Darton Sleeves
Discussion in 'Performance and Tuning' started by Torspd, Sep 11, 2012.
  1. Jun 13, 2013 at 10:50 AM
    #81
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I guess that means that you don't plan on running 30psi??? :eek:
  2. Jun 13, 2013 at 12:02 PM
    #82
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    20s is where I'm gonna hang out lol
  3. Jun 13, 2013 at 12:07 PM
    #83
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Not a bad place to hang out :cool:
  4. Jun 13, 2013 at 12:53 PM
    #84
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    what boost are you going to be running? urd? turbo?
  5. Jun 13, 2013 at 2:58 PM
    #85
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
  6. Jun 20, 2013 at 3:57 PM
    #86
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Hey tor trying 2 find some clevite bearings kinda quick because darton said there source is on back order till July. Thanks brother
  7. Jun 20, 2013 at 3:59 PM
    #87
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Also I'm running a map ecu3 an gadget recommends I get trd supercharger injectors do you know of any that will work with the map ecu3?
  8. Jun 21, 2013 at 7:38 AM
    #88
    Torspd
    Tor
    The Great America!
    Try www.Dezod.com. and www.LCEperformance.com. They might have some bearings.
    Do you currently have the Map-ECU3? It won't be capable to handle the injector size you will need, if you are planning on running 20psi, and the factory MAF sensor.
    It will need a have to use a its MAP sensor, but you will also have to have an AFR sensor wired into it.
    In all honesty, for what you have just invested in, you need something much better than the MAP-ECU3.
  9. Jun 21, 2013 at 8:02 AM
    #89
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    This is what gadget recommended for me
  10. Jun 21, 2013 at 8:06 AM
    #90
    Torspd
    Tor
    The Great America!
    Ok. Then be very careful with its map sensor.
  11. Jun 21, 2013 at 8:18 AM
    #91
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Ok well I know it's way better than the piece of shit unichip I had lol
  12. Jun 21, 2013 at 8:47 AM
    #92
    Torspd
    Tor
    The Great America!
    Well, my MAP-ECU2 ran my RC Engineering 550cc high impedance inectors just fine with tuning. I highly recommend Injector Dynamics injectors though. Paul @ Dezod can set you up with those. They are flow matched through the entire voltage scale.
  13. Jun 21, 2013 at 11:41 AM
    #93
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Sweet I'm just making sure that they will work fine for my setup an not having 2 replace them because they just don't cut it
  14. Jun 22, 2013 at 1:38 PM
    #94
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Look what I did with my old engine made a engine table out of it u8ajyzej_7465a5572b10aeff48773cc2a2dfeb4b0d21977a.jpg will sell for a reasonable amount
  15. Jun 22, 2013 at 2:34 PM
    #95
    Torspd
    Tor
    The Great America!
    1st 1GR table i've seen. Looks Pro too.
  16. Jun 22, 2013 at 2:42 PM
    #96
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Thanks man this is my second table I've made I have a s2000 engine table right now the 1gr is taking its place as the coffee table an the s2k is a end table/wine holder
  17. Jun 22, 2013 at 2:43 PM
    #97
    Torspd
    Tor
    The Great America!
    Damn I need a welder.
  18. Jun 22, 2013 at 2:50 PM
    #98
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Ya I love having a welder I'm always welding stuff up. I do alot of custom fab work here an I weld exhausts up all the time. Just did one for a guy on the forum
  19. Jun 22, 2013 at 10:23 PM
    #99
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Wow. That's a nice table. I want one lol
  20. Jun 23, 2013 at 5:19 AM
    #100
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Get me a old block with pistons ill do it for you
