Dash Illumination Wire
Discussion in 'Audio & Video' started by BlueNorthToyo, May 21, 2009.
  1. May 21, 2009 at 1:40 PM
    BlueNorthToyo
    BlueNorthToyo [OP] Well-Known Member
    07 DBL Cab, TRD, SR5 & Tow Package, 3" Lift
    3" Revtek lift, Access Laredo Tonneau Cover (awaiting delivery), Debagged Tailgate, Pop and Lock Tail Gate Lock (awaiting delivery), Grom I-pod hardwire, Chrome Side Step Bars, Hood Deflector, Window Vents, 15" Stubby Antenna, GE NIghthawk Headlights, Fog Light Mod, Hose Clamp Tailgat
    Anyone know what color the dash illumination wire is in the stock wiring harness. I am installing an aftermarket HU and the wiriing harness that I have does not have a wire for this. Wanted to splice intothe stock harness so that the stereo dims with the rest of the lights.
  2. May 21, 2009 at 1:59 PM
    BlueNorthToyo
    If the wiring harness that came with the HU does not have the orange wire coming off it, does this mean that it does not have the capacity to dim?
    Stupid Sony
  3. May 21, 2009 at 8:13 PM
    acozzens
    acozzens Well-Known Member
    98056 , washington state
    06 4d 4wd trd sr5 silver
    Michelin ltx m/s WSU (cougs) License Plate Holder $1.99 Gate Theft Mod DIY HU install DIY SWI-JACK install DIY rear speaker & baffle DIY ipod audio/video interface DIY HD radio DIY Alpine pdx 5 DIY front components install DIY RedLine Tuning Gas hood lift ( very slick ) DIY slimcubby gb hid head/fog DIY extang trifold trifecta DIY dynolock tailgate lock
    I have a similar issue. I just left that cable un done.
    My deck harness had the orange, but no counterpart in the factory cable bundle.
    However, with my deck ( jvc kdavx44 ) it has a auto dimmer based on the clock..
    Currently in the Northwest, I set it to "dim" at 9pm "un Dim" at 6:00am
    I'd just check if your deck has similar... i'm sure it can dim..
    All cars i've ever had have that little internal dimmer control for the gauges. All aftermarket HU's i've had have some dimming mechanism built in.
    Personally I rarely ever use that... Therefore, the orange wire became low priority and it just doesn't bug me much. Doesn't bug me at all except that I like to hook up every wire.
    If it does bother you though, do a quick search for 2007 tacoma wiring guide or whatever. I found that information easily. It does not bother me enough to unbundle the factory wires..
    wonder if it will actually bother you... do you really use that spin-wheel dimmer ? Ever ?
  4. May 22, 2009 at 6:52 AM
    BlueNorthToyo
    The HU harness does not have the orange wire and all other wires are connected to their color coded counterpart. The adapter harness to go from the HU harness to the stock harness does have an orange wire that I have deadheaded right now.
    As for dimming the dash lights, I do like to dim them on long night road trips. Just find it easier and less distracting than having the whole dash blazing at me.
  5. May 22, 2009 at 6:54 AM
    fixedforbroke
    fixedforbroke Well-Known Member
    St. Simons Island
    06 PreRunner SR5 White as Snow
    Stock the way god made her. (FOR NOW)
    this is a good thread :popcorn:
  6. May 22, 2009 at 8:47 PM
    BlueNorthToyo
    It would be an even better thread if I could get the answer! LOL.
  7. May 22, 2009 at 8:58 PM
    garno13
    garno13 Well-Known Member
    great falls, mt
    06 red x-runner
    all new carbon fiber black with red seats with sub box, ipod center console holder, pioneer f900bt navigation, 2- alpine pdx amps, 10" type-x sub in custome enclosure, alpine type-x components, in kick panel pods, tunneau cover, urd cold air intake , throttle body spacer, painted engine cover, bermuda digital tails, projector headlights 8000k h1 hid kit, lba short headers, bullet muffler. this week having billet grill, urd cold air intake, and liscense plates powder coated iridium red color to match rims should be on thursday.
    If you pop the dim button out you can check signal there and tap in at that location but you will need wire to run that far. I would sugest adding a fuse in between so you have no future problems between the two.
  8. May 22, 2009 at 9:11 PM
    BlueNorthToyo
    I thought about doing that but the problem I have is that the Sony wiring harness does not have a wire for the dimmer. All the wires are used in the Sony harness but the adapter harness ( to go from the Sony to the stock harness) has an extra orange wire?
  9. May 22, 2009 at 9:14 PM
    garno13
    great falls, mt
    06 red x-runner
    the stereo doesn't have the feature to do it then I would not even bother. I do professional installs and if stereo does not have you don't want to do. If you try you might mess up the stereo and the truck.
  10. May 22, 2009 at 11:17 PM
    BlueNorthToyo
    Ok. Thanks for all the help. I guess the light stay on.
