Dash keeps popping out of place
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jonesy, May 24, 2013.
  1. May 24, 2013 at 8:17 AM
    Jonesy
    Jonesy [OP] Member
    PEI Canada
    06 SR5 TRD
    :confused:Just wondering is anyone else has the problem with the dash popping out of place on the lhs by the coin holder , mine keeps poppimg out a bit and will not stay , any suggestions on a repair ? Thanks guys
  2. May 24, 2013 at 8:25 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    If I remember correctly wen I took that part of my dash out it was held in by some plastic clips. You might have to take yours apart to find out where its actually having issues. :cool:
  3. May 24, 2013 at 7:30 PM
    maxboi
    maxboi MAXBOI
    Brian
    SODA CITY
    2011 White D'Cab OR 4wd
    76 FJ horns, Weathertechs, Backup Camera anytime switch, Fogs anytime, Clamp & Washer tailgate, Diff Breather,
    My old 06 had the same problem
    There's a TSB that changes the clip to a better one
  4. May 24, 2013 at 7:56 PM
    Taco'09
    Taco'09 Well-Known Member
    ^^^ This. Its a very old TSB. Call the stealer and order one or two of this clip: 90468-04177. It is a metal clip that replaces the plastic clip in that corner. It only takes one but if you are like me you will pop the first one to somewhere behind the dash, to the other side of the garage or out in the grass and never find it.
    The dash panels are secured in many locations by pink and yellow plastic clips as you will soon find out.
    For reference:
    The pink clips are 90467-12080.
    The yellow clips are 90467-10203.
  5. Jun 8, 2013 at 5:02 PM
    Jonesy
    Jonesy [OP] Member
    PEI Canada
    06 SR5 TRD
    You guys are amazing. Got the clips and all fixed up. Thanks again. :).
