 be a safe dd
  19. Sep 10, 2013 at 4:26 AM
    #319
    Torspd
    Tor
    The Great America!
    So you have the Ron Davis Radiator in there now? Need to post of some pictures man! Don't be stingy.
    Glad to hear that it is running and alive again. No time to be wasted. Need to post up some graphs and videos of how it sounds when smashing the skinny pedal too. :D
  20. Sep 10, 2013 at 4:36 AM
    #320
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Lol I will I'm gonna take pics 2day. I was workin my ass off didn't have anytime 2 do anythin. Yes I have the Ron Davis radiator in there. It's a ford rad that has the right hose location it's a little smaller from right 2 left but is rated for double the hp I have. Actually used the stock rad layout and cut brackets out of aluminum and welded them to the side of the rad an it bolts in like stock it even uses the stock bushings. I had to cut down the shroud on the efan but it all fits so perfect now
