Dash Insert part name...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tpique1, Dec 25, 2012.
  1. Dec 25, 2012 at 12:31 PM
    tpique1
    tpique1 [OP] Member
    This is my first post. I'm not sure if this is the right place to ask this question but....
    I have searched everywhere I could to find out what the name of the plastic insert is on either side of the stereo console. The inserts are located just below the ac vents on either side. On some Tacoma models, on the left side, the 4 wheel drive switch is mounted to it; on the right side the passenger side air bag switch is mounted to it.
    Could someone please direct me to where I can get a replacement? I would appreciate it.
    I've attached an image.
    Thanks.
  2. Dec 25, 2012 at 12:33 PM
    98tacoma27
    Ben
    Not Beech Creek
  3. Dec 25, 2012 at 12:46 PM
    tpique1
    tpique1 [OP] Member
    Thank you. Much appreciated.
  4. Dec 25, 2012 at 1:16 PM
    cooktaco
    cooktaco Well-Known Member
    Northern California
    11 Dbl. cab TRD 4x4
    Weahertecs, Bed met, Snugtop, Avid sliders, TSB Springs, Bilstein 5100's @1.75,
    This should get you started. I used that spot for my off road light switch and I bought a new cover in case I ever decide to go back to stock. Mine is a DC so no airbag switch but it should be in the neighborhood.
  5. Dec 25, 2012 at 9:06 PM
    tpique1
    tpique1 [OP] Member
    Thanks for the tip! This was very helpful.
    For those who might need this in the future, the part is called a
    "COVER SWITCH BASE HOLE"
